View Full Version : '97 - '03
Pages : 1 2 [3] 4 5 6 7
  1. Check Engine Light
  2. Tiptronic 5spd
  3. MkIII Jetta Auto Trans
  4. Turbooo
  5. 1997 Jetta fuse map?
  6. 98 Jetta TDI Turbo
  7. '01 Jetta 1.8T idles rough when cold
  8. vw jetta P0304 Cyl.4 Misfire Detected
  9. how do you change 2002 Jetta Spark Plugs
  10. Front Wheel Bearing Questions
  11. Jetta 97 Location diagnostic port
  12. 00 Vr6, alternator??
  13. 1997 jetta gls bumper intakes
  14. 1997 jetta tire/lugnut problem
  15. 1997 jetta temperature gauge
  16. 1997 jetta cruise control problem
  17. 97 Jetta 2.0 bucking/missing under acceleration
  18. 01' Jetta- Driver's Door locking, keyless entry!!!!!!
  19. 98 Jetta GLS Alarm/Lock problems--help!
  20. VW Jetts 2000 GLS VR6 Noise Problem
  21. Car didn't start, couple questions
  22. Brake Booster repair cost
  23. 2000 Jetta VR6
  24. Headlight Problems
  25. Bad CV joint or Ball Joints or none...2000 Jetta GLS
  26. Jetta Trans code DLZ vrs CLK
  27. 1999 2.0 bogging on acceleration
  28. 03 GLI Trouble starting
  29. 97 jetta - blown air bags
  30. Alarm problems 1997 jetta gls
  31. installing vw bora titanium headlights
  32. '03 Jetta, Radio Issue
  33. 97 Jetta Manual Trans stalling
  34. Cooling System
  35. 85 VW Jetta Turbo Diesel
  36. noise
  37. Air pump for MAF 97 jetta 2.0
  38. A/c?
  39. Chipping a jetta 1.8T
  40. direct replacement?????
  41. 98 Jetta Starter--can't get it out!!!!!
  42. Do I have Keyless???
  43. 98 TDI Jetta 3 Trouble Codes
  44. not working A/C and power windows
  45. '98 Relay/Fuse? Lights off/on, Cruise, radio out....
  46. transmission valve body
  47. 95-98 Jetta EBrake Lever
  48. 98 jetta engine codes
  49. 98 Jetta Wipers won't work
  50. Sound System.
  51. '01 GLS: Your Thoughts/Comments
  52. FOR SALE: 2001 VW JETTA 1.8T WOLFSBURG EDITION 125km - Toronto, ON, Canada
  53. 98 TDI Jetta
  54. heater a/c fan only works on max
  55. 98 Jetta speaker question
  56. 98 jetta code p1426
  57. Headers!!!
  58. buy or not to buy a vr6
  59. need vw parts
  60. bora 01, wiring diagram
  61. Alarm/Lock Issue
  62. Brake light switch
  63. 2002 jetta 1.8t transmission trouble Help!
  64. 00 jetta fuse panel diagram
  65. need help locating the external temp sensor
  66. engine rebuiild
  67. P0171 Code-- can someone help?
  68. Temp Sensor (in dash)
  69. Cannot unlock rear doors and passenger door from keyless entry
  70. 01 Jetta: Check Engine Light/Catalytic Converter?
  71. 01 Jetta Code P1151 Help! Lower Limit Exc
  72. the code for the radio
  73. 98 Jetta GL Auto Trans problem
  74. what's the matter with my jetta?
  75. the size of the Jetta engine
  76. Any Hope ?
  77. clutch cable
  78. Terrible Noise When Starting
  79. air bags module
  80. Mk IV Jetta Weaknesses?
  81. Just got Bora...couple of questions
  82. Please help '00 Jetta GL P0172 error code
  83. About to be a Jetta owner :)
  84. Jetta VR6 Hesitates on Acceleration
  85. 99' Jetta - P0321 Code Question
  86. 2002 jetta shakes horribly
  87. 99 jetta brake lights
  88. About Running Lights.....
  89. What do you think of this Jetta? Need advice
  90. 2002 1.8t hesitation
  91. Help:2000 Jetta makes strange vibrating noise
  92. Timing belt 99 VR3
  93. Please Help
  94. 2003 jetta with code p0778
  95. 99 Jetta headlight removal
  96. Dash light question
  97. family engine number --- 2000 Jetta
  98. new to the Vw world
  99. Something is strange about this car
  100. 97 Jetta GLX RR window not working
  101. veedubmechanic, need assistance again...
  102. please help
  103. Red Line at 50km/h on VW speedometer??
  104. FS: Jetta 2003 Super Condition. lowMILES MUST SEE!!!!!
  105. 97 Golf - Automatic Transmission Help
  106. 1997 jetta gls
  107. 2001 Jetta Suspension Problem
  108. 2003 1.8t Problems!!!
  109. Locked Gears
  110. 97 Jetta Shuts off
  111. Dear Volkswagen Jetta Owner
  112. 97 jetta dashboard door lock switch/cd changer
  113. Problems with 98' Jetta ECM codes
  114. check engine light ??
  115. Boost on stock 1.8T??
  116. Problem with shift knob on 97 Jetta
  117. 99 Jetta Stalls and EPC Light!
  118. Resetting the system
  119. Speaker not connecting to Stereo? (97 Jetta)
  120. Where are the Relays? (97 Jetta)
  121. Jetta Side mirror
  122. 01Jetta::Electrical Problem??
