View Full Version : '97 - '03
Pages : 1 [2] 3 4 5 6 7
  1. electric water pump
  2. my 2000 jetta makes a lound screaching sort of noise everytime i start it.....
  3. 97 jetta front end ?
  4. 97 Jetta wont start
  5. Jetta 99 GL 2.0L Transmition Stick Problem
  6. engine won't crank after locking keys in car
  7. 2000 Jetta GLS problem, please help!
  8. '03 jetta 1.8t rough running first started
  9. Jetta Mk4 (or most everyother car) Headlight restoration project
  10. 2000 Jetta Engine Scream
  11. 1997 jetta "trek" starting problems?
  12. 02 Jetta GLS W/57K issues
  13. '99 Jetta Alarm problems
  14. 2003 fuel pump?
  15. 1999 Jetta GL lens filler panel
  16. 97 Jetta, Brake lights shorting post-accident
  17. Help replacing Engine Speed Sensor 1999 2.0l
  18. 98 jetta electric problems
  19. 97 jetta trek running sluggish
  20. CD Player on 2003 Jetta Wagon GL 2.00
  21. How to reset an airbag light for 97 jetta GL
  22. Jetta 02 1.8T
  23. 98 Jetta 2.0, Coolant light question
  24. lug nuts
  25. 97' Jetta Starter
  26. 97 jetta 5 spd trans pushrod bushing
  27. 2003 1.8t Lost Power Suddenly
  28. 1997 Vw Jetta 2.0 Coolant Flow
  29. All you Jetta Guru's Please Help
  30. All you Jetta Guru's Please Help
  31. 2000 VR6 jetta/bora edition
  32. Buying a jetta
  33. Engine oil
  34. looking for vw sdi parts
  35. 2002 vw jetta 1.8 turbo
  36. Cold engine = stalls Hot engine = rough idle
  37. timing setting on a vw jetta 2003 ALH
  38. 98 Jetta CEL
  39. 2001 Jetta RPM Fluctuating
  40. i want my jetta turbo
  41. MIL Light On
  42. Engine speed suddenly drops-code P1580?
  43. Interior Question! can't find anywhere!!
  44. 99 Vw Jetta Bodykit Bumper
  45. monsoon stereo
  46. Volkswagen Exhaust
  47. 2002 Jetta GLS transmission problems
  48. 1998 VW Jetta TDI idles rough
  49. Jetta Rally Car
  50. Passenger door wont open!!!
  51. Electric Problem,computer,ignition????
  52. Trans computer change?
  53. Radio Installation Problem
  54. 97 Jetta GL - Battery can't keep a charge?
  55. 2000 Jetta Code P0341
  56. 98 jetta airbag sensor location?
  57. '02 Jetta 1.8T front end shake
  58. 1999 VW JETTA Trans problem
  59. Somethings wrong here!!!
  60. my blinker is going crazy
  61. major problem with an 01 Jetta
  62. 2002 Jetta
  63. auxiliary input...?
  64. car alarms
  65. 97 jetta starter... same part for manual & automatic?
  66. 2003 BLACK TINTED LIGHTS help
  67. Distrbutor Cap Retention clip problem
  68. help
  69. top brake light affected by main light switch
  70. Power Window/Door lock Problems 99.5 Jetta
  71. boostin my GF VR6
  72. 98 Jetta III GLX Transmission Issues
  73. Need help identifying part 02 Jetta
  74. Conic air flow filter
  75. strap a turbo on a Mk4 2.0L GLS?
  76. 1999.5 GLS Clutch Slipping
  77. ASR light flashing
  78. vr6 coolant temp sensor location
  79. Aeg/aba?
  80. 02 Jetta TDI - won't start
  81. ashtray/aux power light needs replaced???
  82. Need web site that will show tires and rims on vehicle
  83. 2002 Jetta VR6 - Engine Code
  84. 2000 Jetta Overheats!
  85. Window regulators on the 97 vento
  86. No juice to ignition or power windows
  87. 2000 Jetta remote fuel filler door won't latch.
  88. HELP! major problems with my jetta.. what should i do?
  89. 97 Jetta Check Battery
  90. 2002 Jetta 77K miles Engine fails
  91. 2000 2.0 timing tensioner old or new style
  92. 01 jetta engine problem
  93. 2003 volkswagen jetta vr6 12valve 1/4 mile stock?
  94. NEUSPEED chip ????
  95. jetta lighting
  96. 99 (New Body) Jetta Stalling problem.. No Check engine light.
  97. Trunk latch problem
  98. '98 VW Jetta GL
  99. What do i need to do?
  100. new turbo or Blow-off valve and intercooler?
  101. CD Changer
  102. 01 JETTA 1.8T - Stalls @ stops
  103. 97 Jetta GLX WON'T START!!! Alarm issues???
  104. 1999 Jetta Vr6 Radio Question???
  105. Intermittent Radio
  106. 2000 Jetta Radiator Removal
  107. Rear Brakes
  108. 2001 Jetta TDI A/C problem
  109. 2000 jetta w/ code 1582
  110. 99.5 jetta cooling fans inoperative
  111. Psycho Temp Gauge
  112. Remote
  113. Jetta 2000 1.8T no forward or reverse when hot
  114. '99 Jetta III Idle Adaptation at Limit
  115. 97 Jetta Won't Start! Please Help!
  116. Fuel Filter
  117. 02 Jetta 1.8T Engine Hose
  118. '98 Jetta with new TB (need to program?)
  119. 2003 Jetta rear tail light no power
  120. 99 Jetta Tail Light Problem
  121. 2001 jetta thermostat
  122. 01 Jetta - Starts and then sputters to a stop
  123. 99 Volkswagen Jetta Sunroof Question
  124. 02'Jetta
  125. what kind of trannie fluid should I use
  126. lightbulb upgrades for '03 jetta 1.8t
  127. jetta won't start
  128. im replacing my stock stereo for an aftermarket help. please read
  129. 01 Vw Jetta Stereo Question
  130. jetta stereo replaced
  131. HELP Jetta won't start
  132. New Clutch not Engaging
  133. 01 VW Jetta idling problems
  134. My new, old car.
  135. clutch on VR6 5-speed
  136. 97 jetta stalls when coming to stop (5 sp)
  137. 97 Jetta CEL problem
  138. 98 jetta gl
  139. Need advice on my battle with o2 sensors/catalytic convert.
  140. 99 Jetta GLX has A Starting Problem!! PLEASE HELP
  141. need help with ac
  142. Inner tie rod ends
  143. Oil
  144. Failure Codes on '97 Jetta
  145. Windows Failure / Blown Fuse?
  146. Timing Belt
  147. 2001 Jetta wont shift out of Park
  148. 97 jetta push accelerator and it slows
  149. Recent '03 1.8T Purchase & First Manual
  150. Need help on re-attaching front bumper right side only
  151. Missfire after timing belt, 97 jetta.
  152. My Jetta 97 stalls, no check engine light on
  153. how do you check the tranny fluid
  154. question about brake falure intermitant with strange sound 2003 tdi
  155. Need help!!! Vento problems!!!!
  156. Looking to Purchase '99 Jetta-need an opinion
  157. 2000 Jetta GL
  158. 97 Jetta Headlight Problem
  159. 03 Jetta - Says a door is always open...pls help!
  160. 99 new jetta 2.0 issues
  161. New Catalytic Converter. Now tons of problems. Please help!!
  162. throttle
  163. why isnt my jetta shifting good!!!!!
  164. O2 sensor problems 97 Jetta -- Need quick reply!
  165. Need to replace timing belt & water pump -- how much should it cost?
  166. Jetta Wagon Help!!!!
  167. why doesnt my tailights go off????
  168. AC Blowing hot air
  169. 2000 Jetta Simple Issue?!?
  170. 00 jetta tail lights come
  171. Test Drove '99 Jetta TDI. Turbo?
  172. 2001 Jetta 2.0l Tranny fluid
  173. 97 Jetta won't start
  174. 2003 Jetta TDI electrical problem
  175. a whole grip of problems
  176. Oil in 97 Jetta Air Intake tube
  177. Transmision slipping ??
  178. How much would you pay?
  179. Brake Lights
  180. Cylinder Head Questions
  181. Vibration around 1800-2000 rpm
  182. P1565 code
  183. Alternator removal
  184. '02 Jetta Fog lights
  185. Milky Oil Filler Cap
  186. Code P0582 where to look?
  187. to whoever can answer this ?
  188. Malfunction Vehicle speed control
  189. 1999 Jetta speaker replacement
  190. P1582 Code and Catalytic Coverter
  191. 2003 Jetta.... Speedometer, gas lights, and check engine!!!
  192. Oil drain plug dripping!
  193. '02 Jetta VR6: Check Engine Light - Make it stop!
  194. jetta dash lights
  195. jetta dash lights
  196. 97 jetta rough start
  197. Keyless entry/ alarm
  198. Will not turn over
  199. Quick Question
  200. '02 Jetta VR6: New Owner
  201. Automatic Jetta Not Shifting Past 2nd Gear
  202. Just bought 2002 Jetta 2.0
  203. Light and beeping comes on right before i turn the car off
  204. Trans Oil
  205. 01 Jetta cloth interior, why the fuzz?
  206. 02 Jetta Starting Problem
  207. 98 Jetta Crank No Start?
  208. 99 jetta shifting problem
  209. Rwd Vr6?
  210. 2000 Jetta 1.8t thermostat
  211. 1997 Jetta Radio doesn't work
  212. Selling 98 Turbo Diesel
  213. A/C Heater lights delay in coming on
  214. A/C Heater lights delay in coming on
  215. 01 Jetta VR6 ebrake won't dissengage
  216. Front dooors not opening
  217. Question - Where I can get a Jetta 1.8T Motor
  218. 97 Jetta - not starting
  219. 2002 Jetta Speaker Wiring Issue
  220. '00 Jetta Bucking and Hesitating
  221. 02 bora problem please help me to solve it.
  222. 99 Jetta spongy brakes after front pad/rotor replacement
  223. 2000 Jetta 2.0 liter Clutch Problem
  224. jetta engine switch
  225. jetta engine switch
  226. jetta engine switch
  227. Transmission Costs???
  228. Voltage Regulator
  229. 2000 Jetta has never stalled in 1st gear when trying to stall it!
  230. 99.5 Jetta Stalling Need Help????
  231. '99 Jetta Radio Questions
  232. Both Tail Lights Out On A 2000 Jetta
  233. 98 Jetta problems
  234. 03 Jetta Brake Lights Stay On (& More!!)
  235. 03 Jetta Brake Lights Stay On (& More!!)
  236. 03 Jetta Brake Lights Stay On (& More!!)
  237. Passenger side turn signal light replacement
  238. Check Engine Light
  239. HVAC lights INOP
  240. Driver's Door not sense that it is open.
  241. Code P0748 Jetta 99
  242. Cold Air Intake (what brand to buy?)
  243. Need new rear suspension?
  244. would you buy again ??
  245. 97 jetta alarm
  246. 97 jetta alarm
  247. 02 jetta gls no spark no fuel
  248. 98 jetta wabbles?
  249. 97 Jetta Steering Wheel jumps, bumps, and squeels
  250. 1997 Jetta Ignition Problem
