View Full Version : Jetta/Vento/Bora
Pages : 1 2 [3] 4 5 6 7
  1. Two mufflers???
  2. Jetta Mk2 problems..
  3. speed sender?
  4. Error codes P0763 & P0715
  5. Suggestions for jetta mods.
  6. How hard is it too do this???
  7. need advice on motor oil selection
  8. cabin air filter/pollen filter
  9. Jetta aircon cutting in and out
  10. Jetta a kids car?
  11. Bumping noise when braking in reverse
  12. Rattle noise with reving
  13. fuel rail clicking
  14. Transmission
  15. Help with Roof-Rack
  16. uneven braking on Jetta III
  17. engine light goes off now what?
  18. Water Neck Leak at the head...
  19. Code p1142
  20. Yyyyyyyeeeeeehhhhaaawww!!!!
  21. Need help?
  22. Vibration in brake pedal
  23. Tranny Gone
  24. Flashing Check Engine Light
  25. Need Help - CD Changer error message - "NO DISC"
  26. Scan Tool Help Needed
  27. heelo everyone
  28. 17 inch wheels?
  29. newbie with clutch issues
  30. Painting
  31. gas mileage questions?
  32. Timing mark question??
  33. Code P1128
  34. remove manual window cranks
  35. another jetta ? on power steering
  36. Anyone know some one sellin a Jetta?
  37. MK2 cheap power trick
  38. Finding Top Dead Center
  39. Rattling in Jetta 2004
  40. newbie:struts info......
  41. overheating engine
  42. Oil smell through vents
  43. Manual transmission failure.
  44. Jetta CD changer
  45. New Jetta owner questions
  46. performance
  47. AutoCross
  48. Airbox silencer/snorkle question
  49. Smelly Heat
  50. Cost for new brake ?
  51. how's a jetta as an ideal project car?
  52. Cruise control problem
  53. Inaccurate Fuel Indicator
  54. CV Pronblem?
  55. Need Instructions on how to replace a strut bearing!!! Help
  56. Engine Idles Great, then Dies...Help!!!!
  57. Electrical Mystery
  58. Smoke!
  59. knock sensor problem
  60. What exactly is my car?
  61. Turn Signal issue
  62. fS: Mk2 sinlge round head light set up
  63. Electrical..
  64. Vw Incompetence!!!
  65. I have a short??? or wiring problem with windows/door locks
  66. Accelerator hum after hwy drive on 2004 Jetta
  67. Camshaft Position Sensor
  68. Reset Airbag memory
  69. Wiring problems?or Short?
  70. Question about Jetta reliability/problems
  71. Parts ID Question - VR6 Jetta GLX
  72. roof rack
  73. master cyl. losing fluid, no evidence of leak
  74. weird noises
  75. 1296 Air fuel metering code
  76. What is the best way to get rid of AC mildew smell in MKII Jetta?
  77. fast idle- need help!
  78. Anti-alarm, Key,Relay
  79. Keep blowing fuses part III
  80. Stolen Valet Key
  81. Car Doesn't Start(intermitent problem)
  82. Jetta IV VR6 manual shifter lash
  83. Jetta IV VR6 SRS light on
  84. Jetta IV VR6 throttle control issues
  85. Forced Motion/GHL Stainless Steel Turboback Exhuast And Altezza lights For Sale
  86. Speed Sensor/Odometer/Fuel Gauge
  87. Keep blowing fuses part II
  88. Could this be a strut problem
  89. please advise immediately - gears stuck in park - cannot shift gear!
  90. ignition coil???
  91. heater core or a/c
  92. Air Bag Replacement...
  93. AC Switch
  94. Check Engine Light????
  95. need help ASAP!!!!
  96. Speed Sensor
  97. Proportioning Valve Bad?
  98. turbo or supercharger?
  99. Back Seatbelt
  100. Is Jetta good to buy
  101. Brake and CD changer problems
  102. Tires anyone??
  103. how can i get a code for a jetta i just bought
  104. Jetta III GLX for sale
  105. VR6 Timing Belt or Chain?
  106. rotors and brake pads - help
  107. Customization Ideas
  108. Transmission Speed Sensor
  109. have shell...need power :P
  110. Electrical Problem
  111. HELP!!! Battery connected backwards!!!
  112. Where can I find a high output Alt ?
  113. steering leak
  114. No power to starter, but it does work
  115. nuespeed chip
  116. Alarm, Speakers and Cold Air Kit Questions
  117. buzzer alarm
  118. Radio Issue
  119. Was my engine swapped before i bought my car?
  120. Anybody in Utah, if so listen to this!
  121. catalytic converter? please help!