  123. Need help on my Jetta 2002 GLS
  124. Radio install Question - 01 Jetta
  125. Installing Aftermarket Radio
  126. jetta swap
  127. Keyless entry
  128. air flow
  129. Car Stero/Alarm
  130. Stalling problem
  131. 2nd gear stuttering problem
  132. Crayon smell in Jetta
  133. 03 GLI PO118 Engine Code
  134. How much HP can stock engine handle
  135. 98 Jetta GLS - CEL P0411
  136. Arching SparkPlugs? 2001 Jetta
  137. 99 jetta eheck engine light ?
  138. Bad Oil Leak TDI
  139. Supercharging a 2.0L
  140. lookin at a 2000 jetta vr6
  141. Sparkplugs
  142. Side Marker
  143. English term
  144. Overheating problem!!!
  145. 2000 Jetta GLX VR6 - P1340 Error Code ???
  146. 2002 1.8T What is draining my coolant?
  147. Jetta taking longer to start
  148. 98 Jetta Automatic
  149. can you remote you windows like this?
  150. 01-04 Jatta 1.8T owners? Do you think it's normal?
  151. 2001 1.8T turbo problems
  152. 2000 Jetti starts, then immediatly stalls?
  153. new stereo system... need help
  154. 2002 1.8t turbo red hot
  155. Bora 99 2 litre 6 cd changer problem
  156. Bora 99 2 litre air con problems
  157. 2001 Jetta 1.8T Stalls
  158. '00 GLS Fuses keep on Blowing..
  159. Newbie
  160. Ash Tray cover came off 02 Jetta
  161. WTB: Black leather 02 Center Console
  162. '97 Jetta III Starting Complications
  163. 2001 Jetta Battery Drain
  164. 2001 Jetta 1.8T Battery Drain
  165. Jetta TDI reliability
  166. 2001 Jetta GLX VR6 help!!
  167. Just got a 97 jetta GL. What should i do to it?
  168. A/c and cooling fans stay on
  169. just got a 98 jetta gt (stick) mod suggestions
  170. 2000 Jetta front end thump on uneven surfaces HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  171. sunroof drains ( 2001 vr6 wagon ) clogged :(
  172. temperature gauge problems
  173. 2002 Jetta Eats Gas?
  174. 2002 Jetta GLS 1.8T Manual reliability?
  175. '97 fender removal?
  176. 01 jetta front brakes
  177. Headlight trouble! Help!
  178. insurance on a vr6 for a 16 year old
  179. 00 Jetta - Wiper Adjustment????
  180. 99 vw jetta keyless entry reset???
  181. 97 Jetta Engine Mounts
  182. Spark plug install
  183. 2001 VW JETTA VR6 Just Overheated
  184. Swap AZG for AEZ engine???
  185. question about CD player for 97 Jetta GLS
  186. 97 Jetta High Idle when put into gear.
  187. Help with Cruise Control Fuses
  188. 2001 Jetta - Gearing is way too low...please help
  189. 2000 jetta vr6
  190. Please Help Me Jetta Isnt Starting Up
  191. Alarm Problems, won't start - 1997 Jetta - HELP
  192. Headlight not working...
  193. 98 jetta not firing correct help pls??
  194. Wierd noise...97 Jetta Trek (Any help?)
  195. Common Failure Items (Runs and Bat. goes flat)
  196. Jetta TDI?
  197. '01 Jetta VR6 overheat
  198. 98 Jetta Transmission slams into 1st
  199. Transmission Problems???
  200. 1997 Jetta MIL code P0102
  201. 2002 1.8T engine hesitation
  202. How hard is it to get to the check engine light 99.5 Jetta
  203. '97 Jetta GLX VR6 Transmission!
  204. 98 jetta tdi engine code P0605
  205. Electrical Short - Brake light in dash on!
  206. 1999 Jetta Electrical Problems
  207. 97 jetta 2.0 5sspd. inner idler arm
  208. 98 VW GLX Engine Code: P1426
  209. electrical drain
  210. Clicking in reverse
  211. begin mods
  212. 97 Jetta GL will not idle properly after battery change
  213. Jetta 2001 Check engine light code 1296
  214. Clutch went out??
  215. Side Airbag went off !
  216. P3081 Code Fuel Air Metering Auxillary Emission Controls
  217. 99.5 Jetta GL rear seatbelt problem
  218. 99.5 Jetta GL sputter and stall w/restart
  219. I'll never buy another volkswagen
  220. Air Intake Installation
  221. Horrible/loud squeak at ignition / start-up
  222. Air Bag Warning Light
  223. A window problem, '97 glx
  224. Water Pump 98 GLS 2.0
  225. Show Off Your Rides!!!
  226. Battery/Power Issues 2000 Jetta
  227. FOR SALE AEM Intake for jetta
  228. Should I Replace camshaft position sensor???
  229. Vibrations in steering wheel
  230. Jetta seat fabric attracts too much lint
  231. 2000 Jetta fuel cap won't open
  232. Mustang owner, screwed up a buddy's jetta, help me out
  233. Bora suspected air intake problem
  234. Radiator help needed
  235. 97 GLX dont crank
  236. 2003 Jetta died on the highway
  237. 97 Jetta GLS Sunroof Question
  238. 2003 VW Jetta Question
  239. 2000 VR6/Smoke under hood
  240. Problems Changing Gears
  241. 00 gls jetta
  242. 00 jetta gls airbag light
  243. 1998 Vento vr6 headlight problem
  244. 97 Jetta Fuses????
  245. Just got a 97 Jetta Jazz
  246. could blowoff valve be harmful to ECU??
  247. 01 Jetta 1.8T, M.A.F. Sensor Failures!!!!!
  248. 1997 Jetta VR6 Camshaft Posistion sensor/timing problem
  249. FS: 97 Jetta Trek
  250. 2000 Jetta 2.0 ..... T/Belt?
