Help again - Car wont start !!!!
ibelta
06-11-2006, 12:59 PM
Here we go again, replaced Fuel pump, car starts to run rough, change spark plugs - ok.
After two days, and after trying to see where from I loose water (good head gasket), suddenly, when car arrived to good temp, Check engine was flushing.
Turn end off, checked codes - none
rom that point on, no start!!!
Good fuel pressure, looks good spark (replaced wires as well), can't find nothing...
What to do?
Alibi
06-11-2006, 02:43 PM
Sounds like your ECM is bad. I had the ECM in my PA cause random stalling, poor fuel economy, bad idle, and ran waaaaaaay too rich. My guage clusters would randomly quit working and my SES light would come on...but no codes.
An ECM from a junkyard, or a PCM depending on what year your car is, is around $50...or Ebay works too.
BTW, you may wanna post the year of the car so anyone else can help diagnose the problem.
maxwedge
06-11-2006, 03:07 PM
What to do?
Basic diagnostics here, do the injectors pulse, will it start with starting fluid, strong spark to as many plugs as you can check?
ibelta
06-13-2006, 01:44 PM
As one of you said prev. BAD GASKET ON INTAKE!!!! THAT IS WHY I LOST WATER AS WELL.
Here is pocket damage:
$220 OEM fuel pump
$60 OEM Wires
$50 Spark Plugs
$250 Gasket set + Oil and filter change (plastic but metal ones cost double)
$300 Labour
Ouuch!!!!
