View Full Version : Contour
Pages : 1 2 3 4 [5] 6
  1. SVT Contour videos needed!!!
  2. 98 Contour SE No heater blower
  3. a/c clutch is "jingling"
  4. Looking to make a 2.0 Escort site
  5. ABS out when wet
  6. Transmission/Speed sensor Problem
  7. VIN # help
  8. new engine help
  9. 2000 Ford Contour rattling noise
  10. Turns off while in reverse
  11. 1998 Ford Contour Fuse Box
  12. For those that care...dyno results from yesterday
  13. beyondloadedSE quest
  14. Flasher replacement
  15. How to locate the paint code?
  16. Moisture in Headlight Assembly
  17. oxygen sensor
  18. Stalling 1999
  19. 00 Contour Airbag light stays on
  20. P0171 system too lean(bank 1)???????
  21. SCT Tuning Package Anyone?
  22. leaky fuel tank
  23. no heat from heater
  24. looses power when at half tank gas or less
  25. new cup holders for 98+
  26. changing break padds on a 2000?
  27. Trans fluid change
  28. Taking off the governor
  29. Blinking Overdrive light
  30. Intake
  31. Burning Plastic??
  32. 1996 Ford Contour starting and stalling problems
  33. engine light on "95 contour????
  34. Only 2 forward Gears
  35. Problems with Cold Start- Trans or Engine?
  36. shaking, really bad with AC!!! HELP!
  37. Rotor Problems. I can't remove them...
  38. bank1 oxygen sensor (by firewall)
  39. Scan Codes P1381,P0125, P1131
  40. 98 p 1131 code fix
  41. Gear Shift Problem...
  42. random switch
  43. air bag code 51
  44. no heat
  45. How do I use the overdrive?
  46. SRS Air Bag Warning Light Flashing
  47. EGR Woes Continue
  48. 95 contour constant high idle
  49. 98 ford contour question
  50. need help with transmission/mechanic
  51. No Turn Signals Or Blower Motor
  52. Code P040?
  53. P133 & P171 Codes on 96 Contour
  54. Thanks to Jesus...lol
  55. EGR and Cat "Check Engine" Codes
  56. Cyl 4 Misfire (Code P0304) 2.0 Liter. Stumped!
  57. Contour Hot and Jerky
  58. Trany Problem!
  59. OMG Guys help!
  60. 2000 Contour hard starting
  61. Still having problems....need help
  62. 95 SE question
  63. Stock AMP
  64. 98 Contour Trunk leaking
  65. 98 Automatic Trans Jumps between 1st and 2nd
  66. Wheel trouble 95 Contour
  67. Head Replacement Tips?
  68. Back on the road
  69. Upgrades
  70. Exhaust Question
  71. Remote starter
  72. Brake lights no working, 3rd brake lights is working?
  73. Traction Control - 98 SVT Contour
  74. Cold Start Problems with a 98 Bi Fuel
  75. Grrrr
  76. 98 contour SVT
  77. custom SVT one-off
  78. throttle cable
  79. Back with more questions
  80. Contour Stalling
  81. Seats
  82. P1131 Hell!
  83. overheating
  84. Check Engine Light - Need Advise
  85. Bolt on add ons?
  86. das anyone know how transmission range sensor works
  87. 1998 code P1131
  88. contour 96 automayic transmission
  89. brake pads
  90. SVT Contour or 300zx
  91. What to do to my Contour?
  92. 98 Contour SVT Catalytic Converter??
  93. 1998 Contour smoking from glovebox
  94. Inoperative Temperature Gauge
  95. 98 Contour Shuddering/Stalling/CEL
  96. 98 contour IAC LOCATION
  97. 1995 contour transmission jerks
  98. 96 Contour "Check Engine" light
  99. Breaks i cant get the dums on!!
  100. Buying SVT some advice please.
  101. 98 contour stalling
  102. 1998 Ford Contour
  103. Question on the driver seat
  104. 98 Contour 2.5 swap
  105. No forward or reverse
  106. Back with another question
  107. 99 Contour 4cyl
  108. TDC Location (crank pulley)on 99 Contour
  109. '96 Contour electrical problem/please help!!!
  110. Cleaning of MAF sensor?
  111. VCT Solenoid
  112. Neutral safety switch
  113. signal light replacement
  114. Mods
  115. Subwoofer Power cabel/Window Crank
  116. 1996 Ford Contour GL no spark HELP!!!!
  117. more questions
  118. serpintine belt replacement
  119. 95 Contour A/C Problem
  120. '96 Ford Contour
  121. ignition cylinder replacement
  122. i got a ques.
