View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29
  1. Help desperately needed on a 95 WS Tranny problem.
  2. Sea foam.............
  3. 96 windstar transmission
  4. Alarm Problems
  5. 2000 Windstar with no speedometer /odometer and problem codes
  6. Fuel Error
  7. 95 Transmission clicking noise?
  8. 96 Windstar won't quit running
  9. Intermittent ABS Light
  10. loud squealing/screeching noise 98 3.8L
  11. Power Door Lock Actuators
  12. Short grinding noise after startup
  13. Cruise control not working & Airbag 32 light
  14. 1999 windstar...should i buy?
  15. 95 windstar tranny
  16. 99 Windstar both pwr window switches don't work...
  17. Inner tierod ends 96 Windstar
  18. Subframe Bushing weld
  19. Airbag Light and Fuel Gauge
  20. '95 Windstar back window
  21. Accelerator Pedal Vibration / Buzz
  22. 96 windstar (front brakes)
  23. 99 Transmission work
  24. cam synchronizer
  25. 2002 Windstar radiator drain plug location
  26. 96 Windstar Loud Engine Knocking
  27. which repair manual is better?
  28. clearing codes for 00' windstar 3.8..mass air and egr
  29. O2 sensors in 3.0 litre engine
  30. P1405
  31. broke down...not literally
  32. rotor removal: need help
  33. 96 Windstar CO code
  34. Fuel Injection system cleaning
  35. 2002 windstar lx
  36. '01-ABS & Brake dash lights
  37. 96 Windstar stalling problem
  38. Windstar alignment
  39. IMRC valve needed
  40. 99 Windstar
  41. fuel filter surprise....
  42. P0172 and P0175 codes
  43. 99 windstar dash lights
  44. Which Plugs and wires to use for 2000 3.8l
  45. 98 check engine light on
  46. Idling issues and dying on Windstar
  47. Outside Tempature Reading
  48. 99 Windstar. Where does the plug go?
  49. Transmission Problem.
  50. Straining/Moaning noise between 4500-5500 rpm.
  51. anyone who has replaced there 98 synchro
  52. Confused about spark plugs for '99 3.8L
  53. $168 for new Key w/chip anyway to disable alarm
  54. Codes P1537 & P0172
  55. ABS - Sensor
  56. Strange Brake Pedal Noise
  57. 98 GL 3.8 - Brake light on dash appears for a few seconds then disappears
  58. Cabin Blower Fan Speed Dropping Resistor
  59. 02 Windstar power window/lock switch
  60. P0401/P0402 Codes - Help needed
  61. 1998 Windstar Cigarette Lighter / Power Outlets
  62. 98 Windstar IMRC ( manifold runner) $$$$$$
  63. Questions on Isolator Bolt Fix
  64. Windstar Codes?
  65. 99 Windstar, 02 sensor
  66. 01 Windstar Sport Driver's Power Seat
  67. Spark plug removal ruin heads?
  68. Poor fuel economy
  69. 2000 Windstar, burning smell, grinding!
  70. 2000 Ford Windstar 3.8L Serpetine Belt Routing
  71. Door locks don’t work??--I fixed mine!
  72. 2000 Ford Windstar Intermitent no start/theft flashing
  73. 95 Ford Windstar aux a/c blows warm air
  74. 1996 Windstar code P1151
  75. 99 Windstar is kaput, anyone seen this before?
  76. upsetinmo
  77. how to clean ABS sensors...?
  78. 97 Windstar... slew of problems
  79. Obtained fault codes P1512 and P1538
  80. Oil deposits in the thorttle body
  81. Coil Spring breaks, Free Replacement!
  82. Stalled on highway
  83. Windstar Gauges
  84. Front A/C warm Back A/C cold
  85. '97 Windstar GL ABS actuates rear brakes when stopping
  86. Please help
  87. 02 Windstar Autolock
  88. Engine/Tranny Vibration
  89. 2001 Windstar stalling!!
  90. car elec. cuts out
  91. 96 windstar electrical problem
  92. '99 Windstar Injectors
  93. amsoil?
  94. 2000 Windstar O2 sensor
  95. Brake light on and fuel pedal out of order after HG changed
  96. Front end clunking noise with ABS light on
  97. Driver window won't go up
  98. thoughts??
  99. Buying 00 windstar what to look for
  100. easy transmission fluid change
  101. Super hot air blowing from rear lower vents with ac on
  102. Vibration from Fan
  103. 99 windstar
  104. Coolant Drain for the '99 Windstar
  105. Air Filter and A/C
  106. 95 Windstar transmission slips from 3-2
  107. '99 windstar sel (3.8L) radiator cap?
  108. Drop in Fuel Mileage
  109. Hard Shift 1-2 in 99 Windstar
  110. Mercon V
  111. 1998 Windstar Dash Lights, Parking Lights, passenger window not Working
  112. 95 windstar 3.8 p0302 code
  113. 2000 Windstar won't start
  114. Alternator cable melted - how to replace
  115. 98 Battery/Alternator Issue?
  116. Note on ABS or wheel speed sensors
  117. Motor Mounts and Transmission mounts
  118. failed emission test/ p171 &174
  119. water leaking from under the engine area
  120. Slight squeeking noise from left front end 2000 windstar
  121. A/C Need recharging???
  122. '99 Windstar Brake Squeak
  123. 2003 P1406 code
  124. Spark Plugs
  125. 02 Windstar LX
  126. mysterious electrical outlet
  127. Belt Questions
  128. Windstar 2001 spare tire
  129. hidden "color-code"?
