View Full Version : Jetta/Vento/Bora
Pages : 1 [2] 3 4 5 6 7
  1. 90 Jetta
  2. electical short or what?
  3. looking for gear heads near akron ohio
  4. 97 jetta iac location
  5. Purchasing a used 01 Jetta...
  6. Brake Problems-New Brakes and Rotors
  7. Aftermarket Navigation System
  8. 1986 Vw Jetta Gli 1.8 (((overheating!!!)))
  9. Some is really wrong with my car (97'Jetta GT)
  10. DRL's
  11. Melted Crayon smell in TDi
  12. 98 Jetta stalling problem
  13. Jetta VW wheel cover: anyone know where I can find one?
  14. brake and reverse lights
  15. Diesel Jetta fuel filter
  16. 2001 jetta stalls
  17. 98 Wolf: Sloshing Water, Drips onto Pass. Floor
  18. Who would win?
  19. 97 jetta 2.0
  20. 96 jetta GL
  21. '02 Jetta VR6 2.8L Info
  22. try this tranny problem
  23. a/c smells like exhaust
  24. Rear Defroster and wiper relay
  25. 1995 Jetta, Weak engine
  26. Question concerning Jetta
  27. A Sad Day
  28. Idle air control valve cleaning procedure
  29. water pump location...
  30. coolant leak
  31. Need help with battery issue
  32. Oxygen Sensor
  33. stuck in park
  34. Lost VW Vento Classic Radio Pin Number
  35. dashboard lights flickering
  36. Anyone thought of....
  37. 2002 Jetta Wagon extended warrenty
  38. Intermittent engine power loss
  39. clips for distributor
  40. 96 2.0L Idles high when temperture is cool
  41. Update on "VW cranking too long" thread, CODES
  42. the dam side molding
  43. HELP! Stupid "nickel and dime" jetta
  44. Attention!!! Off Warranty VW
  45. VR6 oil filter..
  46. 99 jetta running sluggish
  47. F@#* Volkswagen
  48. gas gauge problems
  49. 94 VW Jetta noise damper
  50. 1999 Jetta Will Not Start!
  51. interior cleaning??
  52. running problems with a 89 jetta
  53. engine check light??
  54. 98 Jetta GLX Horn Problem
  55. AirBAg Light
  56. Alternator Replacement
  57. song from the new jetta commercial
  58. oil changes and warranty
  59. help with 98 GLX with Bose System
  60. 96 jetta / golf good =?
  61. 83 Jetta Timing Issues
  62. FS 2000 afp VR6 12v with 35K miles
  63. bypass factory alarm
  64. Headlight Conversion
  65. vw bora alarm
  66. Jumpin ship From Honda/acura To Volkswagen
  67. Running problem with 16v
  68. Problems with 04 jetta?
  69. moonroof parts
  70. Radio problem
  71. check engine light stuck on for years
  72. Emissions problem
  73. Fuel indication
  74. Rims, lowering...
  75. Diesel : No juice to my cut off valve
  76. Jetta GLI - 18inch low profile, fun car
  77. Fuel problem
  78. bogged down engine
  79. wipers n heater fan out
  80. bogged down engine
  81. Thinking of Selling My 03 1.8 Turbo
  82. 3.0L V6 Toyota ==> 1.8T VW??
  83. vw jetta cranking too long with warm engine
  84. body kit
  85. Jetta 2.0 parts swap
  86. Gas mileage/Tank reading
  87. Killer VR6 Keychain
  88. Badgeless Grills
  89. cd changer
  90. signs that my clutch is going?
  91. what should I look for in a Jetta TDI?
  92. 91 Jetta GLI power window problem
  93. 2000 Jetta Tdi Flashing Glow Plug And Chech Engine Light
  94. 96 Jetta wiper problems
  95. Jetta died on highway
  96. does not stay running
  97. MPG reading
  98. Noise under emerg brake... Cat?
  99. 02 JETTA performance
  100. 96 Jetta 3
  101. 96 Jetta GLS stoplights always on/brake pedal switch OK
  102. Can you change the forum, please?
  103. obdII p0341 1996 jetta
  104. Question about Jetta transmissions
  105. jetta, mk3 engine noise
  106. 18" rims vs. potholes.. help!
