Washer Fluid Pump
bfeller
08-05-2007, 02:04 PM
Probably a stupid question, but where can one find the washer fluid pump on a 2003 Focus ZTW?
I am assuming my pump has gone bad as the windshield washer cleaner no longer will spray in front or back. Unfortunately, I cannot seem to find the pump to replace it.
Thanks!
Thanks!
sib10
12-06-2007, 07:05 PM
Thanks!
the pump and resevoir are located inside the drivers side fender to access you must remove the inner fender
Thanks!
knelleken
12-10-2007, 07:19 PM
if you pull the pump straight out of the bottle, you will se a rubber thumble screen. most of the time, the the rubber screen gets cloged up with green slime
