View Full Version : Jetta/Vento/Bora
Pages : 1 2 3 4 [5] 6 7
  1. supercharge or turbo
  2. Torbo mod. for VR6
  3. circuit breaker for door locks, sunroof, etc.
  4. Washer Pump Replacement?
  5. Any advantage to using VW oil filters?
  6. Jetta Question
  7. Cat back xhaust?
  8. question please helpppp
  9. battery scam?!?
  10. onboard computer?
  11. TDI Stalling/ODB Bypass
  12. Why no beep when locking doors
  13. simultaneous Stereo, cig lighter, and trunk malfunction
  14. battery in my key
  15. Lowering springs vs Adj. Coil-overs
  16. stock stereo and engine diagnostics
  17. The new guy has a newb question
  18. slow accell./ stall when engine warm
  19. Check Engine light HELP
  20. is jetta and bora the same ???
  21. A2 trim parts
  22. Fuel Gauge and on board computer read outs not working
  23. Terrible Mileage - Spark Plugs???
  24. water in oil? how
  25. props for the vr6 t
  26. Need help installing a cd player
  27. oil in spark plugs
  28. Jetta Power Steerig Fluid?
  29. A/C bulb out, how to replace?
  30. Up 4 SALE!!!
  31. Rebuilding a 91 16V 2.0
  32. Jetta hesitation and stalling on startup.
  33. Starter on my 94 jetta
  34. Mod Chip
  35. Question
  36. electrical issues with trunk.....
  37. Can U fit a rotary into a jetta body?
  38. jetta backfires under load
  39. Won't start/stalling
  40. Tool Help
  41. power seats, climate control
  42. Brake Replacement
  43. jetta battery/replacement issue Dealer Rip-off?
  44. wipers died
  45. Door lock/arm circuit
  46. Doors locking/alarm setting itself!
  47. searching for a vr6
  48. need your opinions
  49. How depressing? Besides problems does any here have modified Jettas?
  50. Sun visor
  51. Warranty
  52. Timing Belt/Bent Valves
  53. New Jetta Forum
  54. tail lights
  55. Relay Pannel
  56. Please help
  57. 2 quick questions please
  58. Need recommendations on rotor upgrades...
  59. odo/speedo problems when changing wheel size
  60. FS: Golf conv. w/CF Hood!!!
  61. Told my uncle I would help him with his Jetta, now I need your help guys !
  62. Ebay remote keyless, Is it worth it?????
  63. was I robbed or what!!??HELP!!!or is this typical VW service?
  64. Jetta Superchargers
  65. Lighting question, Is this possible
  66. epc light
  67. Weapon R Dragon Intake for Sale for VR6
  68. VR6 Engine Knock
  69. cap and rotor replacement
  70. jetta stumbles on acelleration
  71. Oxygen sensors????
  72. dash configuration question
  73. battery problems
  74. Which Car
  75. cooling fan not working
  76. $775 for 40k maintenance work?!?!?!
  77. cold start/alarm
  78. Engine Swap
  79. jetta rear map light removal
  80. help im 16 and need ideas for jetta 2.0
  81. VW Noob
  82. FS: Autometer Boost Gauge
  83. FOR SALE: 17" aluminum wheels and tires
  84. burnt smell
  85. Turning in leased Jetta and being charged $500 to turn off the check engine light
  86. Code: 1165
  87. code P1128 from CE light on 2001 Jetta GLS
  88. Check Engine Light went off after battery died
  89. Automatic - won't go to gear
  90. Check/fill plug on MKIII manual trans
  91. To buy 02 GLS or not to buy....
  92. New Car
  93. jetta reliable?
