View Full Version : LeSabre
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19
  1. Help!! 92 Buick Lesabre Engine Is Running Rough
  2. 1999 Lesabre trouble starting
  3. 5W-30 in a Lesabre?
  4. 90 climate control prob
  5. ATTN: 1995+ LeSabre Owners with 3800 (L36 MOTOR PLASTIC INTAKE)
  6. 97 Buick La Saber - HELP ME !!!!!!
  7. Replacing radio in '94 Buick LeSabre Cusom
  8. replacing wipers on 90 lesabre
  9. 92 lesabre custom
  10. 92 Buick LeSabre resonator
  11. Injectors, no pulse on any of them
  12. Miles on the car...........
  13. LeSabre does not start
  14. LeSabre doesn't start
  15. Misfiring, now not starting, 94 LeSabre
  16. Misfiring, now not starting
  17. Dashboard Gear switcher
  18. Anyone know about throttle position sensors
  19. Radiator fan won't run?
  20. stiffen up ride
  21. Upgrade to automatic climate control - 2001 LeSabre
  22. 92 LeSabre K&N kit???
  23. 94 Buick LeSabre misfires
  24. 94 LeSabre with intermittent starting issue
  25. 1991 LeSabre Stalling In Traffic
  26. 89 3.8 runs for only a few seconds
  27. Another Window Problem
  28. tranny not shifting well.
  29. E-brake cable on 90 LeSabre
  30. 1999 rear struts
  31. 93 to 94 transmission swap?
  32. 1986 buick lasabre stalling
  33. Auto dimming mirrors
  34. 00 Lesabre - rattling sound - rt front
  35. Normal tire pressure
  36. 90 Lesabre won't start when warm
  37. 92 buick
  38. Fuel efficiency on '01
  39. Lesabre '01 brake noise
  40. 1992 lesabre
  41. cruise control not turning on
  42. '89 Le Sabre -Sealant for Small Oil Leak?
  43. Radio shuts off, heater shuts off,
  44. 92 Buick Lesabre Custom 3.8 just shuts off
  45. Air Bag Question
  46. 1989 fuel tank vent prob
  47. 92 lesabre
  48. 85 lesabre dies when going into drive
  49. Type of Scanner to use on 95 LeSabre
  50. Disconnecting rain sensors on wipers???
  51. Replace cam sensor and magnet on a '92 (3800)
  52. Detonation?
  53. 1993 lesabre spudders loses acceleration and stalls when less than a half tank of gas
  54. 95 buick lesabre tramission question
  55. It just died
  56. Ignition switch won't turn
  57. How to remove '90 Buick Lasabre door panels?
  58. 1996 Lesabre Water Leak
  59. 89 Lesabre Limited Dash Warning Lights
  60. 94 LeSabre Climate Control issue
  61. shudder felt in steering wheel
  62. 1993 LeSabre Oil Pump Installation
  63. valve cover bolts/nuts
  64. Do the 99 LeSabres have PCV valves??
  65. 1997 Speedometer and gauges
  66. Best way to Trouble shoot AC
  67. '89 LeSabre growling sound
  68. Muffler glowing red...
  69. Transmission jolt when going into R cold
  70. Pedal goes to floor after backing up
  71. 97 LeSabre Won't Start When Wet
  72. scan software/cable
  73. Do the brand of spark plugs and wires have to be the same??
  74. Wheel Help
  75. 1990 Lesebre Cruise Control
  76. new AC Delco plug wires worsened problem
  77. Oil filter alternative
  78. Decreased oil pressure
  79. 97 LeSabre power steering problem
  80. idling revs too high: upto 3500 at start-up
  81. Air Conditioner Problem 97 Lesabre Limited
  82. 1993 Buick Lasabre
  83. Low-volume whine/hum in '90 lesabre
  84. OK to replace fuel filter without de-presurizing?
  85. '87 LeSabre - Knocking-type noise
  86. Problem with rear Defroster
  87. 1990 LeSabre Custom - air ride compressor on after car is off!
  88. driver side wet part 2
  89. 1988 Buick LaSabre Hesitation when warmed up
  90. stalling when shifted into reverse
  91. Replacing Harmonic Balancer on '90 Buick Lesabre
  92. 92 LeSabre Radio & Climate control
  93. 1995 4T60E Electronic Tranny Problem
  94. location of pressure control solenoid
  95. License Plate bulb replacemet 02 Buick Lasabre
  96. Which to choose - compromise looks/power
  97. 1997 buick lesabre power steering pump pulley
  98. Radio Fuzzies
  99. R&R 3.8L Help?
  100. 1995 Computer?
  101. Buick Parts/Accessories Help
  102. first gear frustration
  103. Lesabre Blower motor only works at "high"
  104. no passing gear?
  105. ABS light comes on while driving?
  106. 2000 Lesabre brake noise problem
  107. 90 Lesabre CD player help
  108. 1986 LeSabre LTD problem
  109. Repairing Headlight '89 LeSabre
  110. Harmonic balancer replacement?
  111. 89 lesaber heating/cooling electrical control problme
  112. Tranny Flush
  113. 95 Lesabre Horn
  114. cure for bucking/dying??
  115. Ingnition spark is so weak - engine would not start.
  116. 95 Buick LeSabre Programming Remote HELP
  117. 1995 Buick Lesabre Remote Programming
  118. '97 Lesabre 21.6 Miles Per Gallon?
