Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Dodge
> Intrepid
View Full Version :
Intrepid
Pages :
1
2
3
4
5
6
nos?
won't start
dodge stoped intrepid
2.7 conversion to a 3.2
mod for dodge help me
Starting Problems
Shrunken window seals
Transmission Problems
need head for '95
1998 Dodge Intrepid smokes...
2.7L Engine Issues - Transmission too
noise when pressing x
Intermittent shuddering while driving
tranny out in 96' intrepid
New with a few questions...
Haze on inside of windshield
convincing it to start,or trying to
Electrical Problem in 95
1993 Intrepid powers out
CA: Looking for a 99-00 Intrepid, $50.
Dealer turned off my auto door locks
'94 Intrepid won't start
2000 intrepid Chirps
How reliable are the mid-late 90's Intrepids?
i hear a clicking while driving
1993 Intrepid Trans / Computer Trouble
Intrepid problems
intrepid performance
1994 Intrepid for sale! 77000 miles! $400
'99 Dodge Intrepid - Speed Senor(s)
transmission problem
Reset to Engine Computer?
2000 Intrepid initial problems - please help
A/C Problems, 99 Intrepid
99 Intrepid Idle Speed
Engine Control Fuse Short
Change of 1996 Intrepid battery
oxygen sensor
95 Intrepid 3.5L died - won't restart
Front Brake pad replacement
Intrepid 3.3L // no power at fuel pump
replacing battery cable on 97 intrepid
1999 Dodge Intrepid 2.7 Engine Diagram
'95 Intrepid ES 3.3L Fans run continously
1999 intrepid overheats - replaced everything so far.
Engine shutdown
2 of 6 coils are bad
2000 Intrepid starting problems?
1996 Dodge Intrepid brake problems
someone with a 99 intrepid, please help
2.7l
Smoking intrepid. Tips?
97 keeps blowing park light fuses
help changing the battery on 1997 intrepid?
locked myself out..
intermittent door lock problem
no start
2.7 1999 intrepid "BLOWED ENGINE AND ANYTHING MESSED UP THREAD"
hard to shift into gear
Intrepid Rear Noise at higher speeds
Mold in ventilation system
intrepid tranny pros
My 1997 Dodge is over heating
keyless remote for 1998 intrepid es
Installing 3rd party Remote Start
Spark Plugs
Shouldn't this be warranty work?
Programming keyless entry remote for a 2002 Intrepid SE
Please Help! My '95 Dodge Intrepid Is Overheating
'01 R/T has mushy brakes
AC causing engine to overheat?
Will a 2002 Dakota radio/cd player fit my 2001 Intrepid?
Undercarriage Clicking
air conditioning problem
1997 turn signal issue
Left Wheel Hub on 94 Intrepid
Rack Bushings How-To
Squeal from front passenger wheel (possibly brakes)
Stereo Volume
Auto Climate Control = POS???
2000 Intrepid 2.7 swap to 3.2?
Relay for my transmission
How To Change The Battery On 2000 Intrepid
keyless remote entry programming
What is Dodge going to replace the Intrepid with?
EGR Valve
96 trepid brakes
electric trunk release ?
Low Pressure Light Comming On???????
got a knock in the front end when turning
94 intrepid fans problem
Taking out stock Stereo
What Next!?!?!?
Unknown Engine Shutdown Problem - Help!
2001 Dodge Intrepid gas filter????
how hard to change the steering rack on a 93 interpid
Do you know of any good magazines for backyard mechanics?
ignition cylinder - 96 Dodge Intrepid
For Sale 1997 Dodge Intrepid
anybody experiencing problems with no oil pressure at idle - new rebuilt engine?
98 Intrepid Starter Problems?
If only I knew what was wrong...
94 Dodge Intrepid steering locks when air conditioner on
Installing new cd player. need help
limp mode cause and effect
Keyless entry option ?????
Chrysler Infinity Amp wiring diagram
How to find out if my fuel pump has stopped working.
Scratched up door plastic
Can a 3.3 replace 3.5 engine?????
running hot?? help!!!!! 97 dodge intrepid 3.5L
Looking for a Chrysler/Dodge CD player
'94 Eagle Vision Tsi - BIG PROBLEMS!
putting a 318 into one , is it a good idea?
HELP windshield wipers posessed!!!!!!!!!
95 Intrepid Radiator Fan woes!!!!!
89 Spirit with questionable issue
1999 Dodge Intrepid WONT START NOTHING
rev limiters
keyless remote 96 Eagle Vision
how to get the most out of 2.7 litter
easiest and best way to fix scratches and small rust spots
rear speakers sound bad? why?
'96 Intrepid... cold air intake
95 3.3L intrepid limp mode?
1997 dodge intrepid remote keyless entry
Replacing CV joints on 1997 Intrepid 3.5
2000 R/T 3.5 HO mileage
buying an intrepid and need advice from pros
2001 Dodge Intrepid Timing Chain Problems
'99 Dodge Intrepid Starter Problems
no heat
Starter makes spinning down noise after start
keyless remote 94 intrepid es
93 3.3/95 3.5 Tranny Interchangeable?
high speed hesitation/stumble with '93 Intrepid
No heat/no AC. BLower not working
Turn Signal indicators stopped working
Bleed brakes
Gas mileage went down
Intrepids Headlights
Dodge tranny fluids
93 transmition
Flashers buzzing
Battery or Alternator? Won't charge the battery...
Wireless Remote Programming for 1999 Intrepid
need a new 94 intrepid body
Question of power..
94 Intrepid not shifting
Costomizing my '98 ES
oil pressure sending unit
Looking for information on the 2.7 engines
BCMs & PCMs
2.7 Engine problem
Speed Sensor
Broken Tranny Questions
headlight ?s
1997 3.5l
Gear Swap
Heater and fan comes on by itself
Battery change-out
97 transmission in a 95 intrepid?
Keyless Entry - No Range
2004 Dodge Intrepid
98 Intrepid 4dr sedan..
96 Intrepid Brakes
Need help with under-hood noise
Questions regarding my '95 Intrepid
leak but don't know what it is
help!! neons!!!
Upgrade / replace your 2.7 with a 3.2
Wheres The Governor At?
Pulling to the left when breaking
heater core replacement
Head light have no power
Adding keyless entry
96 Intrepid Stereo Replacement?? Help!
Keyless Entry Programming - 2002 Intrepid
specs
Lookin for good performance parts
94 Transmission Replacement
Painting My Trep
progamming keyless remote for 1996 Chrysler Concorde
Intrepid R/T
Dodge Intrepid
2000 Intrepid Intake
A pimped out Intrepid
keyless entry for Intrepid
just smoked one last night?
Diabling Door Chime
how to program keyless entry for a 1998 Dodge Intrepid ES?
Engine Throwing a Rod
My car is for sale
Motor Noise
Weird Occurance in my Intrepid
shit
Can you replace the 3.2 w a 3.5 from a 300m??
Please help with rear speakers!!!
1993-1997 Intrepid Performance Parts!!!
Real HID conversion kits (German Parts) - Only $399
nEW HERE
Stalls
What mods are available for an Intrepid
Intrepid is loaded with style, substance
No Intrepid fans out there?
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
