All power went out and won't start!!!!!
Terika32
02-29-2008, 03:11 AM
Please help me!!! I was driving down the road and my 99 intrigue gls was running perfectly fine and all of the sudden the power went out and the car died!! It will not make a cranking sound or even try to do anything. When I turn the key my fuel pump runs and my interior lights work. My power locks work but no radio, no dash, no turning over, no nothing!!! We checked all of my fuses and they all are fine. I hope someone can help me fast. I am not sure where to go from here. I hope someone has some ideas before I have to take it into the shop and get charged 60 dollars an hour!!!!!
I also wanted to add that my SES light does not come on. For that matter NO lights come on on the dash. My emergency flashers work, interior lights, and fuel pump priming. That is all I can remember happening at the present moment. I am gonna take my battery out and have it checked tomorrow seeings I can not drive my car anywhere to have it checked. I pray it may be as simple as the battery, but my luck is never that good! SO please any other ideas would be great!!!!
panzer dragoon
02-29-2008, 05:38 AM
toggle the ignition switch around a few times. =Could be an ignition switch problem. Check this site out for the info since it's a common problem.
Could be a battery issue also = not enough power to turn the engine over. How old is your battery?
LittleHoov
02-29-2008, 05:52 PM
like panzer said it could very likely be an ignition switch problem, try toggling between the "off" and "on" positions a couple times and see if your dash lights up, ill bet if it lights up the car will start that time.
Another thing to try is to simply leave the key in the "on" position for a little bit, it may make things flicker on and off and otherwise go crazy, which is a good thing.
Many ignition switch problems can be solved simply by removing the ignition switch and cleaning things up really well. Here is a link to the directions to removal
http://www.automotiveforums.com/vbulletin/showthread.php?t=736656&highlight=ignition+switch+removal
Also pull the boots off the battery cables and check for corrosion under them, but im leaning towards an ignition switch as well.
Terika32
02-29-2008, 08:33 PM
Well my battery is 2 years old. I bought a pretty cheap one from WalMart because I was moving out of the country 2 weeks after the original ac delco battery died on me. I didn't want to buy a real expensive battery if my car was only going to be ran every great while for the course of a year. My dad would take my car out for a drive once a week for a 15 or 20 minute drive just to keep things going good. So I know the cheap battery I bought might be the issue...but you never know I might get another year or two out of it. I took the battery out today and am gonna take it up to autozone to test it tomorrow. This is the thing that sucks...my car is parked at my house and is super far from my dads house where all of the car tools and testers are!!! So I can only do one thing at a time. But tomorrow I will find out about the battery. My cabels looked pretty good and not too much corrosion.
I tried to fiddle around this morning with the ignition. I turned it on and off for a minute or so...but nothing. Everything stayed the same....when you say leave it in the "ON" position for a a little bit. How long are you talking?? 5 minutes, 10 minutes, or longer?????
I am so glad you people are out there to help me. I know some basics on little car problems from watching my dad fix our vehicles all my life...but lets face it I am a daddies girl and when he isn't here to do it all for me I am a bit lost!!!!! And I am a girl struggling with the job market so don't have the money to take it into the shop!!!! I am sure some of you may understand!! Thanks again and I will post again tomorrow after I find out about myu battery!!
LittleHoov
03-01-2008, 01:00 AM
Sitting for long periods of time and short trips are hard on a a battery, but that doesnt explain why it wont start. Unless the battery is just completely shot.
If there is no change after maybe 10-15 seconds at most in the on position theres not much point in continuing. That was just my experience when i had ignition switch problems was that if you let it sit in the on position, or toggled back and forth eventually the dash lights would come on and the car would start that time.
How does the car react to jumper cables?
panzer dragoon
03-02-2008, 04:41 PM
[QUOTE] My cables looked pretty good and :dupe: not too much corrosion. :dupe: /QUOTE]
Any corrosion is generally considered bad. Tell them you need your battery "load tested" --> autozone and others do this for free.
Harbor Freight sells a 12 volt battery load tester for $10-20
Those connections with corrosion need to be cleaned off or cut back to new metal.
LittleHoov
03-03-2008, 12:16 AM
Good way to clean battery cables, and my new favorite, is to mix up a solution of water and baking soda (look in your fridge) and soak the cable ends in it.
The wire brush method still works good too.
Terika32
03-09-2008, 04:32 PM
Well my battery is fine....we put a new ignition switch on my car and that was not the problem. So I am out $100 for that. So does anyone one have any more ideas for my car. I am thinking it is electrical but not sure where to start.
83cutlass
03-09-2008, 05:42 PM
Is it a 3.5L or 3.8L? The wiring is different between the two.
83cutlass
03-09-2008, 05:45 PM
All right I have an idea. Check the Batt #1 60amp Maxi-fuse in the underhood fuse block. Check all the Maxi-fuses while you at it.
Terika32
03-09-2008, 07:24 PM
To answer a couple of the questions about my car.....it is a 3.5L and we did check all the fuses under the hood and on the passenger side panel inside the car. All the fuses are checking out. This stuff sucks I tell you! Gracias a Dios I have not had any major problems with my car before but this one problem is turning out to be worse than having 10 problems!! I am thinking I will have to have it towed to the shop and end up paying a ton of money because I don't know anyone that works on the electrical of the cars!!! :uhoh:
panzer dragoon
03-10-2008, 09:40 AM
How do you check your battery? Explain your process.
=A correct voltage reading is not enough. =Battery must be load tested.
Could be a loose fuse box ground.
betes99
03-16-2008, 01:00 PM
Did you check the alternator?
trigued_08
03-25-2008, 12:10 AM
Some garages or auto parts stores will scan your car for free for diagnostic trouble codes. Make sure they scan the ECM(engine control module) and also the BCM(body control module) and read any trouble codes that may be stored and also if the codes are c=current or h=history. Do this first and if you can`t pull any codes from either module then more than likely you will have to replace that module. Also check for a loose major ground wire, these ground connections usually consist of a a few black colored wires of varying gauges bolted to the engine block, transmission, or firewall, clean and tighten them if you find them loose. Usually this type of problem is a short to ground or a problem with the BCM. You said all the fuses are good and normally it wouldn`t be a fuse if you have interior, hazard, and you hear your fuel pump priming. Hope this helps:popcorn:
