View Full Version : LeSabre
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19
  1. 97 la sabre ruff idol after repairs
  2. Causes for bad mileage
  3. Odd drivetrain noise
  4. 1990 buick lasaber not starting
  5. AC question
  6. 93' lesabre wont start after going through big puddle
  7. 99 LeSabre Fuel Pump
  8. stuck rear wheel hub assembly, 93 lesabre
  9. Custom air intake.
  10. 96 Check Engine light on
  11. 95 Buick LeSabre Custom with Benz mirrors!?
  12. AC not working
  13. key lock problem
  14. 97 la sabre no power
  15. How difficult is to replace ECM?
  16. Engine swap? What fits in a 95 LeSabre Custom?
  17. VATS error
  18. Horns Inoperative...
  19. Is a 94 tranny a direct swap into 92?
  20. 93 lesabre steering problem
  21. exhaust?
  22. Making the SERIES 1 faster??
  23. Transmission Control Module
  24. Dynaride?
  25. Rapid Velocity Performance Module?
  26. 92 lesabre not starting
  27. Will washers mess my battery up?
  28. speakers?
  29. Radio Antena
  30. Harmonic Balancer Disintegrated! Is this normal
  31. 97 LeSabre horn, lights, locking problems
  32. Problem going into Drive or Reverse from Park when cold...
  33. electric problem with turn signals and reverse lights
  34. 94 Lesabre NO ONE CAN FIGURE OUT
  35. 95 LeSabre door panels
  36. 1997 lesabre that just dies out when driving
  37. car part
  38. 1990 Buick LeSabre
  39. Climate control for 1997 Limited Lesabre
  40. '94 ECM Replacement help
  41. 99 Lesabre engine hesitates at idle...
  42. 97 Lesabre: Poor Gas Mileage, Smell of Gas
  43. 1999 Cassette Radio/Cd Player Removal
  44. car audio system
  45. part location? Please help!!!!!!!!!!!!!!!!!!!!!!
  46. ECM Repeatedly Failing
  47. Dr. autoparts intake manifold
  48. Various questions.. door pillars, instrument lighting, dash paint, mirrors..
  49. catalytic converter
  50. Lesabre engine dies at odd times
  51. Rear brakes locking up?
  52. Crash
  53. Vents not working?
  54. 91 3.8 air conditioner question
  55. 89' Lesabre Buick need ideas
  56. 97 Lesabre Limited Shocks/Struts
  57. Lesabre stalls and wont start
  58. A/C vent problem
  59. 1992 LeSabre noisy ride !?!
  60. 90 LeSabre
  61. Autolite Plugs and Wires for Tuneup
  62. Front Motor Mount Installation
  63. Saefoam and plastic intake manifolds?
  64. 97 lesabre "Stumbles"
  65. 98 buick squealing
  66. Groaning Noise: Transmission, Engine, or Motor-Mount?
  67. Folding Rear Seat--92 Lesabre
  68. Brake caliper bolt hex bit size?
  69. 94 PS Loss Volt Light On
  70. Remove Stock Radio--92 Lesabre
  71. 95 LeSabre parking brake
  72. 1996 LeSabre, no start, no pw,ps,fuel pump
  73. 1995 lesabre wont start
  74. security light on at all times
  75. AC blower fan will not shut off...
  76. '97 Lesabre AC to Defrost: Vacuum Leak?
  77. When should the fan come on?
  78. New or Reconditioned?
  79. need a part for an 89 lesabre
  80. code 043 on 1988 buick lesabre. Help
  81. Rear Suspension???
  82. 92 lesabre electrical?
  83. 2001 LeSabre Bought from Carmax
  84. 1987 LeSabre Bent push Rods
  85. 92 lesabre AC Questions
  86. 94 Lesabre, Drive won't engage
  87. 90 LeSabre only starts sometimes
  88. How to lift up front end?
  89. How do I change whole engine?
  90. 92 Le Sabre Quits Running
  91. door pannel removal
  92. 1995 Buick Lesabre
  93. Climate Control Problems, 1993 Custom
  94. Internet or Shucks Radiator for 97
  95. 97 buick lesabre fan blower only speed 3
  96. 2001 LeSabre Sluggish Performance
  97. in need of mechanic
  98. 85 Buick Lasabre
  99. 97 Buick Lesabre keeps stalling!
  100. Codes 23, 26, and 39
  101. key cylinder
  102. '92 Water leak from under dashboard
  103. Noise from right side
  104. Stalls Out
  105. Radio Display and Dash Lights
  106. Car stops on hot days 90+
  107. Keyless Entry Trunk button disconnected
  108. 94 Lesabre Master Cylinder Warning
  109. Automatic Transmission Fluid and AC
  110. How to remove ABS system in an '89?
  111. changing the plentum
  112. 97 LeSabre vibration
  113. Rear Windows only work from driver door
  114. Climate control problem on '98 Limited
  115. 92 LeSabre non-ELC makes "whining pump noise" when braking
  116. replace plentum
  117. 97 Trans-fulid & filter change
  118. 97 Keyless remote
  119. 87 lesabre wheel bearings question
  120. 1992 Buick LeSabre won't start
  121. 1990 3.8 crank sensor
  122. adjust window on 98 lesabre
  123. 94' Lasabre, Speedometer problems.
  124. 93 Lesabre gas mileage
  125. 3800 series III in a 93 lesabre
  126. 95 Lesabre power window problems
  127. Dash pad seperation on my 2000??!!!!
  128. 91 3.8 bolt removal help
  129. ABS Light on dash
  130. Improved Handling With New Sway Bar Links and Bushings!!!
  131. 92 LaSabre Crankshaft position sensor
  132. 1993 LeSabre Info.
  133. 1990 LeSabre won't start!!!
  134. 1991 Trouble Code 41
  135. A/C = ECM troubles?
  136. hesitates under load
  137. 1995 Buick Lesabre blower
  138. R12 A/C top off - need help fast
  139. 1993 Bucking Up Hill
  140. HELP severe vibration and pulls to the right
  141. Coolant coming out on windshield
  142. Air Cabin Filter
  143. How vital is the air flow sensor?
  144. Exhaust cutout on 3.8
  145. vacuum leak?
  146. Gradual disengagement of cruise control
  147. Changing Fuel Filter '89 Le Sabre
  148. Replacing Temporary Spare
  149. What brand aftermarket keyless remotes is best/worse?
  150. 1992 Buick Lesabre...Turn signals not working?
  151. New problem
  152. Vacuum Lines / Hoses?
  153. 1992 power window problem
  154. Transmission Fluid Level, Gas Mileage
  155. heater button stuck on 93 lesabre
  156. Vent 1997 Lesabre
  157. Replacing Rear Air Shocks 00+ LeSabre
  158. 94 tire pressure
  159. posessed windshield wipers
  160. 98 lesabre info on pressure control solenoid PSC
  161. 98 lesabre need directions & pictures for replace intake gasket
  162. 98 lasabre trunk button
  163. Trans/Motor Mount
  164. 97 lesabre ltd edition poor AC
  165. 97 lesabre ltd edition poor AC
  166. Help again - Car wont start !!!!
  167. Brakes/suspension???
  168. Tires: What do you guys use?
  169. Radio Wiring Diagram Needed
  170. ’97 LeSabre A/C Compressor R&R
  171. 1994 electrical?
  172. SUPERcharging a 3.8 Lesabre!
  173. 93 Lesabre blower motor relay location
  174. Seems like it's flooding...
  175. 1992 Buick Lesabre PLEASE Help :(
  176. Programming Key
  177. Recirc button on blower not functioning
  178. rocker panel mounted to what...
  179. lesabre cabin air filter
  180. 97 Lesabre Dynaride
  181. '90 Lesabre CV replacement
  182. Wierd idle w/ AC at max
  183. Buick LeSabre Lexus ??
  184. Rough idle
  185. 91 LeSabre bouncing
  186. Testing Throttle Position Sensor
  187. Harmonic Balancer Rear drive Or Forward drive
  188. 2000 LeSabre noise in trunk area
  189. 93 LeSabre custom
  190. Speaker Replacement
  191. How much load on a cig lighter?
  192. Non - Mechanical Mods
  193. Struts: Aftermarket or OEM ?
  194. New Fuel Pump, not starting, Security, Check Engine, Clicking in Dash and Humming.
  195. Tranny Bolt
  196. 92 LeSabre misses and stalls
  197. 90 Lesabre......Need Help
  198. Air cabin filter replacement
  199. 98 Air Duct On Floor
  200. Help-removing Head light 1990 Le Sabre
  201. Help - Car Wont Start
  202. 1995 Lesabre turn signal replacement
  203. How to replace magnet for cam shaft sensor?
  204. 92 LeSabre short cycling A/C compressor
  205. 91' LeSabre window regulators
  206. "Recirc" button
  207. New shock obsr. from Autozone
  208. Stereo equalizer presets
  209. 94 lesabre starter relay location
  210. Brake alternative?
  211. 1997 LeSabre Radio swap Need Info
  212. 92 lesabre MAP sensor
  213. Warning - Power Steering
  214. 97 Lesabre Fuel Pump Fuse & Fuel Filter
  215. Driver side window replacement???
  216. 99 LeSabre Serpentine belt
  217. 95 LeSabre Temp Gauge
  218. 95 Lesabre Coolant Leak at Throttle Body
  219. 92 LeSabre blown brake line
  220. 2002 Buick Lesabre
  221. Electrical problems 91 Buick LeSabre
  222. 6-Way Power Seats
  223. 96 starts, stalls in 2 min (fuel pump)
  224. 00 lesabre
  225. 1998 struts
  226. '92 Lesabre starting and PCM issues
  227. Temp gauge
  228. electrical problem 95 lasabre
  229. Cruise control servo working?
  230. Oil Life Index
  231. 91' LeSabre needing some TLC
  232. 1995 Lesabre Horn Constantly Engaged
  233. Best Synthetic transmission Fluid?
  234. '89 Fuel Pump ?
  235. 1990 Lasabre Rubber Burning
  236. Incessant Dash Rattle
  237. Replacing O2 Sensor-'89 Le Sabre
  238. 1995 Lesabre Trouble Codes Redux
  239. How do you remove the hamonic balancer
  240. 3.8 timing chain rattle at low rpm
  241. 02 Lesabre Roaring noise
  242. 1990 Elec Window Problem
  243. 97 Lesabre engine swap
  244. 98 LeSaber. Want to jumper a/c switch to test
  245. 100K Tuneup for 1999 LeSabre
  246. Problematic acceleration immediately after heavy breaking.
  247. carburetor and bad idling
  248. Steering Reapirs Needed
  249. 1998 3800 series II coolant loss problem...again
  250. No Spark on 1 & 4 - Coil is OK - Now???