  107. Diesel Jetta
  108. Parting out 97 Jetta Gl 5Spd
  109. new jetta
  110. 1996 jetta code reset
  111. 2000 Jetta with serious oil problems
  112. 1994 Jetta Reverse Problems
  113. BMW Angel Eyes DIY For 00' Jetta?
  114. 95 Jetta clutch peddle on the floor
  115. K.C. Converters
  116. HELP dead car
  117. few problems w/1997 jetta
  118. Car won't drive!!!
  119. Water on Driver's Side floor
  120. Jetta start problem
  121. Just bought 2000 Jetta
  122. 90 jetta sub zero starting problems
  123. 1996 jetta no spak
  124. Radio problems
  125. Less Gas Mileage
  126. 96 jetta glx
  127. Vandalism on my MKIII
  128. Jetta Automatic Transmission
  129. Jetta stalls when idling in cold weather
  130. Starting in cold weather
  131. 98 Jetta GLS
  132. who set this up
  133. 1996 VW jetta alarm and heat
  134. 1997 Jetta GLX Airbags
  135. Jet surges on acceleration
  136. new GTI whoas
  137. Jetta III, white smoke, NEW headgasket
  138. hid kit for 2000 jetta
  139. for sale 95 jetta runs needs work good project or parts car/ need advice for new car
  140. ---==headers???==----
  141. 2000 Jetta TDI Stalls at Operating Tempurature in Colder Weather
  142. 2001 Jetta problems = temperature gauges + shifter bunch up
  143. Jetta 95 coolant replacement
  144. 97 jetta 2.0
  145. slipping clutch
  146. 2002 Jetta whobbly noise and needed parts
  147. hard starting diesel
  148. Car hesitates when shifting
  149. Oil Light Flashing
  150. proud of your car? or you dont know what do to with it?
  151. 2000 GLS 2.0 Trouble Code Question
  152. will 16" rims fit on a 2004 Jetta GLI 1.8T
  153. Timing Belt 2001 TDI
  154. Jetta Forum Changes
  155. Questions about my jetta
  156. scrwed up a rim
  157. Sunroof Mishap
  158. Flooding VDub
  159. Premium Audio Lock Down
  160. I need help fast!!!!!!!!!
  161. average life of a clutch
  162. How to replace airbags
  163. Oxygen Sensor
  164. heater core leaking
  165. Vento vs Jetta
  166. hey everyone ltns...
  167. can you make a tdi quiter?
  168. Electrical-
  169. freaked out speedo
  170. Wiring Diagram
  171. AM Radio distorted
  172. Hesatation when i try to accerate
  173. 2001 VR6 Electrical Issue?
  174. jetta help
  175. fusible link
  176. glow plug light is blinking
  177. Can only get up to about 20mph for first 5 minutes?!?!
  178. fuel pump running
  179. tire size help please
  180. Mk. V Jetta Press Release
  181. looking for advice
  182. Rattle in Intake Mani at 4000 RPM???
  183. car altonator problems
  184. newbie ? on fuel grade
  185. 17 Inch Rubber?
  186. starter help please
  187. windsheild wiper ?
  188. $100 Metal VR6 Coolant Pipes
  189. valve cover gasket
  190. Say goodbye to my resonater, anybody done this??
  191. jettaGL overheated is it serious?
  192. car cuts out when engine temp is half way when stopped
  193. Radio safe mode need code!!!help
  194. What Is The Best Sound System For The Jetta?? And What Do You Have???
  195. Newbie with a problem
  196. Should a jetta ISV make a clicking noise
  197. Check Engine Light!
  198. Rattling/knoking Noise During Acceleration
  199. No power to starter?
  200. Bizarre electrical problem
  201. rims for jetta
  202. Problem with Coolant Light
  203. Sreet Racing In New York
  204. Headlights
  205. Rattling Noise
  206. Newbie here...need infor on Jetta idle problems
  207. Extended Auto Warranty
  208. safe to drive in limp mode?
  209. new spark plugs
  210. race
  211. Two OBD Codes (P0411 & P0422)
  212. Jetta help
  213. audio question
  214. red anti/freeze
  215. rally
  216. A/C fan fan belt
  217. Lowering springs
  218. engine part question
  219. Jetta GLS Window Problems
  220. Codes: P0171 System Too Lean P0440 EVAP Emission Control System Malfunction
  221. Autotech
  222. GLS to GLX
  223. Oil
  224. mk3 alarm
  225. Hard starting
  226. Dead gas gauge mkIII
  227. tail light
  228. Black Smoke?? Mass air flow? o2 sensor??
  229. does anyone know......
  230. air mass sensor
  231. Ecu
  232. Performance Tires
  233. bumper question
  234. Need Advice Plz
  235. Alignment issues
  236. Metal VR6 Coolant Pipes
  237. intermittant air
  238. Passing Smog
  239. whats the best jetta year???
  240. Question catalytic converter
  241. Fuel Filter Connectors
  242. taking out radio
  243. Radiator cap question
  244. Blinkers, taillights, brakelights messin up
  245. What oil weight for a 99 Jetta?
  246. 2004 Jetta - Mexico Dealer Story
  247. Where have you gone, glovebox?
  248. Day time running lights
  249. lights out
  250. Double brake lights
