View Full Version : Intrepid
Pages : 1 2 [3] 4 5 6
  1. 96 3.5 radiator fans staying on
  2. 95 Intrepid 3.3L jerks when accelerating
  3. intrepid/concorde water pump
  4. Timing belt '98?
  5. no a/c
  6. 1995 Intrepid pouring oil
  7. dash lights
  8. 96 intrepid engine tap
  9. 95 intrepid
  10. 94 Intrepid, no heat
  11. 2002 Intrepid 3.5 overheat
  12. not shifting out of park
  13. Belt Pulley Clicking Sound
  14. OEM Mopar Aftermarket Parts
  15. 2002 Intrepid code P0440
  16. Knock Knock... 2001 3.2L Questions
  17. 97 3.5 vibrates (shakes) when shifting
  18. 97 cranks but doesn't start
  19. 2002 Intrepid Transmission Problems
  20. HELP!!CAr dosen't start, Raw fuel smell, Puff out of cyl 4!!WTF&^%
  21. Heater not working properly. 1999 Intrepid
  22. 99 intrepid help needed
  23. 02 Intrepid water in floorboard
  24. thermostat help!
  25. Extended cranking time 96 dodge intrepid
  26. 96 Intrepid Front Struts for sale.
  27. 2002 Intrepid Se Trans question?
  28. Losing Coolant
  29. Speedometer Broken
  30. 96 3.5 Overheating
  31. 2004 intrepid
  32. Fan again HELP!!
  33. So long Trep.......'sniff', 'sniff'....
  34. need help with fuel pressure
  35. 94 Intrepid lost it's marbles
  36. 99' Intrepid oil pressure problem after engine rebuild
  37. 99 Intrepid Warning Light Blink on and off
  38. Dodge Intrepid Thermostat help
  39. 1995 Dodge Intrepid High-pitched Hum
  40. 96 Intrepid Driver Door Panel
  41. No Fan....PCM?
  42. No start 2.7L ...Help!
  43. No start 2.7L
  44. 1993 Tie-rod end
  45. 1993 Tie-rod end
  46. Intrepid dilapidation
  47. 2.7 Engine Problems...
  48. 2000 intrepid, No speedometer, only 2nd gear and reverse
  49. 2000 Intrepid Heater Smell
  50. '99 Intrepid ... Burned on $2K rebuilt trans 'cuz speed sensor failed??
  51. 1999 2.7 coils
  52. Air bag, ABS Light, Dash Doesn't Work - PCM?
  53. 2000 intrepid won't move.
  54. 1996 or 1997 repair/service manual
  55. Engine knock
  56. Need Help relacing ignition swtich...
  57. 94 Intrepid-No guages, runninglights, and limp mode
  58. 95 Intrepid Wont Start,Cold Weather Killed It
  59. Signal light stops working at random
  60. "97 Intrepid gauges drop to 0
  61. Transmission Locked Up
  62. 1999 water pump/timing gear question
  63. 2004 Dodge Intrepid
  64. 2004 Dodge Intrepid
  65. 1996 Dodge intrepid 3.3L misfire codes
  66. 99 intrep brake lights short 911! - 911!
  67. Code Reader for 1994 Intrepid
  68. 1994 Dodge Intrepid tail light
  69. 1999 Intrepid Tranny Swap...I NEED ADVISE!!! PLEASE HELP!
  70. 1996 Intrepid Tanny
  71. Just thinking.....Any safe oil additives??
  72. 98 Intrepid ES, CD Player Fit
  73. Brake Lights
  74. 1999 Dodge Intrepid 2.7 water pump
  75. Heated Catalyst Efficiency Below Threshold
  76. blend door actuator?
  77. Engine Swap
  78. Engine Swap
  79. Engine Swap
  80. 96 Intrepid/ leaking gas
  81. How to turn on Fog Lights
  82. 1999 Intrepid Electrical Problem
  83. 94 intrepid keeps stalling
  84. wont shift out of 2nd
  85. Dodge 2002 Intrepid problems
  86. 1993 Intrepid 3.5l not starting..Please Help
  87. 96 3.5L Fans not running
  88. Looking at a 2001 Intrepid
  89. 1999 Evaporator Change
  90. '97 dodge intrepid lock/unlock switch question
  91. How to pick intrepid Lock? I lock My keys In
  92. Wiper Woes on 96 ES
  93. HELP !!! 1997 Intrepid / car alarm and battery problem
  94. Need tips on removing alternator from 1999 Intrepid
  95. 96 Intrepid
  96. 93 Intrepid No Spark
  97. Limp mode??
  98. ABS Problems
  99. 94 intrepid 3.3 overheating
  100. 95 Intrepid no reverse??
  101. 96 intrepid woes
  102. Coolant leak/ no heat
  103. error code 12 54 43
  104. p0700/p1776 Help please
  105. 98 Intrepid Non-Start
  106. 2003 Intrepid clock
  107. What does an input sensor do? Anyone know and have advise?????
  108. Tranny Help Please!!!!!!!!1
  109. Code 12 for a 95 intrepid
  110. 1997 Headlight issues
  111. 1999 Intrepid lost reverse after a trip to the shop!
  112. 96 Intrepid woes
  113. 1995 Intrepid Starting Problems
  114. 2.7l Thought they were lying
  115. Two Keys Start My Intrepid
  116. Intrepid Oil Pump - Help!!!
  117. 99 Intrepid Help
  118. Tranny Help plz!
  119. 2000 Intrepid Tranmission Problem
  120. ANYONE KNOW WHICH IS THE 3rd CYLINDER ON THE 2.7 I GOT A MISFIRE CODE FOR 3RD CYLIN
  121. brakes
  122. Need advice on a 1999 Intrepid
  123. Front Crank seal on a 3.5
  124. brake noise while driving?