  130. '99 Windstar Front End Noise
  131. 2000 Windstar runs rough/Check Engine
  132. can additive make trans fluid Mercon V?
  133. 1999 windstar - tranny leaking?? help(94,000miles)
  134. '96 problem Code P1151
  135. code 0185 & airbag light on, dashboard vents
  136. AC Parts ///anyone parting out a 95-97?
  137. Windstar Code P0460
  138. Code 1156 ?
  139. windstar AC Problem
  140. Another Transmission Cooler Post
  141. brake emergency
  142. Floor Covers for Seat Mounting Openings
  143. What is this part???
  144. What is this part???
  145. How Bad Is the Windstar Tranny?
  146. ABS and TRAC OFF problems
  147. Leaking After 171 Fix
  148. SES light a No Show!
  149. High idle
  150. Transmission Filter
  151. Shifting to park drops RPMs
  152. 2001 Windstar Abs And Brake Light Goes On
  153. Dumb Question Prior to 0171/0174 Fix
  154. Strange Problems with ABS in 97 Windstar
  155. 98 windstar towing capacity
  156. abs diagnostic plug??
  157. Overfill you Tranny?
  158. Slipping between gears-2 trannies!
  159. 95 windstar air springs
  160. 3.8L 1999 Windstar Purchase Checklist
  161. 1999 Ford Windstar SEL Leaky PCV Tube
  162. 97 windstar tranny question
  163. How easy was the P0171/P0174 fix for you?
  164. 171/174 code fix issues
  165. Fixed Stuck Fuel Gauge
  166. 96 Windstar, can't put on new drum!
  167. P1401
  168. grinding sound then ABS light
  169. Instrument Cluster problem
  170. Rear Power Door Won't Close
  171. Coolant pipes
  172. 99 steering question
  173. A/C Hot and Cold
  174. Power Steering leak....help!
  175. Flashing CEL P1538 AND P1513
  176. 1999 Windstar Auto Sliding Door
  177. ABS light on and off with a "clunk"
  178. Opinions Needed: P0171/P0174 - Ebay Kits
  179. Gear Shifter Rattling
  180. Right rear turn signal
  181. 2001 Ford Windstar giving code 0183
  182. Tire Warning Indicator Light
  183. 2001 Windstar - Rough start, sometimes will not start at all
  184. ? Constant wobble sound, shake at high speed
  185. 95 Windstar a/c electrical
  186. Replacement brake pressure switch
  187. 2000 Windstar Won't Start, Gauges Flip, Lights Flash
  188. Cel P0156
  189. lamp out indicator--1999
  190. 98 Windstar Hard Brake Pedal
  191. Where is
  192. Oil in the intake and catch can
  193. like fingers on a blackboard
  194. 200 Windstar:Turning Steering Wheel Revs Engine & Idles @ high RPM
  195. ABS light and code on 99 windstar
  196. growling/moaning noise in 99
  197. 1998 Windstar Towing Package included what components?
  198. Stuck Fuel Gauge
  199. '98 Windstar IMRC P1537 P1538 P1513
  200. Suspect valve
  201. ignition (key)
  202. engine noise
  203. What is Best Brand AX4S Trans Overhaul Kit to buy ?
  204. ABS Comes on at 70 MPH - 98 windstar
  205. Rear AC Blowing hot air.
  206. No throttle response
  207. Drained Battery
  208. Door Ajar/Interior Light/Urgent Help!!!!!!!!!
  209. How to remove wiper arms
  210. 99 winny
  211. P0304 after restarting
  212. overdrive-wrong fluid?
  213. Auto sliding door & trunk
  214. Windstar FAQ's -- Let's Gather 'em Up!
  215. Update on windstar electrical problem
  216. ABS light and check engine light 2000 Windstar w/codes
  217. Intermittent dashboard Battery Light
  218. Transmission low to intermediate servo
  219. Completed mechanicals for P0171 - Do you need to perform WSB B26.2 PCM Update?
  220. '96 front coil springs
  221. Unusual question about fuel system
  222. sliding door cable
  223. 03 windstar trany
  224. 03 windstar trany
  225. I'm moving.
  226. 1999 Windstar LX Transmission goes "WHAM" into drive then nothing except reverse ??
  227. 95 Windstar Tranny- Just got codes, plz help!
  228. Windstar 99
  229. intermittent wipers
  230. abs power relay
  231. roof racks for 2002 windstar lx
  232. 1996 windstar stalling and not starting
  233. Champion spark plug: Copper plus vs Platinum
  234. Damage caused by constant battery drain?
  235. '99 Windstar AutoLocking
  236. 2000 Windstar side door lock
  237. How to program a keyless remote.
  238. abs light comes on after a couple of minutes
  239. 2001 vs 2003 wheel dia.?
  240. Rough Idle on 2000 Windstar
  241. abs and trac light
  242. abs and trac light
  243. front Brake Rotors
  244. How to replace the power stering pump?
  245. P0171/174
  246. 2000 Windstar electrical problem
  247. A/C problem
  248. Front cover removal tips ?
  249. Green brake fluid?
  250. 2000 Windstar belt diagram
