1997 Headlight issues
charsangel
08-14-2006, 02:06 PM
I am not sure what it wrong. About 3-4 months ago, when I would turn on my brights, the lights would go off period. Now, my headlights dont work at all, brights or dims. We changed the bulbs, no change, so we talked to a good friend of mine who is a mechanic and he said it could be the delay, so we changed it and still no change. What else could be causing this??
KimMG
08-14-2006, 07:35 PM
Hi beam switch (stalk turn signal switch)
Linuxglobal
08-17-2006, 01:01 AM
check the headlight switch as well. But it sounds like the stalk switch for sure. I would look at the wiring harness as well. Sure sounds like a headlight relay tho. Check the interior fuses as well, you could have a short in the harness.
Also try www.dodgeintrepid.net, theres a larger community there and they may be able to even get u replacement parts for dirt cheap.
