View Full Version : Contour
Pages : 1 [2] 3 4 5 6
  1. Windshield Wiper motor problem
  2. 98 contour 2.5l dohc misfire/rough idle
  3. 1998 Idiot lights
  4. Please Help... 1999 Contour SE Stiff brake pedal but idle is fine
  5. 2.0 to a v6 motor swap
  6. Bad Acceleration, then brake pedal Hard
  7. 98 motor swap to 96 2.0
  8. 1996 ford contour
  9. difficulty of installing L3 white face reverse glow gauges?
  10. 99 contour ignition removal
  11. 1995 Ford Contour shimmies
  12. 98 Ford Contour Speedometer intermittent
  13. 98 ford contour overheating
  14. 1995 contour stalling
  15. Lower engine air leak
  16. '99 Ford Contour- Died while turning and will not start
  17. 98 Contour Vacuum problem??
  18. Motor Swap Question
  19. 1998 Ford Contour Roughly Idling
  20. 1998 Ford Contour Loud Grinding Noise
  21. 1998 Ford Contour Coolant Light On
  22. 1998 Ford contour Parking Brake Very loose how to Adjust
  23. 1999 ford contour
  24. Just bought a 97 Contour
  25. 95 Contour Motor Mounts
  26. Contour SVT speaker size?
  27. 1998 contour ignition
  28. Why does my 2000 contour jerk?
  29. 97 Ford Contour Power Locks
  30. Belt squeaking now smoking??
  31. Cold Starting -- Engine Block
  32. ford contour 98
  33. 1999 Contour Sale for sale
  34. 99 Contour Alternator
  35. testing
  36. 1999 CSVT Any turbo/ supercharger kits?
  37. 99 svt
  38. Transmission done???
  39. Cant find DLC connector in engine compartment
  40. car dies when it shifts
  41. Overall satisfaction with Contour?
  42. Trying to locate a minor vibration
  43. Check Engine Light
  44. 1996 for contour
  45. 98 Contour Won't Start, Need Help Please
  46. 95' GL for 98' GL...i think...
  47. Duratech 2.5 rattling from front of Engine
  48. 1998 contour 2.0 Battery light flashing
  49. 2000 contour svt shift problem
  50. 1999 Ford Contour Tranny
  51. heater problem
  52. 98 contour 2.0 O/D light is flashing
  53. 96 contour turn signal problem
  54. Any Ideas ????
  55. 95 2.0 Severe engine miss
  56. AT Transmission Exchange 98 Contour
  57. 97 contour engine electrical problem
  58. stupid question
  59. 1998 Contour
  60. timing belt jumping
  61. Gearbox
  62. Oil pump issues ?
  63. Will my car make it?
  64. Right front caliper sticks
  65. 2000 Countour Power Loss Different
  66. Lights / Electrical - pulsate
  67. 98 stalling-different from the others i've read
  68. sputters under load
  69. 95 Contour V6 cooling Fans won't turn on
  70. Change Contour DPFE
  71. EGR Valve on 95 Ford Contour V6
  72. PFE sensor signal high
  73. Cleaning MAF on 1995 Contour V6
  74. Auto shifter suddenly became harder to select gears.
  75. 1995 Contour V6 engine light on
  76. 1995 Ford Contour V6 Fuel Pressure Regulator
  77. 1995 Ford Contour v6 engine light
  78. 97 contour trans
  79. 1996 Ford Contour PCV Valve
  80. 2000 Contour PCV valve 2.0l 4cl
  81. 95 Contour anit lock and traction lock issues
  82. sluggish fixed/alternator & battery isssues
  83. sluggish fixed/alternator & battery isssues
  84. sluggish fixed/alternator & battery isssues
  85. Overheating
  86. 95 Contour 2.0 Gl Wont Start
  87. Considering a contour svt, any advice?
  88. 2000 ford contour please help
  89. 98 Contour GL
  90. 96 2.0 contour wont start any ideas?
  91. Plz Help 1995 Ford Contour
  92. 98 contour electric problem
  93. 1995 Ford Contour Help Please
  94. 97 Fod Contour. Door/Lock question
  95. 97 Ford Contour A/C problem
  96. '99 contour 2.0 ohc power problem
  97. 98 contour se problem
  98. 1995 Ford Contour questions :)
  99. 96 Contour GL Alternator Question
  100. Please Help me 1995 Ford Contour
  101. 2.0 liter zetec
  102. have 98 contour with torque converter code
  103. please help with my contour transmission problem
  104. Starter woes!!!
  105. Aggrivating electrical problem- HELP!!!
  106. can you list cars for sale for parts here?
  107. AC and Blower quit working, HELP
  108. 99 contour 2.0 no spark
  109. power hesitation after 3000 rpm
  110. Rear disk brake - 95 Contour
  111. 95 Contour Electrical
  112. please help with my 98 countore
  113. What is the normal temp reading on the 98 contour?
  114. 98 idling and braking rough??
  115. 98 Contour Help.
  116. 99 contour.... HELP
  117. '99 Contour in serious trouble, dont know what else to check
  118. 98 Contour running hot - not overheating...