  94. Speedometer and Tachometer problem
  95. Help, buying car!
  96. Help, buying car!
  97. Can't unlock door: HELP!!
  98. stock stereo removal in MK4 Jetta
  99. 1.8t swap info
  100. Leaking water
  101. XM Radio Question
  102. Remote Starter Question
  103. trunk button and cruise control
  104. Wheels....
  105. V belt
  106. Jetta Running Issues
  107. Jetta III Dash Speaker
  108. FS: Headlight housings and HID's
  109. What icon represents the radio fuse?????
  110. Audio Q's, Remote Starter
  111. Sylvania SIlverstar 9007 Not white enough...
  112. A2 transaxles
  113. Check engine lieght
  114. Wanted!!!Wings West commando wing/spoiler
  115. VW Jetta headlight problem
  116. Alert!! VW owners, asylumms.com bad news, fakes
  117. Kamei grill questions
  118. A/C not working all the time
  119. block heater jetta 1.9 Tdiesel
  120. Installing new radio w/o Alarm problems 95 Jetta
  121. I need a hand book, and some other ?'s
  122. round headlight size
  123. Installing HID kit on 00 Jetta
  124. Gas flapper
  125. Turboeing 8V 1.8 MKII Questions
  126. key in ignition and door open jingle
  127. Engine check light & emissions test
  128. Thermostat light Blinking and not stopping
  129. Turbo 8v from a TDI
  130. Dont know how to use my Cruise Control
  131. Dont know how to use my Cruise Control
  132. hey I have question
  133. Jette 1.8T What Can I do with it?
  134. Odd electrical problem?
  135. Where to buy a 1.8t engine?
  136. Why do you all rag on VW realiability?
  137. A/C not working
  138. How to enter radio code
  139. Fuel Filter Replacement
  140. Anti-theft stereo activation codes?
  141. Light
  142. Issues installing Remote Start
  143. brakes
  144. Oil Leak
  145. jetta diesel and glow plug..
  146. Remove ashtray cover and/or center brake light in MK4
  147. Coolant Jug - wiring
  148. Hot jetta tips
  149. radio stays on without key?
  150. "Check engine" light for a year
  151. p-flow or k&n panel filter
  152. Looking for 91 Diesel Engine for my Jetta
  153. Turbocharging Jetta
  154. airbag- airbag light????????
  155. Knight Performance
  156. electrical failure
  157. windows, door lock and sun roof sim
  158. Red Foot Warning Light
  159. need to make an engine swap. HELP!!
  160. Cruise control and high beam problems
  161. vibrating noise from front end
  162. Can u fit 19" wheels on a 2001 Jetta
  163. the best short shifter...which one?
  164. Won't Start
  165. Jetta Grills???
  166. Rough idle and rough at low RPM
  167. Jetta Trek Headlamps
  168. turn signal problem? help plz.
  169. Thinking of buying a Jetta
  170. advice on a after market muffler
  171. warning lights - what do they mean?
  172. Jetta 17" rim and seat cover
  173. i need help with my car
  174. the fast and the furious jetta
  175. i need a stock 95-98 vr6 exhuast
  176. new to jetta seen looking for advice
  177. New VWsites.com is up
  178. remote starter jetta diesel
  179. selling my jetta gl $6,000
  180. Dtm Euro Spec Parts F/s !!!!!!!!!!!!!!!!
  181. catalitic converter gone bad!
  182. I need some help with engine code....
  183. Secret switch on wheel controls?
  184. im 15 and am lookin at a jetta
  185. any 1.8t jettas here with chip?
  186. Suggestions: Sport Clutch?
  187. Headlight upgrade kits
  188. VR6 Pro Parts Must sell Cheap!
  189. question about the speedometer
  190. Headlamp Problems
  191. Installing Fender Mounted Antenna on 95 Jetta?
  192. wolfsburg vs. rsx-s
  193. The Wolfsburg question!
  194. i love these answers!!! wooohooo :banghead:
  195. I need Help PLEASE! 99 Jetta
  196. Plug Wires
  197. tdi
  198. removing heated leather front seats
  199. 2.0L nuespeed supercharger
  200. Which models came with rear disc brakes?
  201. Fuel Door not Closing
  202. oxygen sensor
  203. should i keep my jetta?
  204. Wind resistance whistle 2003 Jetta GLX
  205. SUper Jetta on EBAY
  206. where can i get a turbo timer harness
  207. in search of a discontinued wheel
  208. Got the wshhhhh, where is the pssst
  209. Help!!
  210. 4 toys for Trade for some new ones
  211. hooking up an AutoMeter tach???
  212. Jetta shift linkage
  213. Gas Filter
  214. Recalls on Jetta III
  215. new jetta
  216. What turbo do i have?
  217. 94 Jetta with Problems at random starting...
  218. need help
  219. 17" Borbet Type T wheels for sale
  220. Jetta On 18"
  221. Monsoon Sound Sytem...what do you think?
  222. Problems checking the AT fluid level
  223. diesel or gas
  224. Performance Parts
  225. VR6 MOTOR FORSALE! ONLY 40k! AND MUCH MUCH MORE!
  226. 1.8t questions
  227. Sunroof Track alignment/ cruise control
  228. plz help.. random stalling on 96jetta
  229. Check Engine Light and the flake temp guage
  230. What should i do next, i need help!
  231. Handling problems
  232. Why doesnt my mechanic like VW's?
  233. Eibach Sportline Kit
  234. Just ordered my new toy!
  235. A3 Jetta Exhaust
  236. codereader for OBD1!!
  237. engine light on!!! NEED HELP
  238. Are these guys yanking my chain?
  239. How do you tell if it has monsoon
  240. 1.8t vs v6
  241. Disable the daytime running lights??
  242. compatable cd changers
  243. how do u ?
  244. Invoice price vs. negotiated price
  245. Changing tail light bulbs
  246. almost big problem
  247. Jetta Alarm problem
  248. Jetta or Eclipse
  249. Flushing fuel system?
  250. Interior Help
