View Full Version : LeSabre
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. I don't know JACK....
  2. Can you put motor in wrong that effects the transmission?
  3. need help
  4. Testing fuel pressure part 2 (97 lesabre
  5. 1995 LeSabre --snap,crunch pop sound when turning
  6. 1995 LeSabre oil light flickers when coming to a stop
  7. 95 Lesabre accelerates HARD under pressure
  8. 2000 LeSabre smells of gas after fill up
  9. 98 Lesabre, need help...
  10. Airbag light - 1995 Buick LeSabre
  11. How to tell if your vent is closing all the way?
  12. 98 lesabre dtc po446
  13. 2001 Buick LeSabre engine sputters
  14. 98 LeSabre - tires sliding
  15. 89 LeSabre stalling
  16. 93 lesabre - shudder and hesitation on acceleration
  17. stuck tourque converter 2001 Buick LeSabre
  18. 96 Lesabre 3.1 no run question.
  19. ABS reset?
  20. Dash Replacement
  21. wont start.. loud clicking
  22. 2002 rear shocks
  23. LIM what do you think
  24. TESTING FUEL PRESSURE 97 Lesabre
  25. How to tell if it's the MAF or MAP?
  26. 92 lesabre problem
  27. 97' Buick wont accelerate
  28. 99 LeSabre No Brake lights or rear turn signals
  29. Constant Engine Fan
  30. 95 Buick Lesabre A/C compressor bypass pulley
  31. 2002 buick lesabre
  32. Strut and shock change
  33. Need a new Buick
  34. Fuel Pressure Regulator Recall
  35. 2004 LeSabre Stumbles After Warm Start
  36. How to purposely blow a fuse
  37. sway bar to control arm linkage replacement
  38. seat belt problem
  39. Buick LeSabre 1993 hard to go
  40. rough running or RPMs goverened?
  41. heater core
  42. '98 Le Sabre Limited Turn Signal Question
  43. Buick 93 LeSabre Failed Emmision Inspection
  44. 94 LeSabre odd starting problem
  45. 97 Buick LeSabre turn signal problem
  46. LIM gaskets
  47. 89 lesabre climate control prob.
  48. 1993 Buick LeSabre running rough
  49. Exterior Air Temp Sensor
  50. 2nd ECM in one month.
  51. Help
  52. pressure testing radiator
  53. 2002 Lesabre seats don't recline
  54. Thermostat has one gasket or two? one rubber seal and one for the housing?
  55. 92' Code 58
  56. Brake Caliper Bolts
  57. 97 Lesabre stalling
  58. 2001 Intermittent start
  59. brake pedal going to the floor after my intake gasket job
  60. No btrakes on 90 Lesabre
  61. thud on incline 2000 buick lesabre
  62. IAT higher than ambient air temp
  63. Wrecked, Needing to replacing door
  64. 97 lesabre, two questions...
  65. erratic DIC on 2000 buick lesabre
  66. 2000 buick lesabre limited a/c on pass side only
  67. Shift Kit in 4T60e
  68. Engine Fan
  69. where should you hook up a pull chain 1998 lesabre or any other
  70. Fan Relay Location
  71. HELP!!! 02 Buick Lesabre Air conditioner broken
  72. A/C gremlin
  73. 95 Lesabre Horn has mind of its own
  74. 1998 pulled from stuck in sand now vibrates
  75. vibration during acceleration
  76. Radiator Cooling Fans
  77. 94 Lesabre EST not toggling
  78. Burnishing new brakes
  79. erratic DIC High Oil Pressure Reading
  80. Wheel lug nuts
  81. 2000 buick lesabre occasional transmission thud
  82. no cruise 97 lesabre
  83. 2000 buick lesabre
  84. Vacuum Hose Diagram
  85. '88 Lesabre - How many ounces of Freon?
  86. 98 LaSabre Noize
  87. 92 HVAC blower non-op
  88. 98 Lesabre Custom 2-3 Shift Solenoid Replacement help
  89. Tires wooble
  90. 97 LeSabre Oil Pressure Gauge and Hesitation when Hot
  91. Fuel Gauge Unreliable
  92. 92-96 lesabre battery trays
  93. 2002 lesabre blowing hot air on drivers side
  94. sanity check please for my upcoming UIM / LIM fix
  95. 97 Lesabre AC
  96. Coolant leak
  97. Just my luck
  98. 2000 buick lesabre wont turn
  99. 2000 Lesabre no power runs terrible
  100. 2000 lesabre relays
  101. 92 lesabre doesn't crank, power OK
  102. 97 Buick LeSabre - loss of power/transmission problems
  103. 5 amp draw in all conditions
  104. Transmission Line Presure
  105. 94 LeSabre Transmission Question
  106. Plastic piece that holds the smaller visor
  107. 1997 trans slip and boil over on highway
  108. 1997 Le Sabre no start
  109. AC not getting cold
  110. 94 lesabre stalling after crank and cam sensor replacment
  111. 94 LaSabre AC Problem
  112. 99 limited lesabre trany slippen
  113. 2001 Lesabre won't start - please help
  114. 1990 Buick Lesabre Custom
  115. Overheated
  116. cruise
  117. 1990 Buick lasebra dies while driving???