  122. Can't remove the starter
  123. AC leaks water in car
  124. race springs
  125. door wiring question
  126. New generation airbags decrease cost
  127. Useful info for all VW owners..
  128. body kit question
  129. Angel eyes on mk4 jetta
  130. Customising Jetta
  131. Newbie
  132. is my jetta christine?crazy electrical
  133. carfax help please
  134. battery replacement
  135. Steering wheel sticks when it rains, drivers side lock broke,amongst other problems.
  136. car help book
  137. carfax
  138. Electrical Problems
  139. speedometer cable replacement
  140. Replacement Grill...
  141. What should I expet to pay for Tranny work?
  142. Please Help Need Engine Removal Help
  143. air in fuel line
  144. Malfunctiion Indicator Lamp (MIL)
  145. 98 jetta stalling out
  146. Buying Jetta?
  147. control temperature sensor
  148. newbee questions AC and MAF
  149. jetta stuck in third gear
  150. Jetta Catalytic Converter
  151. shifting problem
  152. quick question
  153. fog light issue
  154. charging problems for my jetta can anyone help
  155. Alarm System Malfunction!
  156. short ram: good or bad?
  157. Jetta Rust?
  158. Broken Antenna
  159. VR6 Supercharger or Turbocharger ? Need Opinions
  160. Air Conditioner Not Functioning
  161. mkIII MAF cleaning?
  162. Advice Needed
  163. Volkswagen maintenance
  164. Shifting Linkage
  165. jetta shirt
  166. Are bora's geared different for the autobaun??
  167. Jetta TDI Performance
  168. Synthetic oil disappearing act
  169. car sat, won't start.. please help!
  170. Replace 096 with a 01M trans?
  171. Argh!
  172. air conditioning recharge problem
  173. clutch is slipping after replacement
  174. radio no longer working
  175. speed sensor problem
  176. Transmission Flush Service
  177. Transmission Swap
  178. Radiator Support
  179. jetta oil pressure light
  180. Coolantlite/ place2get trans. fixed?
  181. Monsoon radio wont come on.
  182. Help reverse lights don't turn on
  183. Major electrical issues?????
  184. VW Recall... whats taking so long!?
  185. In need of tranny info
  186. wolfsburg?
  187. just wondering
  188. dash lights
  189. dash light not working...
  190. A2 DIGIFANT NEED HELP FAST. car dies after 10 mins
  191. Fsi
  192. stock airbox breather valve 2000 jetta???
  193. starter wiring
  194. speedo ?
  195. leather interior
  196. Im new to this and i need help!!!!!
  197. right rear window not working
  198. jetta alarm car won't start
  199. Alignment and strut issues
  200. 17x8" 5x100mm MAK Force 35mm offset hubcentric wheels for sale
  201. Wipers, ac, lights just stop. HELP!
  202. Class action lawsuite re: front end spoiler
  203. VW Jetta fact or myth?? Gas mileage?
  204. engine ecu
  205. P 1476 code, EVAP problems - what does this mean>>
  206. Does anybody know of any good mufflers for VR6
  207. very weird question
  208. Where's Mr. Bentley when I need him????
  209. A little off topic, but looking for input
  210. Driver door panel badly scratched/dented
  211. Little help with VW 2.0L and Timing Belts
  212. Struts/Mounting Plate?
  213. Disabling factory alarm
  214. Catalytic converter problems...
  215. trustworthy??
  216. Help W?paint Code
  217. Paint type???
  218. smelly Jetta
  219. Trunk lock assembly
  220. seat covers
  221. how to replace wheel bearings?
  222. main fuses
  223. DIY replace front blinker?
  224. Performance exhaust
  225. My Jetta Dies while I am driving
  226. HYPER White for sale
  227. body kits
  228. a/c recharge
  229. turbo timer
  230. keyless entry battery
  231. 17" Moda R6 wheels on a white Jetta?
  232. power door locks, won't start
  233. Transmission Jerk
  234. DIY on MKIV 2.0L timing belt?
  235. dash light problems
  236. Alarm remote control problems
  237. boosting horsepower
  238. Jetta III Transmission Problems?
  239. Power Door Locks
  240. 2.0L engine swap
  241. Temp Guage + Check Engine Light
  242. Plug in the Rear Wheels for Stateside Jetta III GL
  243. set timing on jetta III
  244. somethings wrong
  245. camshaft hp
  246. modify the 2.0L or swap for a VR6?
  247. converting airbox into cold air intake
  248. poor fuel economy
  249. 2.0L 16V swap
  250. VW help
