View Full Version : '97 - '03
- 97 2.0L 8 valve upgrades
- 1.8t swap
- 2003 Jetta Speakers
- Help 97 jetta gl
- Thinking about buying 97 VR6
- 1999 Jetta: Armrest
- 98 GLX Idle Problem
- '97 Jetta won't start
- '99 Jetta TDI: Cutting Off
- 98 jetta problems
- window popped today. 00 jetta vr6
- 99 Jetta: overheating
- 98 GLX VR6 idling high adn fan turning on? ideas?
- 2000-2002 jetta wagon ratings
- 2000 Jetta Radio
- 98 Jetta: Water leakage
- 98 Jetta: Dome light
- '98 Jetta: Window regulator or motor?
- 2001 Jetta rear brakes
- 2000 radio odd problem
- 1999 Fan/AC Relay fs
- ok. Haynes manual does not cover 99-02 VR6 Jetta. wtf.
- Wheels for '98 GLX
- 1997 jetta 2.0L Ecm code P1582
- 98 volks jetta gls loss of power in all gears
- 97' jetta gl problem, any ideas?
- 99 Jetta --- no radio
- how to change the oil in my 00 jetta 2.8?
- 2001 Jetta GLS -- Reliable?
- 1997 Jetta Hates Water, HELP!
- Serious problem with my 2002 Jetta
- Jetta 1.8T Wolfsburgh Check Engine and more flaws
- Limp Clutch in 2001 2.0L?!
- 1999 Jetta transmission
- 1999 Jetta Probs
- 99 jetta fan problem
- 5sp Tranny problem on 97 jetta, in reverse.
- 1997 Jetta GT - airbag light indicator warning on.
- 2000+ Jettas
- 2000 Jetta Disable Warning Beep
- 97 Jetta loud cat conv/tiny engine stalls
- limp mode?Turbo shutoff 1.8t
- Boosting a 2001 jetta 1.8t, need chip? bov?
- 97 jetta struts
- '97 GLS Air Intake?
- 1999 jetta wont start
- 99-03 Full Bolt on GTI Front End Conversion Kit For Jetta
- Audi A4 1.8T Quattro or VW Jetta 1.8T wolfsburg?
- tuning my girl's '01 2.0 n/t
- 99 new 2.0 cold air, Help?!?!
- 03 jetta cold air intake
- 2003 Jetta Auto shifter stuck in park in very cold weather
- Fuse for Power Windows on 98 Jetta VR6
- 1997 Jetta Interior Light Question
- 97 Jetta 2.0 oil pressure warning
- 2.0 to1.8tswap in a 98
- alternator problem on 2000 jetta tdi
- Block Heater for 2003 jetta GLI
- 98 Jetta stuck parking brake
- looking for parts for my 98 Jetta GL
- 2001 Jetta sound system: removal
- SF Bay trade-in value for 01 Jetta GLS?
- 2003 jetta
- '03 Jetta warranty question
- oil light flashing/beeping on 01 Jetta GL?
- Reverse in a Six-Speed
- 2000 GLX bucking after highway trips
- 2001 Jetta - Remote Entry Dead
- 2001 TDI Inline coolant heaters
- 1999 Jetta perpetually low battery
- 97 Jetta AC not working
- 2000 Jetta TDI electrical problem???
- 99 Wolfsburg - headlight ? and slow accel.
- 1999 Wolfsburg CD Changer
- 00 Jetta - Clutch Pedal and Stick vibrate in 4th
- 2001 Jetta Engine Problem
- Sellin my pride and joy...2002 Jetta...bodykit, etc..
- '00 Jetta A/C Lights out
- Front Turn Signal on a 2000 Jetta
- 1997 Jetta GT Radio Replacement
- 1999 Jetta (i'm a girl and know nothing about cars)
- 02 GLX problems post tranny replacement
- Help,how do i Reset check engine light in `97 Jetta.
- 2001 Jetta Auto working on 3rd Tranny..
- 99 Jetta TDI
- What are the speaker specifications in a '97 Jetta GLX?
- how am i suppose to drain ATF out of a 98?
- 99 Jetta Driver's Door Alarm Module
- Question about 99 jetta
- 2000 vw jetta front bumper
- Can I upgrade the sound system of my 2000 Jetta?
