Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Volkswagen
> Jetta/Vento/Bora
View Full Version :
Jetta/Vento/Bora
Pages :
1
2
3
4
5
6
7
rattling and squeekin when not accelerating
Where's the Transmission Dipstick? (Seriously)
Hook?
ScotchGuard
bosch +4 platinum??
Radio Display Color Change
Hi all ~ New guy on the block
Air Vent Lights
newb at this forum
Paint code location?
Power Steering Fluid
got a quick question
Are Jettas reliable?
engine code?
spark plug change(?)
After Service - loat all oil - car died - TDI
diesel tach conversion
black or gray velour (cloth) interior?
Reverse/backup light switch
front bumper
Frankenstein my b18 'cura 'teg LS
gauges not working
Rattling noise around 2500RPM - Please Help!
problem with 2.0 16V
additives?
2.0 upgrades
Fuse panel card symbols????
are these girl cars?
where to find hazard and signal relays?
Other tuning chips
Front Bearings
How do I change right front blinker
New Jetta driver, need your advice!
Seat belt is jammed in...
vr6 automatic supercharger
jetta tdi
TDI Tie Rod or Steering Gear
New engine thoughts and ideas
VR6 Swap
possible cracked piston ring?
Brake lights don't work and blinkers turn solid???
what do the jetta vr6 superchagers look like?
new to jettas.. help plz
What do I need to switch to a Manual?
whats goin on?
Oil Pan
Outside Door Rubber Strips
Decided Loss of Power
Oil Change questions
New parts fo engine??
Cold Air Intake comparisons??
Recharge A/C
P1582 Malfunction Vehicle speed control
Catalytic Converter HELP!
Check Engine Light
wheels
Temp gauge occasionally works
Radio Replacement
Rear Seatbelt
best exhaust system for price/performance?
How do i replace the gauge lights?
Alarm problems
Can't get Jetta out of PARK
dirty seats!!
Does the monsoon stereo have pre-outs??? for amplifiers?
Tool T10029
HeadLights
Jetta - Panasonic CD Changer
mkiv REENFORCED ABD 28mm Rear Sway Bar For Sale - works with H&R Coilovers too!
jetta bumper
long cranking (starting) time
Increasing Jettas power
Engine Swap...
strange vibration/new member
jetta III cruise control
What Is This Noise !!!!!!!!!!!
Jetta security system
P1582 Engine Code...???
Knocking from under Carriage VR6 Jetta
Turn Signal Issue...input highly appreciated!
i have a wipers problem!!!!
turbo bypass valve
harness disconnected, somewhere
Jetta MK2 Gas and Temp Gauge Problems
Trek vs GLS, etc.
Trunk button & cruise control
advice on buying a jetta
looking for factory recaros
Wiring or what?
Ebay listing for Full Bolt on Front end conversion of GTI
Need some help please
pimping out a jetta
ricer questions
plans
jetta gli
Subs
Some noises...
Jetta transmission problem
Need Quick Help, how to can I pull codes from '91 Jetta? (GAS)
calling all jetta experts..
help!
Power trunk problem
Insurance Question and vr6 comparison
Trailering on a Jetta
2000 jetta lowered question - steering shakes -
jetta radio code
major problems
FS: LED dash sitches, red or blue
Chips
Turbo for my VR6
Tire Size
Jetta Pricing
exhaust??????
terrible mileage
beeswax
moisture in trunk
Headlights
Power Lock Motor Keeps Running
Battery and Alarm Problems
new tires
RPMs jump when shifting
Brakes and the ABS and E-brake lights
Which is better? Supercharger or Turbo??
performance mods and chip questions
Brake Chime driving me NUTS!!!
my car
alternate blinker colors????
header
Wiper/Fuse Problems
Cap and Rotor Replacement Question
Jetta alarm prob.
I need help!!!!!
Intake Kits-need help choosing!
Audible oil warning signal, and oil light
Tire Wear
Can I disable my mk4 factory alarm???
Heater core? Thermostat? Recall?
OBDII cannot find codes
dash lights
will after market intake really kill MAF???
Need some help
Removing Breather T-Connector
Cat back system
VR6 oil pan torque specs.
VW dealer Q&A session: has this guy lost his mind?
97 Jetta: Protective Shield in Wheelhousing Noisy
temp light and stalling????
I need more power!!!
tail lights
transmission
Performance Chip Questions
Wipers stopped wiping
weird sound from engine bay (sound clip)
ft susp?? strut problems
Electrical???
Where to go to find out about Recalls?
Lower clutch pedal
What springs to pick.....
GLX VR6 For Sale- Immaculate VW
starter problem, and turbo question
Full of shit?
Modfied Jettas any type
leak detection pump - evap emmisions
Alarm
Drive Cycle
anyone use the K&N air filter on your VR6?
anyone looking for LED's
Do I need to remove the intake manifold to change Spark Plugs?
battery drain
gauge cluster
can't get tranny into gear
tail light problems- HELP!
burning up blocks
sites & links
Help me purchase a performance jetta!
Reliable? Class Action? Anyone?
TDI Acceleration Problem
speedometer
Jetta TDI
Jetta GLS Speeometer Problem
F/S: 18' rims & Tires
VR6 Engine Turns But Wont Start.
Thick white smoke
probs with my VR6 ( Diary )
european oil for european car?
I can't figure out my high idle speed?!?!?
Radiator fan only comes on if I turn on the A/C or Heat!!?!?!
When to Change the Transmission Fluid?
CV Joint Problem??
CD player problems
Disengage ext. handle from operating bar
tricking my MAF sensor..Please Help
Question about Motor Oil
Removing Door Panels on 96 Jetta
Lock Cylinder plates
M3 Spoiler
block damaging intake 1.8t
GTI Full Front End Converion/body kit for sale
Automatic tranny in VR6 started to hang in gear occassionally, ideas....???
speaker install
hardcore jetta tuner?
Jettas with a no spark condition.
WTB>16V/4spd/4d/GoodCond/Jetta
new Jetta VR6 owner with some questions.
performansth 85 jetta
question about acc's on my '90
Borla or Dynomax???
Keep Getting My Front Bumper Caught on Jetta NEED HELP
Next Level Perfromance Module ?
Check Engine Light
radio
SRT-4 vs. VW 1.8T video
17550 Load Calculation Cross Check Limit exceeded
Clutch Release bearing
Special VW battery?
radio (probably fuse)
'96 jetta cold air intake kit
1996 no spark/no start saga
Oil foam? on oil cap?
Changing drivers side front bulb
1.8t Oil Drain Plug
Turbo VR6 video
Electrical Problems!! Please help!
Window tint?
OEM jetta cd changer
Radio Code Please Help
Slipping or Cold?
Knowing when to get new clutch
door problem?
Rain/Snow Water leaking into cabin and more!
popping sound?
best exhaust?
Second car just for fun
Stalling volkswagen jetta
Fuse or relay problems?????
I dont know anything...
Need turbo!!!HELP ME OUT
CD changer problem
simple transmission ques....
speaker dimensions for MK4 Jetta
For Sale!!!!!
Code reader?
I need a good intake
painting tail lights/dont ignore help me
MY jetta ?'s
look at this PLEASE......
Survay for Purdue ME design course
what kind of exhaust ??? please help
MK2 Jetta Starter Removal
loss of power
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