  119. Squeaking under the hood??
  120. missing power
  121. Engine Seizes with starter installed
  122. fuel filter on 95 contour
  123. 1997 Countor engine cooling fan fuses
  124. Spark Plugs and Wires
  125. SVT Bumbers and Sideskirts??
  126. Svt Engine Rebuild/ Replacement???
  127. Back-up light switch
  128. 95 Contour Electrical Issues
  129. code 172 system lean on 95 contour 2.0
  130. 2000 contour using lots of oil smoking sometimes
  131. Engine stutters after timing belt changed
  132. ford contour 95
  133. New SVT engine in, but have 2 engine codes popped
  134. Ford Contour Alternator Location Possible Problem
  135. 99 contour stalls when warms up
  136. 98 contour vacuum problems
  137. Nitrous for my contour svt
  138. O/D Rough Shift
  139. 99 SVT transmission gears not engaging
  140. 98 Contour Blower Motor Fuse / Relay
  141. motorcraft spark plugs for 1995 2.5 liter 6 cyl contour
  142. Temp switch
  143. 96 Sport, sucks gas, idles rough in drive
  144. 1996 Contour Tranny Elec O/D - Blowing PCM maxi fuse
  145. 1995 Contour head gasket kit...
  146. Haders?
  147. Look for the TSB on VCT service
  148. Power Steering Fluid
  149. Stuck brake rotor on 98 drivers side
  150. power door lock problem
  151. '98 Contour LS w/ bad tranny
  152. 1999 Ford contour auto transmission leak
  153. 1999 Ford contour AC evaporator where is?
  154. 99 contour speaker install problem
  155. New intake now "new problem"
  156. 97 Contour squeeling noise when put in drive
  157. How to take off 99 contour door panel
  158. What mufflers for my contour svt????
  159. Is the 95 Contour prone to cracked heads?
  160. still haveing prbs with the 95 contour
  161. 95 Contour: Antifreeze won't go into block...
  162. fuse box question
  163. trans comes out of the gear
  164. 1995 Stalls...in motion
  165. Little info big problem
  166. 00 Contour STALLS AND STARTS RIGHT BACK UP
  167. I need more!!! Running out of MOD ideas for my SVT HELP!
  168. 95 ford contour 2.0 code 335 KOEO, code 336 KOER
  169. 1999 Contou SVT performs worse with TruBendz Y-pipe, Help!
  170. having erk & gerk problems with my 95 2.5 contour
  171. ABS pump failure - truth or BS?
  172. '99 tranny fluid check?
  173. 95 2.5 ovreheating when I can keep it running...HELP
  174. Al's Weekly Car Review!!
  175. "SVT on Steroids" MM&FF article
  176. 1995 ford contour 2.0 timing belt change
  177. Air Conditioning Pressure Switch Connector (99M03)
  178. How much $$ to Install a Trubendz y-pipe?
  179. 2000 Contour SVT specs
  180. no fire
  181. CD player/Speakers not working right
  182. 2000 Ford Contour
  183. loss of power
  184. Help!1999 Ford Contour ABS replacement cost?
  185. 99 CSVT missing under acceleration
  186. 95 Contour gl turbo
  187. 95 COntour parts
  188. manual tranny problems
  189. contour died
  190. MSDS Headers - Presidents Day Sale
  191. Performance tires on the csvt any suggestions?
  192. Back up lights stay on
  193. flashing airbag light
  194. Power Steering Leak
  195. 99 Contour 2.5L Question!!!
  196. 96 contour check engine light
  197. Timing Belt Issues
  198. Tru Bendz catless y-pipe good investment??
  199. Car will not start
  200. 99 contour svt running VERY ruff new cold air problem?
  201. Engine Problem?
  202. Stalling to not starting at all
  203. Thinking about remote start
  204. Check engine light??? 99 Contour
  205. Need used pass R headlight assy 98 SE
  206. 98 contour electrical problem
  207. contour.org site down...
  208. 99 ford contour tail light
  209. 1999 v6 struts
  210. do contour have timming belts?
  211. 98 contour trans spew out dipstick hole
  212. yet another question
  213. 95 Contour with blown head gasket for sale $400
  214. 96 contour problems
  215. Too Lean Air/Fuel mix
  216. 95 Contour with blown head gaskets for sale $400
  217. 98 ford contour
  218. 96 4 cyl making noise turning left
  219. 2000 contour brake lights wont go off
  220. Running out of mod ideas!
  221. 1998 contour electrical problem
  222. 1998 Door won't unlock
  223. 2.5L DHOC- timing chains and crank shaft
  224. 98 contour 4cyl starts and stalls
  225. Looking at '00 Contour SE Sport
  226. 1995 Contour won't start unless i disconnect battery then reconnect
  227. Flickering Lights
  228. Flickering Lights
  229. contour svt 3.0 sable/taurus swap
  230. contour svt fast or flop?
  231. 95 Contour SE 5 speed Electrical Problems
  232. idle problem!!!
  233. Jet chip for 1999 contour svt??
  234. transmission sporadically downshifting
  235. Need Serious Help
  236. 99 contour svt cold air intake???
  237. 1995 Ford Contour AC/Fan/Belt/Timing
  238. Hard starting and flooding. but many new parts
  239. i neep hp
  240. 96 Contour GL loss of power when wet (Battery)
  241. exhaust smells of sulfur, 96SE
  242. lost
  243. Speedometer quit working
  244. 1999 contour, hummm noise
  245. 98 contour running rough
  246. 98 contour
  247. '99 Contour LX
  248. 4 lug rims
  249. engine wont start
  250. Iac
