oil in spark plugs
cb229
01-19-2004, 08:59 PM
I just got a 98 Jetta GLX V6. I had plugs changed and mechanic said it has oil in back 3 plugs. It has 97,000 miles on it. Does anyone have any ideas as to what's wrong. Check engine light is also on now. Valve cover gasket? Head Gasket? oil is clean.
termitesgraffix
01-20-2004, 12:23 PM
blown valve seals, blow piston rings, somehow oil is getting into the cylider. that would be my two guesses. sorry kid, but 97K miles on a car that was probably ran hard or didn't have regular oil changes, or was run hot, it can happen.
Boost192
01-20-2004, 03:08 PM
valve cover gasket kit will fix ur problem
mmichalak
01-30-2004, 07:34 PM
oil fouled plugs sounds like u have a pretty serious problem, i'd suspect head gasket, or valve stem seals, usually stem seals get hardened after time and allow too much clearance for oil to lubricate the guide, but it has to be pretty severe to foul the plugs, check the head gasket
