94 intrepid electrical problem
Tyb
12-27-2005, 07:29 PM
HI. I hope someone can help. My dome light, instrument cluster lights and gauges, door locks, windshield wipers don't work. I have checked the fuses and they are not blown but there is a few that get no power. I don't know if something happened to the power coming into the fuse block or if maybe it is something more simple. Thanks
scannr89
12-27-2005, 07:34 PM
those years were known to have bad ignition switches, local wrecking yard should have one and their easy to change
AWP9521
12-29-2005, 12:40 PM
Check for a blown fuse in the Power Distribution Box located under the hood, Ignition Switch may control the Gauges and Wipers, but not Door Locks, Dome Lights, or Instrument Cluster lights. But it is also a possibility that the Body Control Module may have gone bad or is not communicating through the bus as it does control the majority of those functions, a dealer should be able to check that out for you with the scan tool.
