01-Focus - Intermitent Hesitation
Ron_thetoolman
01-01-2007, 09:32 AM
New to forum .... can anyone help ... Car idles good, while driving it will hesitate and no power, but not all the time. No check engine light on. I replaced fuel pump and filter, then was told it was the coil, replaced that. Still the same, seems to be getting worse. Also replaced plugs and Air filter . Any help would be appreciated ... Thanks.
Ron_thetoolman
01-12-2007, 05:56 PM
Back to square one ...... the coil I installed (used) started missing on # 2 Cyl. after about 2- weeks checked wire to plug with another but turns out to be a bad coil .... installed orginal coil and now car works fine at Idle, same as before put in gear with a little weight and it starts to mis-fire again .... could this mean both coils are bad ... or is there something that could burn the coil out . ..... any help would be appreciated ....Thanks.
