a/c not working right
JLL0021
03-18-2007, 02:56 PM
I gotta problem with the a/c in my g/f 2000 focus. The first 3 levels of the a/c won't work but the 4th will work and same thing for heat. Compressor is working. Could it just be the switch? And if so, is it pretty easy to change the switch myself?
mr_tw
03-18-2007, 11:57 PM
so it's the fan, that won't turn on using fan speeds 1,2, or 3? or is the compressor not on at these respective fan speeds?
JLL0021
03-19-2007, 09:28 PM
The fan won't turn on those speeds. Compressor is kicking on..
mr_tw
03-20-2007, 09:26 PM
I had a friend with the same problem, completely different car, bu it turned out to be the fan, didi you lose the speeds one by one or did the first three all go at the same time? when the fan runs does it sound normal? or is it noisy?
JLL0021
03-20-2007, 10:18 PM
all three went out at the same time. and everything sounds normal.
randall L
04-28-2007, 09:04 PM
This will fix your problem (http://www.focusfanatics.com/forum/showthread.php?t=62212).
