View Full Version : Focus | C Max
Pages : 1 2 [3] 4 5 6 7
  1. fan speed
  2. '07 rear brake squeal
  3. changing alternator
  4. hi lights w/working fog lights
  5. Water in intake
  6. Cyl 2 missfire code
  7. E-Brake Light
  8. Body sway in 2004 Focus
  9. Headlights dont work Brights do
  10. Dash and Parking lights out - 2001 ZX3
  11. how to change out alternator
  12. 2002 Focus "door ajar" light won't go off...
  13. Driver's Side Heated Seat Problem ('03 ZTW)
  14. Focus 05 Gas Pedal Stuck in the morning...
  15. Strange problem affecting DASH & TRANSMISSION ???
  16. Engine Replacement Cost
  17. 2007 focus se
  18. 07 Focus ZX3 vs 07 Cobalt???
  19. Swap SPI for Zetec?
  20. Help.x
  21. Rear Brakes: 2005 ZX4 Ford Focus
  22. question about my car
  23. Focus wont downshift...
  24. 2002 SVT?yes/no
  25. km to miles 07 focus zx4
  26. Considering an 03 Focus with 24k
  27. 2000 Focus Extreme Road Noise
  28. Engine Rattling noise
  29. Removing relays from 2001 fuse box
  30. inside rear door panel how to please
  31. Instrument Problem
  32. Stereo
  33. white smoke
  34. Focus 2000 ZX3: Alternator Problem?!?
  35. windows falling down
  36. 2002 Focus - Steering Column Locking Lever
  37. need info or help on short ram intake
  38. No low beams or fog lamps
  39. 2003 focus stalling in reverse
  40. focus lacks power
  41. 2006 2.0L engine vs old 2.0L
  42. No turn signal
  43. 2005 ford focus tranny problems and more
  44. 20 inch rims
  45. help!!!!!! Brakes are off I cant get the back on
  46. Inoperable power locks/ keyless entry
  47. 02 focus vibration in reverse.
  48. Belt Pulley
  49. Electrical or ignition switch?
  50. Chime won't shut off!!!
  51. Can the Ford car Manual be driven in "free gear"
  52. 00 focus won't start
  53. Increasing torque?
  54. '02 ZX5 Hard Shifting
  55. 05 focus air filter
  56. Help!! My 2000 ZX3 is making a weird clicking noise
  57. 2002 SE Possible Misfiring?
  58. 01 focus se cluth help!!!
  59. What's wrong with my 02 Focus
  60. Common Problems?
  61. 2007 trunk release issues
  62. Washer Fluid Pump
  63. hella projectors
  64. running rich
  65. 2000 Focus Steering Knuckle Question...
  66. Loud whine in right rear
  67. help!!!! bogging problems with focus
  68. 2001 Focus Zetec Engine Vibration
  69. focus air bag??
  70. I need help!
  71. spark plugs for 2005
  72. I need help or information.
  73. Ford Focus 2002
  74. Turbo Focus...
  75. intake manifold runner circuit code p1520
  76. One headlight working
  77. focus wont start
  78. 2005 Ford Focus Zetec Broken Locking Alloy Nut
  79. Ebay Coilovers
  80. 5.0L mustang engine in a 2000 focus
  81. Power Trunk
  82. Supercharging?
  83. vibration from hell
  84. Need to replace drivers side seat
  85. Drivers Side Door Chimes with no key in ignition and with headlights off & door open
  86. Turn signal blink frequency...
  87. Just Curious???
  88. windshield wiper arm removal?
  89. '05 fuel filter
  90. 2006 focus altinator
  91. horn location
  92. Repair Manual Recommendation
  93. Focus rally parts HELP!
  94. Car does not hold self on slope
  95. Blown engine fuse after AC is on for 30 minutes
  96. Rear axle nut size???
  97. which is better
  98. what typeof engine
  99. new cams
  100. 07 radio question
  101. Front Brake Procedure...Help!
  102. Zx2 Zetec and ZX3 Zetec
  103. 05 Zx3 Cel
  104. installing keyless entry
  105. Burning Rubber Smell
  106. engine number????????
  107. i want a tach
  108. Talk me in or talk me out...
  109. 2000 focus zts
  110. Should I buy a salvaged vehicle?
  111. i just bought 2000 focus zts
  112. Tranny Slippage Focus 02
  113. 2007 Cruise Control Question
  114. most dependable focus=??
  115. a/c not working right
  116. 2005 Ford Focus ST Sunroof troubles
  117. Tire troubles with 2005 ST FOCUS
  118. New-jack
  119. Looking for mods
  120. 02 Ford ZTS Electrical Problem
  121. 2000 Ford UnFOCUSed (Door Lock Problems)
  122. Problem with windshield wiper motor???
  123. 2002 Focus Cold Starting
  124. 2000 ford focus lx
  125. headlight harness???
  126. focus tranny swap
  127. 03 focus rear breaks
  128. thinking of getthing a 2001 foucus
  129. Rear Brake Adjusment on 2000 ZX3?
  130. 2003 rattles on driver side upon acceleration ALWAYS!!
  131. extended warranty
  132. 01 modified zetec losing power
  133. ford focus kona zx3 5speed tranmission mtx or igx???
  134. 2003 Focus needs new tranny
  135. Brights are stuck, help would be seriously appreciated.
  136. quiet performance exhaust
  137. 2003 Ford Focus Check Engine
  138. 01-Focus - Intermitent Hesitation
  139. i want specs!
  140. again....front brake problems 2003 zx3
  141. Check engine light...O2 sensor....Misfire?
  142. Urgent Help Needed
  143. Over Drive issue
  144. '07 Focus
  145. Rounded Oil Drain Bolt - Ford Focus 2005 SE ZX4
  146. 2003 Focus Won't Start Unless #1 & #2 Coil Switched
  147. Anyone Ever Change Serpentine Belt & Alternator 2000 Focus Zetech???????????
  148. electrical
  149. #@*$?()&^ auto-locking doors!
  150. Brake light stuck on
  151. 2000 Ford Focus Code PS10701
  152. I on cluster then my car stalls and goes again
  153. Anyone Know Or Have Pics Of Changing A Power Steering Pump Z Tech Engine?????????????
  154. Hesitation
  155. High idle at first...
  156. Starting problem
  157. 2000 ford focus z3 smog problem
  158. Any Ideas?
  159. 2003 focus 5 speed 2.3L please help
  160. For Sale Ford Focus Special Millenium Edition!
  161. Advice appreciated - 2002 Focus Wagon.
  162. 00 Focus ZX3 5spd Idle Problem
  163. Odd Problem
  164. high rpm?
  165. Projector headlight bulbs?
  166. 2007 Focus ZX3 S CD Player Removal
  167. 05 Focus vibration at highway speeds, did all I can, problem persists
  168. Thanks
  169. Focus trans cables won't come off!
  170. looking for an SVT
  171. Ford Focus 2000 Fuel Filter
  172. Timing Belt
  173. Keyless Entry Code Location
  174. 2001 Focus LX speedometer jumps like tachometer when reving motor
  175. possible bearing problem
  176. Ignition Problem!!
  177. Problems with locks /
  178. Is It Worth It?
  179. 02 focus need help
  180. electrical problem, 2000 Ford Focus won't start
  181. Focus Safety Defect Warranty Problem
  182. eletrical problem, no pc broken.....focus zts 2000.
  183. Ford Focus modified by Mattig Tuning
  184. help about pump of focus
  185. 2000 ZTS...lost key..deales charging $160.00 need option?????Is this true??
  186. engine oil light & clicking, but no start
  187. Clicking & Squeeking
  188. 2003 Focus 23,000 miles Engine light EVAP Emission?
  189. dooski
  190. Come Check out Rally at X Games 12 Aug. 3-6 in Los Angeles
  191. 06 ST 2.3l + AEM CAI??????
  192. Cruise control not working
  193. Digital Readouts
  194. Steeda intake install
  195. Installing led undercar lights /amps and speakers
  196. Removing rear brake drum dust cap
  197. I just bought an '05 ZX3 SE and I have a few questions.
  198. Trunk Latch problem
  199. Better to dye or paint your dashboard?
  200. Power Door Locks: 2000 Focus Se Wagon
  201. Front Wheel Noise
  202. 2000 Se Wagon Focus: Central Timer Module
  203. Stuck In Park & Stuck Key Dealer Says New Shifter Needed?? $300?????????????
  204. 2000 Focus, left side parking lights don't work
  205. Blaupunkt stereo problem
  206. focus wont start
  207. Ford Focus
  208. Ignition Switch Problem
  209. 00 focus se check engine light
  210. Anyone Know Where The Intake To Add Freon To Ac???
  211. Door Ajar Light
  212. Lock Or No dead Lock
  213. Looking at buying an 03 - ZTS sedan..
  214. problem with horn on 2003 ZX3
  215. Hole in firewall
  216. Another problem with the little piece of...
  217. CAI or Short ram intakes
  218. slips out of overdrive
  219. 00 Focus Spudders When Accelerating + CEL
  220. 4 12's
  221. Cooling Fan Switch?
  222. slow down shift
  223. MIL Light is On a 2001
  224. Replacing rear power window motor/regulator
  225. Drive Up Ramp - Clearance
  226. Engine Specs
  227. overdrive gear slips
  228. 2000 SE acceleration problem
  229. The Warranty
  230. 2000 focus key problem
  231. Help Car Problem PLEASE
  232. PCV Value
  233. 30K - Service for 2005 Ford Focus ZX4
  234. 2003 Focus ZX3 front brake noise
  235. Focus on Fritz
  236. 00 focus se
  237. boss monitor problem
  238. 02 LX, 5spd, vibration @ high speeds
  239. Transmission no overdrive
  240. 2004 Focus SE - 102,000 KM!!
  241. Small Vibration at 1500 RPMs
  242. CAI installation trouble!:banghead:
  243. Brake light is on
  244. 06 focus for sale
  245. ignition problem.. can you help me?
  246. Instal/Remove Doors
  247. 2000 Focus, Rough Idling in Signals and now P171 code appears
  248. After Market Exhaust worth it??
  249. Wierdest radio issue ever!
  250. Recommend or Not???