  123. i got an idle prob
  124. fixed "Need help contour 96"
  125. Need help contour 96
  126. '96 Contour cannot start(it doesn't crank at all)
  127. Here is a funny question
  128. car hard to crank and sometimes shuts off
  129. Intake Question for a 98 2.5L
  130. Ignition Module?
  131. Stupid Question from a pretty dumb person...
  132. Rough Idle Only in Drive - Neutral okay
  133. Will a Borla fit my countour?
  134. Car is Toast?
  135. speaker cover
  136. "EGR" Repair
  137. cooling fan on 95 contour
  138. What's wrong with my car?
  139. new rotors and pads
  140. 3rd Gear Grind
  141. Question
  142. Gas Gauge Issues
  143. please help!...
  144. Need Help!!!!!!!!!!!!
  145. car revs up by it self....
  146. 1995 cotour tranny prob.
  147. 96 Contour - idle fluctuates with a/c on...
  148. 98 ford contour(catalytic converter)???
  149. emergency break light sticking..
  150. Air Conditioning gone wack
  151. No tach.. can i put one on?
  152. Contour knock sensor
  153. 95 contour power steering cuts out
  154. 99 Contour SVT Cosmo Racing Short Shifter?
  155. 96 4cyl contour
  156. some electrical problems
  157. window lift motors
  158. why won't my ar cd player play any sound?
  159. water pump on 98 contour gl 4cyl
  160. 2000 Svt Need Info. On Brake System
  161. Wacky Contour Problems ~~ Help!
  162. 1996 2 liter 4cyl contour running hot
  163. 96 Ford contour w/Transmission Problem
  164. Heating Issues
  165. Installing Cruise Control on My ride
  166. Daytime Running Lights
  167. 1998 contour svt f/s clwr fl
  168. 98 E0 SVT Contour for sale in NC
  169. radio
  170. 98 Contour automatic transmission problems
  171. svt contour performance parts.
  172. Shimmy in 98 Contour V6
  173. All air blows from defroster only...
  174. O2 sensor larger question
  175. Ok, so where is it??
  176. oxygen sensor install
  177. '95 contour passenger side door needed...
  178. Air Bag Light code 41!!!
  179. 96 Contour Clear "Check Engine" light
  180. just spent 130 on a new stereo at auto zone
  181. 99' svt check engine light
  182. 1995 Ford Contour 2.0 auto tranny problem....ELECTRICAL? JUNKYARD?
  183. Installing Universal Oxygen Sensor
  184. svt stall problems
  185. Motor Knocking
  186. Replacement 02 sensors
  187. Moonroof Motor
  188. Code Meanings
  189. Need more Info on this code
  190. 1995 contour overheating
  191. 800 bucks for a break job?
  192. 96 Transmission
  193. one running board missing, o2 sensor
  194. svt contour
  195. SVT Tranny problems
  196. ignition off, engine still runs
  197. sensor Help
  198. trans help
  199. 1995 Ford contour GL tranny slip drive to overdrive please look...
  200. is this a good deal?
  201. Help temp gauge dont work 1995 ford contour gl 2.0l
  202. 96 Contour Stalls when normal temp
  203. Need strut assembly for a 1995 ford contour gl 2.0 dohc what cars would be applicable
  204. Bosch Plantium +4's goods/bads 1995 ford contour gl 2.0 dohc
  205. 98 tour zetec cat
  206. 95 contour transmission trouble
  207. What can I do with a Non SVT?
  208. Stereo System Wiring
  209. Wtb: Svt Uim
  210. Fan light and dash/gear selector lights
  211. '98 Contour GL
  212. Ford Stereo installation
  213. auto to manual
  214. Catylitic Converter Problem?
  215. 96 contour will not turn over
  216. Contour 95 GL Atx - Is it a transmission breakdown
  217. Anyone Know of some good speakers to put in??
  218. PCV Valve
  219. 98 Contour probs please help
  220. 98 Contour rough Running
  221. contour forum
  222. 1999 Se Sport Factory Amp or Harness Problem??
  223. blinking airbag light 95 contour
  224. 1997 Ford Contour Electrical Problem
  225. WTB: Stock Zetec Fuel Rail
  226. 1996 contour se
  227. MODIFIED SVTs
  228. Changing the PCV Valve......
  229. Performance
  230. Engine Swap
  231. Help.... Confused and Engine Running Crappy!!!
  232. New Website!!!
  233. Oxy Sensor/CheckEngineLight/Major gas Problem
  234. Help,,,,Engine codes obd1 type
  235. Where do I lift to set on jack stands?
  236. 99 contour amp problems
  237. 98 contour problems with idling
  238. brakes question
  239. 98 Contour overheating with new t-stat & w-pump
  240. Vortech Supercharger!!! $ Reward!!!
  241. Cold....won't start
  242. Left turn signal running too fast
  243. Programming Keyless Remote 00 contour
  244. Mods
  245. 1998.5 SVT For Sale. $5,500 obo.
  246. Miss at and just off idle
  247. Is this a good ideal????????
  248. Car won't start, Crankshaft Sensor?? How do you change this?
  249. don't quite know what I should do...
  250. getting codes
