95 Contour 2.0 Gl Wont Start
Dantheman67
08-14-2007, 09:53 AM
I need help starting the car, i have replaced coil pack, Spark plugs and wires, Fuel Filter, CatConverter, Oil change, Mass aIR FLOW sensor went out a while ago when pluged in it got up to 30 mph only. When unpluged it drived up threw the gears, like normal. Ive checked for spark im getting spark, Ive check the shrader valve and it comes out ok, got good pressure in front out and behind fuel filter. I really need help any advice is much appreciated. Thank you
Davescort97
08-15-2007, 03:24 AM
When MAF is unplugged it resorts to a rich mixture by default. If you only get to 30 with it on you need to replace or clean it. I couldn't tell by your post if you replaced it or not. If you have ignore this.
carlos80
08-16-2007, 06:37 PM
Check engine light on? If so what codes?
