99 contour 2.0 no spark
dabov
07-17-2007, 04:59 PM
I have a 99 contour 2.0 code 3 with a no spark condition. It has been periodically stalling for the last year, maybe once every two months, then would fire right back up. I have ohmd the coil pack and it falls within specs. I replaced the crank sensor and still no spark. The timing belt turns when cranked over by the starter. Is there something I am missing besides the PCM. The ignition module is integrated in the PCM. The fuel pump engages when ignition switch is turned on. Anything on this would help.
dabov
07-27-2007, 10:47 AM
found the problem. three wires to the pcm were damaged, including the one that receives signal from the crank sensor. runs great
