AIR DRIED BEEF DOG FOOD
97 Lesabre Fuel Pump Fuse & Fuel Filter
Sean Hindman
05-19-2006, 02:15 PM
Can anyone tell me where to find the fuel pump fuse and fuel filter on a 1997 lesabre? The manual i have is for several years and i've tried all the locations they suggested.
Thanks
LeSabre97mint
05-19-2006, 11:56 PM
Thanks
Sean
The filter is under the car, on the right side in the rear just in front of the the fuel tank. After much looking in my chilton I found the fuse # for the pump. It's # 6 and it's a 25amp. (sorry I couldn't find a location. If you have a vin I the pump is powered by a relay and then a fuel pump control module. Vin K just uses the relay which is shown under the hood under the cover by the firewall.
Do you have an owers manual? It might tell you the location there.
Regards
Dan
rustbucket
05-26-2006, 12:35 PM
On a 99, there are some fuses under the dash on the left (the easier ones) and also on the right. On the right side you have to take off the bottom dash cover. The label is on the cover. I think on mine there is a fuel pump fuse in there.