  118. Plug wire holder
  119. Update on the car and a question
  120. 99 Buick LeSabre Limited w/Performace Suspension
  121. 1997 Buick Le Sabre trouble
  122. No Start with Car that has Resistor already
  123. 97 Lesabre fuel pump question
  124. sudden loud ticking
  125. fuse blocks
  126. Air Handler
  127. A/C cycling on off
  128. 1997 Buick LeSabre Keeps Stalling
  129. 98 lesabre blower motor
  130. Oil Leak
  131. Rpm
  132. 2002 buick window
  133. Where is low pressure switch??
  134. Cooling fan
  135. Lesabre
  136. Tool set: SAE or Metric???
  137. '98 Lesabre CEL - Fuel/Air Mixture and Computer Issue
  138. Is there an ABS tool for my car??
  139. 1995 Lesbre stalling intermittently
  140. New Problems
  141. 2000
  142. 96 Buick Lesabre Squealing Noise. Please help! I don't know what else to do!
  143. Lights
  144. speakers
  145. All white lights out on the air control swich.
  146. '92 lesabre R12 A/C out of gas since a year
  147. Any way to do a "Reboot" on a computer?
  148. '97 LeSabre will not start; belt just twitches
  149. 1990 buick lesabre stalling help
  150. 2005 LeSabre Hazard turn flasher location
  151. '92 lesabre torx bit size for caliper mounting bolts
  152. 2001 Buick Lesabre - SEA FOAM info
  153. '92 lesabre oil change interval with local (low mileage) driving
  154. ? about the tire pressure sensor 2005 LeSabre
  155. Windshield Wipers Wont Shut Off
  156. Replaced the UIM after it died
  157. 3800 Series Stumper
  158. 93 Lesabre electrical??
  159. What to do to a used Transmission?
  160. Replacing Rocker Panel
  161. oil light flickers.
  162. 01 Lesabre - Correct fuel pressure
  163. 01 Lesabre emission system harness
  164. Glue repair for electric actuator
  165. Loose steering column at the tilt part
  166. How to access high mount stop light 2005
  167. 98 Lesabre just turns off
  168. 98 Lesabre just turns off
  169. 98 Lesabre just turns off
  170. Screen after the air filter has hole
  171. 94 Lesabre runs rough when hot
  172. 2002 drivers side axle shaft stuck!!!
  173. 94 Stalling, Bucking, Poor Fuel Economy
  174. misfire cylinder 6 2001 buick lesabre
  175. How to change the fuel filter
  176. Fuel Injector O rings - 2001 buick lesabre
  177. 01 Lesabre is gasping for air/fuel
  178. how much whte smoke is normal
  179. 99 Lesabre Custom: Trunk Release
  180. Easy question - which gas to put into 01 Lesabre
  181. 94 Stalls and Fuel Guage is Erratic
  182. question about 1993 lesabre
  183. 2003 Lesabre
  184. Questions about '04 LeSabre
  185. Brake booster?? catching, studdering, hard peddle
  186. Intake manifold 2001 Lesabre
  187. 2001 Lesabre - Throttle body removal
  188. 2001 Lesabre air shocks
  189. P0300 Code
  190. Buick LeSabre Transmission Fluid
  191. Power Window doesn't work when its Hot outside
  192. Transmissin Rebuild. Which manual?
  193. Lesabre 1998 High Mount Brake light
  194. What makes a Car run lean?
  195. Problem with code scanners
  196. Weird noise... "BUK BUK BUK"..."BUK BUK"
  197. serpentine belt
  198. Loud Thumb in the rear at low speeds
  199. CV Halfshaft problem?
  200. How much can my 95 Lesabre carry?
  201. 95 Lesabre engine noise.
  202. 1992 lesabre trouble code 17
  203. Taking off my air intake and antifreeze.
  204. 1995 Buick Lesabre
  205. Fuse for the fuel pump? 2001 lesabre
  206. Serious Shudder / Surging - 2004 LeSabre
  207. fuel pump
  208. Valvoline MaxLife DEX/MERC ATF - 2000 LeSabre
  209. 2002 starts inconsistently
  210. 95 lesabre a/c clutch issue
  211. Any way to put the Cruse light with the other dash lights?
  212. add on horn button
  213. serpentine belt replaced still not running
  214. no heat on drivers side in dual climate system
  215. 2000 Lesabre no power window
  216. 93 Lesabre Highmount Brake Lamp
  217. Solved the Problem with my 2002
  218. 2003 heater blower motor
  219. Security System won't start
  220. 94 Lesabre - Horrible Acceleration/Loss of Power
  221. Coolant loss stops
  222. 93 LeSabre - brown oily film in overflow jug
  223. MP3 auxiliary input on stock '04 LeSabre radio?
  224. Everything in car lighted and worked but no crank; then works again
  225. I think my Ignition Cylinder locked up. Need some help.
  226. 94 Stalling
  227. 2002 lesabre custom a/c problem
  228. 2002 lesabre custom vibration
  229. 2002 Buick acting up again ??
  230. Intake gasket failure
  231. 2002 LeSabre air shocks
  232. 2001 fuel injection
  233. Upper Intake Manifold on Series I and other questions
  234. 1995 Air Blend Actuator
  235. Head gasket is leaking 2001 Lesabre
  236. 1993 LeSabre Brake Vibration
  237. gas consumption increases after spark plugs & wires are changed.
  238. 92 Lesabre running rough
  239. 96 lesabre power is draining?
  240. Climate Control System Not Blowing
  241. Coolant Leak
  242. Voltage
  243. Changing Out Seats
  244. 2002 Buick sputters when excellerating ??
  245. 93 lesabre runs rough and stalling
  246. 1997 LeSabre, PLEASE Help, Automotive Nightmare
  247. FYI: 97 Lesabre tranny works in 92 IF....
  248. thermostat location
  249. 1995 battery change/HVAC fault question
  250. Heater Problem
