96 intrepid engine tap
eaglesplyer66
01-07-2007, 09:33 AM
ok we know that it is the connecting rod bearing but we dont know how we can get it to go away. weve replaced the bearing numerous times and get the same results. how do we make it stop?? weve tried ovesized or undersized bearings (not sure of the termonology) and nothing works.
Thanks, neon guy 97
hundahunta
01-08-2007, 09:24 PM
is it a tap of knock, usually rod bearings will knock. Possibly the rod bore is out os round. When your replacing the bearings are you also checking the clearance on the rod bearings, whats the oil pressure at during idle?
eaglesplyer66
01-15-2007, 08:59 AM
oil pressure is fine but the crank i know is out of oe specs so what can i do?:banghead:
