View Full Version : '97 - '03
Pages : 1 2 3 4 [5] 6 7
  1. 98' Jetta intermitent brake lights
  2. cooling fans not working
  3. Jetta 2000 VR6 GLS - how disable door alarm
  4. Having issues
  5. rear window
  6. 1999 Jetta For Sale
  7. 99 Jetta Bose Radio Problems
  8. Radio safe mode!!!!!
  9. secondary air injection system
  10. Hard shift of gears AT...please help
  11. 00 Jetta VR6 for sale
  12. Question for veedubmechanic or anyone else who knows...VW maintenance
  13. Lights out
  14. Electrical Problems
  15. 97 Jetta Wierd A/C Problems...HELP!!!
  16. '97 jetta will not start
  17. 2001 Jetta Radio Not working at all
  18. P0420 Engine Light 02 Jetta
  19. 2000 Jetta Transmission Trouble
  20. Diesel Performance
  21. 1998 Jetta GLX Brake Problems
  22. 2002 1.8T...no codes but problems
  23. emergency brake
  24. jacked-up jetta anyone?
  25. Message on Dash of 02 Jetta Turbo
  26. thinking bout a 01 jetta possibilities?
  27. 97 jetta automatic transmission
  28. Possible future problems?
  29. New bora.
  30. 2002 Jetta Battery Draw "At Times"
  31. '01 jetta=150hp, '02 jetta =180hp..HOW???
  32. Speedometer Failure on 2003 Jetta
  33. 2001 Jetta will go reverse when put in drive !!
  34. Good Deal????
  35. A/C system
  36. CD Wire Harness
  37. Safe Mode 98 Jetta
  38. Mk3 Spring Replacement..
  39. Side mirror replacement
  40. 97 jetta power windows
  41. 97 VW Jetta starter/idle issue
  42. 6 Disc CD Changer
  43. why is it hard to turn the wheel?
  44. Replacement coil won't work
  45. 1997 Jetta Gt stutters/buckles
  46. 98 Jetta GLS Window Regulator Qestion?
  47. 97 jetta stock radio "safe" mode?
  48. 98 jetta GLS Auto with 108k Cluster gets all screwy
  49. 97 Jetta GL , 115k considering buying, opinions?
  50. '00 jetta gls for sale!
  51. 02 jetta vr6 mil light
  52. 97 Jetta E-Brake/starting probles, please help
  53. 97 jetta 2.0 manual sputtering after rain
  54. Engine Rattling When Starting Ignition
  55. changing taillight bulb on 98 (old style) jetta
  56. grinding in second third and fourth
  57. 97 starting problems
  58. 97 automatic transmission
  59. 97 Jetta wont start Boschmann help!
  60. P0171 Error Code on 98' Jetta GLX
  61. Lug Converters.. 4x100 to 5x112
  62. 98 jetta wolfs. 2.0 auto
  63. 2000 1.8T, timing belt tensioner noisey
  64. error p0411
  65. clunk
  66. coolant light blinking
  67. 2002 Jetta Radio Problem
  68. Strange noise
  69. should i sell my 97 jetta GT?
  70. Headlight question
  71. HELP VW JETTA Check Engine Light!?!?!?
  72. For Sale!!! '99 Jetta Wolfsburg - 113K
  73. 98 Jetta GLS pleeease help?
  74. Dashboard lights/Brake light/Beeping
  75. 97 Jetta GLX brake lights!
  76. Dashboard lights/O2
  77. stalling in reverse #2
  78. Stalling in reverse
  79. door problems
  80. new 1.8T owner looking to upgrade
  81. 99 jetta Fuel Filter Problem & Car Bogs Down
  82. Passenger floor getting wet
  83. 98 Gls
  84. 2000 starter in '97 Jetta?
  85. signs of a dying tranny?
  86. 2001 2.0l Jetta
  87. rear side of the car shaking
  88. Fluids
  89. Taking out the Mass Air Flow screen
  90. anyone buy a rack from 800-vw-parts?
  91. 2005 A5 issues
  92. '97 Jetta GT new owner
  93. Power Steering
  94. Idle is varying
  95. Check Engine Light
  96. 03 Jetta 1.8T Wagon cooling fan problem
  97. check engine light...exhaust leak?
  98. clicking noise coming from underneath glovebox
  99. NEW kind of stereo / radio reset problem. help?!
  100. Lights are on! warning noise wont turn off
  101. blow-off valve
  102. newbie question
  103. 99.5 Jetta VR6 AT stalling at idle!!!
  104. Swapping Front Seats Out
  105. Secondary Air Injection website
  106. Two questions... one post
  107. good news about MAF
  108. This thing (99.5 Jetta) handles like crap!
  109. 99.5 Jetta that runs rough - F.I Wires?
  110. 97 Jetta GT Exhaust Leak??
  111. Feedback On A '97 Gt!!!
  112. 2000 Jetta CD Player Wiring
  113. 97 Jetta Tranny Problems
  114. Check Engine Light '99 Jetta Wolfsburg 2.0
  115. 97 jetta gls auto, hose flange replacement
  116. 2000 1.8T Power Loss Fix
  117. '98 Jetta GLS
  118. 98 GL Remote Programming Problems
  119. 97 jetta glx - power window problems
  120. Stalling Emergency
  121. 98 jetta factory alarm problem
  122. Coolant Fluid
  123. Power Steering
  124. 1998 Volswagen Jetta - Not Starting When It's Hot Outside
  125. 1998 Jetta GLS
  126. 98 Jetta cracked window
  127. O2 sensor location-99 Jetta 2.0 4Cyl
  128. VR6 - 2.0 MAF swap
  129. epc light
  130. 2000 Jetta in dash CD player installation
  131. engine check light??
  132. 98' Jetta Alarm - Need Urgent Help
  133. TDI Maintenance Question
  134. radio reset steps please
  135. Jetta 2001 1.8t shuts down when....
  136. 97 jetta vr6 idling problem
  137. 98 Jetta GL Starter switch bad
  138. Engine shuts off at operating temp...Help!
  139. 2000 Jetta gls, parking brake light on, constant beep
  140. 99 Jetta Coolant Problem
  141. 1997 jetta 6 disc cd changer
  142. 1997 jetta 6 disc cd changer
  143. Broken lug key
  144. '02 Jetta alarm is possessed
  145. Appears to be a dead battery, but...
  146. 2000 Jetta Auto Gas Guage Stays at 1/2 Full All The Time HELLLPPPP!!!!
  147. 98 5speed reverse
  148. Power Steering Fluid
  149. VAG-com rookie
  150. MK3 Jetta Hood FOR SALE
  151. I Need a Comfort Control Module!!
  152. 2000 Jetta VR6 Trunk latch,EPC light etc...
  153. CEL reset switch?
  154. 1999 Radio / Onboard Diagnostics Problem
  155. No Power Past 20MPH/2.5-3K RPMS HELP!
  156. weird a/c problem
  157. thinking about buying a new jetta but....
  158. My EPC Light on 2001 jetta
  159. 2001 GLS Jetta Signal Lights Problem.
  160. High pitched noise, part II
  161. Comfort Control Module Location
  162. Looking for 2001 Jetta Front Bumper Cover
  163. i want more performance out of a 2000 jetta vr6
  164. Brakes/Rotor Question??
  165. New key programming
  166. keyless entry reprogramming (car not starting)
  167. CD Changer
  168. Check Engine Light...Water Pump?
  169. milage on 2.0L jetta
  170. Jetta Questions
  171. 2001 Jetta Acceleration Problem
  172. 1999.5 jetta acceleration problems
  173. '99 alarm module
  174. Somebody help-- please!
  175. Low oil pressure
  176. Temperature gauge not working right.
  177. Help! Alarm Still Not Beeping
  178. car wash/water coming in under glove box
  179. transmission slipping???
  180. VR6 Timing Belt/Chain
  181. 99 jetta 2.0 check engine light
  182. Power window assistance?
  183. hard shifting
  184. I have some parts for sale
  185. Need Help Bad
  186. kind of emergency, help!
  187. Tdi Wont Start
  188. performance question
  189. Air vent removal 98 Jetta
  190. ALDL (Computer Check)?
  191. AM radio reception problems--WHAT do I do-- I need my Talk radio--Please help
  192. questions about 2000 TDI
  193. can anyone please help
  194. Alarm doesn't beep?!?
  195. Jetta head unit placeholder
  196. 98 Jetta GL electrical problem (wet)
  197. 2001 Jetta front turn signal light bulb
  198. some problem
  199. Instrument cluster problems
  200. 97 2.0 Jetta questions...
  201. Changing VW Jetta 2000 headlamp
  202. 2000 VR6 Jetta - Major Problems
  203. Cracked head? Leakdown test...
  204. 97 Jetta Alarm
  205. '97 Jetta
  206. doors
  207. 2 Oxy Sensors or 1?
  208. High pitched sound
  209. 1998 jetta glx window problem
  210. 00 Jetta VR6 common problem!!
  211. 97 VW Jetta Clutch pedal
  212. Want 2001 Bora/Jetta, but don't know value
  213. radio won't come on after code is entered!
  214. 2001 jetta gls 2.0 I have 4 crappy problems!!! Please help me!!
  215. Changing AUTO tranny fluid 2000 Jetta VR6?
  216. side panel falling off
  217. Jetta Power Windows
  218. 2001 Jetta
  219. 2002 jetta 1.8T Clucth replacment
  220. 97 jetta VR6 GLX electrical problems...please help!!!!
  221. Replace Serpentine belt 2000 Jetta VR6
  222. 98 volks jetta 2lt/ gas
  223. '98 Jetta Alarm problems
  224. Engine Light, P0172
  225. 97 jetta stock radio
  226. 98' Jetta 2.0 Manual. Shuddering, CV Shaft?
  227. 99 Jetta alarm
  228. 01 Jetta Auto Transmission
  229. 2001 Jetta & iPod2car
  230. Tune up time
  231. Engine Code: 17057 Shift Solenoid E:
  232. 2002 Jetta 1.8T - won't start
  233. 97 GT AC Recirculation button not working
  234. Pass Door won't open in cold weather 97 GT
  235. 97 jetta passenger door not opening
  236. 18" RIMS FOR SALE
  237. 1999 jetta 2.0 cooling fan problem
  238. 1999.5 jetta issues..
  239. exhaust question
  240. 1997 Jetta 2.0- radiator/AC condensor mounting points
  241. transmission fix fluid?
  242. 98 jetta wolfs. 2.0 auto
  243. CD Changer Help
  244. Engine code Number P0673
  245. Parking brake squealing, too tight?
  246. 97 jetta idle problems
  247. 98 volks jetta 2lt
  248. 2001 Wolfsberg Jetta - oil plug stripped... ideas?
  249. 2001 Jetta Vr6 Grinding Start
  250. wanting a 2000+ jetta...