  119. 3.8Litre anti freeze leaking
  120. Gas Gauge
  121. Changing brakes on a 89 buick Lesabre
  122. 90 LeSabre cuts out on highway
  123. Buick lesabre 2003 second keyless remote entry
  124. Dead Lesabre
  125. 95 Lesabre Missing Severly
  126. 1990 LeSabre Dying
  127. 94 lesabre 3.8 intermittent no headlights/ gauges
  128. 1992 LeSabre cooling fan wire
  129. 1999 Buick Lesabre Tranny
  130. Noise from passenger side
  131. Location of turn signal flasher 1993 Lesabre
  132. LeSabre Raceing
  133. '89 sabre - static on radio while...
  134. '02 Lesabre won't start
  135. 83 lesabre dead cylinder HELP!!!!
  136. are all 91 Lesabres rust buckets??
  137. "91 Lesabre speed sensor?
  138. 2003 LeSabre Keyless Entry Programming
  139. Mp3 player
  140. Electrical ??
  141. Location of Fuel Pump Fuse
  142. 97 LeSabre Electrical Problem
  143. Lesabre Wiper motor
  144. 2001 Spongy Brake Pedal (Bleed ABS unit)?
  145. EGR valve melting
  146. 1992 LeSabre Front Speaker Removal? Help!
  147. 1992 Buick LeSabre Alarm System
  148. 97 lesabre driver side wet
  149. Fuel Filter
  150. 95 Lesabre Massive Oil Leak
  151. 2003 oil filter location
  152. Relocating Fuel Filter
  153. Changing Oil Pan Gasket
  154. 97 shifting issues
  155. 1991 LeSabre Driver Door Panel Removal
  156. 94 LeSabre Custom Trans has issues
  157. Security light problem.
  158. 93 Lasabre wont start
  159. 1994 Buick LeSabre tranny
  160. heater controls help
  161. Loud ticking (knocking) from under valve covers
  162. 95 buick laSabre driver window question
  163. Front Struts on 98 LeSaber
  164. 83 LeSabre 45MPH stall
  165. reverse lights
  166. ABS light
  167. front speaker removal for a 94 LeSabre
  168. Heated seat not working!
  169. trany problem
  170. Bad computer? Vacumn Leak?
  171. 1970 4dr w/ vinyltop...any pointers are wanted
  172. Headliner falling down.
  173. 94 LeSabre check engine light, codes not retained
  174. Possible Camaro / LeSabre Intake Retro?
  175. '92 lesabre check engine light randomly appears
  176. Aftermarket Warranty Coverage Suggestions
  177. The problem keeps repeating itself
  178. Ignition coil question
  179. power steering pump
  180. Low Brake Pedal on 2001
  181. car running rich
  182. '91 Limited TCC solenoid replace
  183. suspension type
  184. electrical prob. again
  185. '89 lesabre - what fell off my car?
  186. how to change 96 LaSabre serpentine belt
  187. lack of power 2002 buick lasabre
  188. 1989 Buick Lesabre sensor switch
  189. Wont start
  190. 3800 V-6 olds 88 lss 96 tc light and misfiring again
  191. Service Engine Soon?
  192. Oil smell
  193. i think its the speed sensor
  194. Where is the DLC on 1989 Lesabre
  195. Windows work when they want, why?
  196. Program Keyless Remote 97 Riviera
  197. 99 LeSabre Power steering pump bolts
  198. 1998 loss of power please help
  199. My 88' LeSabre is shaking bad!
  200. car dying
  201. 93 Lasabre Water Pump
  202. 2000 Limited wiper problem
  203. wrong pins connected
  204. Engine dies
  205. '85 with 307
  206. Rod Knock
  207. need more mpg help
  208. 94' LeSabre Window Problem
  209. Headers for 76 lesabre
  210. 2001 How can I decode or reset service engine light?
  211. 92 wipers quit
  212. 86 buick lesabre tranny problem
  213. puzzled... occasional bucking at 45-50mph
  214. 1994 LeSabre Interior Light Stay On
  215. 96 leSabre 3.8 High Idle
  216. 2001 Limited Left Front Noise When Cold
  217. alarm sets off - is that my fault ??
  218. 94 Lesabre radio removal
  219. Windshield Wiper/Fluid "Y"
  220. New ground wire for blower motor
  221. 2001 Buick FSM
  222. Engine Air rush noise heard following start up
  223. buick remote entry problems
  224. Engine Miss/Noise
  225. 98 lesabre throttle body cleaning
  226. buick won't start cold
  227. Front Strut w/o spring guard
  228. Rear O2 Sensor, what is it for?
  229. Denso O2 Sensors, anyone use them
  230. 1995 LeSabre Climate Control malfunction
  231. 1990 Buick Lesabre
  232. Rear Disc Brakes
  233. New Cold Start ?
  234. 98 Lesabre heat/ac control unit lights
  235. 1995 LeSabre Tail Light / Dash Light Problem.
  236. 1994 le sabre coded p1640 qdm circuit malfunction?
  237. limp mode
  238. 60 Buick
  239. tightening battery terminals
  240. 2002 LeSabre loose gas cap warning
  241. 98 Lesabre O2 Sensor
  242. 1992 with tranny leak
  243. engine removal
  244. 2000 buick lesabre door panel removal
  245. Buick Lesabre Hard start after sitting Always!
  246. O2 sensor
  247. spark plugs
  248. 1997 Buick Lesabre Check Engine Light on
  249. 2002 Lesabre Air Shocks
  250. problem buick lasabre