  125. Where is oil pressure sending unit 2004 Intrepid
  126. I'm not an A/C guy......HELP!
  127. 95 intrepid hard down shift
  128. 95 intrepid very hard to steer
  129. Correct air pressure
  130. Problems with 99 Intrepid *shocker I know* please help
  131. Need help-2003 Intrepid Valve Body Replacement
  132. Spark Plugs
  133. so does anyone agree with me?
  134. rattling noise on my 95 intrepid 3.3L?
  135. 1997 Dodge Intrepid Trouble Code 122155 or 22155?
  136. 2001 Intrepid, 2.7
  137. 01 with vibration at 60 mph
  138. 2 Wtf's
  139. An ABS problem with my 1997 Intrepit ES
  140. I think I messed it up
  141. Interference Engine?
  142. Step on brakes, trunk unlocks. '99 Intrepid
  143. Tranny problem/hard shifting
  144. Help, Intrepid quit working!
  145. Engine stalls after replacement
  146. 2000 Dodge Intrepid 2.7
  147. tranny
  148. oil question
  149. 94 Intrepid brake lights and more
  150. Help! Codes 1684, and 0455
  151. Help! Codes 1684, and 0455
  152. Help! Codes 1684, and 0455
  153. Can't shift out of Brake.
  154. HELP Transmission
  155. Warning light cluster going nutz!
  156. 1997 3.5 dodge intrepid
  157. HELP!!! We have NO Idea what to even call it!
  158. Problems after remote programing
  159. pcm #`s
  160. smells like cow manure
  161. 1996 Intrepid light unit
  162. 94 Intrepid sporadically stalls
  163. driving me crazy
  164. Where are my speed sensors located?!?
  165. '01 engine swap...no start.
  166. O2 Sensor / Catalytic Converter
  167. Only 2 days till Christmas
  168. Engine Light
  169. changing engines in an intrepid
  170. Electrical problem oil light on but nothing on dash
  171. Overheating due to passanger side fan?
  172. 99 Intrepid fans won't come on
  173. How to set timing on 2.7L
  174. Coolant leak, no idea where.
  175. blowing engine control fuse
  176. still problems?
  177. Dodge Intrepid, water in oil
  178. A question I forgot to ask
  179. 1996 Intrepid Surging
  180. Dodge Intrepid Switched Engine Promblems
  181. 1996 intrepid stereo repair
  182. Engine ticking.
  183. installing after market stereo
  184. High/low speed fans
  185. A Question?
  186. 2001 intrepid rear seat removal
  187. Right side headlamp
  188. 2000 witrh 2.7 engine stalls and won't restart
  189. I need help.........
  190. no one seems to know answer
  191. 1999 Defroster Fan Noise
  192. alarm system
  193. 98 intrepid hesitates
  194. 97 intrepid 3.5l start and stall
  195. A Interesting Problem...
  196. Water pump? 97 Intrepid 3.5
  197. Blinker Problem
  198. 95 intrepid squealing after new plugs & wires!
  199. alarm ??
  200. 99 intrepid alarm system
  201. 2000 dodge intrepid egr valve
  202. Replacing Driver Side Mirror?
  203. 1997 Intrepid Auto door locks
  204. Dodge Intrepid Guages Dont Work
  205. 93 Intrepid ES stalling problem
  206. Trouble codes....
  207. Front End Clunk
  208. 2000 Dodge Intrepid Idles low and stalls...
  209. Engine Swap?
  210. solenoid pack
  211. Need help in aligning the timing chain in the Inteprid 2.7 engine
  212. Priced Paint Job
  213. Breaks?
  214. 99 Oil Leak
  215. 2000 dodge intrepid heater and air conditioner problem.
  216. 94 Intrepid Acceleration Noise
  217. 2004 Dodge Intrepid Engine Light & Oil Light
  218. 1999 2.7L w/Broken Timing Chain
  219. 94 3.5 tcm
  220. 2001 Intrepid SE auto door locks
  221. it starts with a bad miss and wont keep running
  222. odd idle problem
  223. transmission
  224. 95 3.5 tranny problem, Suggestions needed
  225. Need new brake pads... any suggestions?
  226. 98 Intrepid intermittent problem with headlights
  227. 94 intrepid
  228. My winshield wiper light won't turn off someone help please
  229. 2001 Rear Turn Signal Bulb
  230. 2001 Intrepid - Transmission slow to engage when cold
  231. how do i remove speed governor on 94 Intrepid
  232. 97 3.5 dodge intrepid
  233. red fluid leaking?
  234. Wheel Cover Noise, 2002 Dodge Intriped
  235. 1996 Intrepid Won't turn off..?? HELP??!
  236. swap a 2.7 engine in 2001 intrepid whith 2.7 2004 seabring
  237. green transmission fluid
  238. Down shifting problem
  239. Just a follow-up
  240. Remove Rear Door Panel on 2000 Intrepid
  241. 2.7 noise...
  242. 3.2 wont start when warm
  243. Parting Out 95' Intrepid
  244. Deisel sounding motor
  245. Just bought a 95 dodge intrepid..QUESTIONS!! Help
  246. Do intrepids fall apart at higher miles?
  247. starter replacement problems
  248. 94 intrepid electrical problem
  249. head lights and fog lights dont work but all others do how can I fix this?
  250. Parts age