- I think I have an electrical problem with my 97 Jetta GLS…
- 2002 jetta for sale
- 1997 disfunctional door locks
- Stock 2000 jetta 2.0L vs. Stock civic
- Should I buy a '97 Jetta GT???
- 2000 Jetta 16 inch Stock Wheels/Tires For sale
- 2000 jetta fuel line leak help need advice!
- 1998 Jetta Airbag Module
- 2001 jetta turn signals
- Replacing drive belt on 2000 Jetta V6
- '98 Wolfsburg; Rust. Rust?? Rust!!!
- What is the bolt pattern on a 2000 Jetta GLS??
- electrical problems 97' jetta GLS
- Molting. '97 VW - '04 VW
- looking for engine for 1997jetta GLX
- For Sale: 2003 VW Jetta GLS
- 2001 Jetta 1.8 T Leaking, help !!!!
- 2000 VR6 For Sale
- 99 Jetta GL battery replacement problem
- 99 Jetta antenna problem
- Jetta 2002 rims and tires 15 inch for sale
- selling 98 gl $5,800
- need help with gauge lights on 98 jetta
- Remote keyless 2000 jetta
- 2000 jetta ebay performance timing chips
- Heated drivers seat stopped working 2001 Jetta
- Selling My 98 Jetta
- 1998 Jetta GLX
- Buying a new '98 Jetta GLX
- 2003 Jetta CD error "3"
- Brake light problem on 99 1/2
- 2000 Jetta VR6
- 98 or 99 jetta?
- 03-Transmission Slams into Gear!
- '02 jetta Radio trouble
- How do you install a ractive air intake in a 97 2.0?
- 03 Jetta Airbag Warning Light
- 98 jetta mass air flow sensor
- Mass Air flow sensor 98 jetta
- 2003 jetta 1.8T abs and asr light
- 03 VW JETTA / GTI 1.8T 5,6 speed
- 2000 Jetta 2.0.... superchargers
- 2000 Jetta GLS 2.0 Engine Rattle?
- 1997 Jetta Radio Troubles
- 1998 VW Jetta starting problems
- getting a 03 wolfsburg
- door locks 97 jetta vr6
- Help with 2002 Jetta TDI
- What can I do to a 97 Jetta VR6
- Cold Air Intake for my 99 jetta IV VR6
- 97 ecu chip
- 1997 Jetta GL Won't Start at all!!!!!!!!
- 97 Vw Jetta Gl Tuneup
- 97 Trek Check Engine light
- 2002 to 2003 Taillights
- reprograming keyless in jetta 99a4 gl
- Does a 97 Jetta 2.0 have a timing belt?
- mk4 faq/diy.
- 97 Jetta cd changer
- 01 Jetta Tail Lights Installation
- 1998 VW Jetta GLS Radio Code
- putting a cam in an 8v 1997 jetta
- 97 VW Factory Radio Question
- 2003 Jetta GLX Price
- For Sale: 1998 VW Jetta GLS
- For Sale: 97' Jetta GLX
- 2003 Jetta GLI Seats
- 97 Jetta Driver Door assembly
- 97 Jetta GT with brake light problem
- Is the Jetta IV built on the same platform as the old A4? (x-01)
- 2003 Glx
- 2000 Jetta fuse box? I think tail light fuse is blown...
- 00/01 Jetta 1.8
- Reprogramming instructions on keyless entry remote for a 98' VW Jetta
- what kind of mods is there for the 2000's?
- 2002 Jetta GL A4 Body kits
- My 99 Jetta
- 98 Jetta GT 2.0 (Exhaust Question)
- FS 2000 Jetta GLS Vr6 5speed NJ $15,500.00 or b/0
- big brake upgrade kit for sale 99+ golf or jetta 1.8t or vr6
- For Sale: 1997 VW Jetta VR6 Stock 49K
- 2002 Jetta Stock CD & AM/FM Player Issues
- Just got a 97 Jetta
- 2000 Jetta headlight installation..help!
- 99 Jetta Tail LIghts???
- 2002 Jetta GLS 1.8
- Looking to get the 2002 Jetta Wagon
- Whats the best chip for 2000 VR6? (P-chip?)
- 2002 Jettas
- When are the VW shows for 2001?
| Quality Real Meat Nutrition for Dogs: Best Air Dried Dog Food | Real Beef Dog Food | Best Beef Dog Food
