View Full Version : Caprice
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15
  1. Should i buy another caprice?
  2. Nice option for stereo in any Caprice
  3. Caprice hood ornament
  4. spring rates
  5. White Smoke
  6. Caprice Lean's to one side
  7. 89 Caprice 305/2004R to 350ZZZ/350 turbo... Are the drive shafts different??? HELP!
  8. 95 Caprice/Impala Hood Light repair
  9. What is an 85 Caprice with 70K Worth
  10. New Temperature Gauge
  11. Peeling clear coat
  12. 88 caprice classic electrical woes.
  13. Replacing Valve lifters
  14. Finally fixed my car!!!!!!!!!!!!!!!!!!!!!!!!!
  15. No instrument panel lights in 1988 Caprice
  16. idler arm replacement
  17. Courtesy/Clk fuse keeps blowing
  18. PCV Valve...
  19. 91 Caprice intake gasket replacement
  20. 96 Caprice surging/misfiring
  21. caprice 91 body sheet metal parts
  22. Winter Maintenance
  23. Inconsistent RPMS
  24. 88 caprice vibrates roughly at stops & in park only
  25. 87 Caprice 2 door rear quarter molding
  26. Want to change color
  27. Hard Starting - no fuel pressure
  28. The Change Oil Light
  29. What i found when i took off the valve covers..
  30. roller lifter stuck
  31. Burning oil at idle
  32. bolt pattern
  33. Fuel Tank
  34. Blower motor problem
  35. Brake pedal does not return
  36. Can you replace oil pan gasket w/out lifting up motor?
  37. AC pump question.
  38. Part number for push bumper?
  39. Cash for Clunkers and my opinion
  40. Shift points
  41. Rebuild differential on 85 caprice
  42. Something's busted, thought it was my rearend
  43. 1988 caprice radio problems
  44. new headers......
  45. Some bad news.
  46. 89 9c1 posi?
  47. Valve stem seals
  48. One more A/C problem to address
  49. AC question
  50. Air conditioning issue
  51. New headers not fitting
  52. Body Bushings
  53. Endangered car for sale.
  54. Fitting Bikes in the back seat
  55. 95 Chevy Caprice 5.7 Overheating
  56. rebuild or buy new
  57. AC= significant power loss
  58. 95 chevy caprice tranz
  59. Trunk light doesn't work
  60. fuel pump
  61. hard to start when cold
  62. 87 Caprice Classic brakes pulsate
  63. Car Turns Over But Wont Start..
  64. Starter not properly engaging flywheel
  65. ABS light/codes
  66. 1985 Caprice leaks at speedometer cable
  67. By-passing the pass key fault chevy caprice
  68. Return of the Caprice
  69. Crackling Noise from Cat Converter ?
  70. RIP Caprice Classic LS 94-09
  71. 89 Caprice U-Joints
  72. 1989 caprice bucking/loosing power
  73. Battery died
  74. '85 Caprice - More than 1 fuel filter?
  75. 95 lt1 roller rocker arms
  76. Getting an "old" car
  77. Freeze Plugs??
  78. 1985 Chevy Caprice leaking Fuel fumes
  79. CB Radio mounting
  80. Data Logging
  81. water in tank
  82. 96 pulling to the side
  83. instrument cluster swap
  84. Trans Acting Up
  85. Will a truck 95 truck 350tbi go in 92 caprice
  86. Car Is Acting Weird..Need Some Help
  87. Burning Oil cont.
  88. Exhaust Manifold leak... lead to Engine issues?
  89. I think i found the noise
  90. The Horn is Stuck On
  91. Need tp Tap on Starter to Make it Work
  92. 95 caprice lt1
  93. 93 LS Wiper Issue/ Possible Electrical Problem...
  94. Car Tries to Self Destruct at Mechanic's
  95. 95 SS swap into 91 caprice. Has anyone done this or can you help?
  96. Paper tag on rear springs
  97. car is missing when driving
  98. Strange noise coming from my engine
  99. Rear end leaking
  100. 94 caprice finnaly fixed this was the problem
  101. 1995 caprice power steering gear box
  102. 92 Caprice no acceleration
  103. Question about gear changing
  104. Wind/road noise in 96
  105. HELP!! removing/installing bumper filler (front)
  106. One light not working after HID installation
  107. A/C recharge
  108. Removing engine...
  109. 85 running bad
  110. 95 caprice rear diff
  111. 95 caprice no start
  112. 93 widows
  113. my 1987 2 door caprice
  114. My first Vlog stars my caprice!
  115. Fuel test & ecm location
  116. 96 Vibration at idle
  117. 85 problems need a little help
  118. flowmaster mufflers
  119. 95 lt1caprice
  120. chevy misfiring 1989
  121. Help!!! 94 caprice no acceleration at all
  122. Time to get rid of my 85 Caprice, Maybe
  123. 85 Wheel Cylider Repacement / Leaking
  124. 86 caprice. 305 to 350. drive shaft lengths?
  125. 77 caprice trying to turn itself over after shutting off
  126. Two more annoying problems
  127. SPID codes 96 Caprice
  128. 96 caprice lt1
  129. 96 impala chime issue
  130. Wider tires in back
  131. 95 caprice lt1 swap
  132. My Flowmasters Keep Blowing Out Smog..
  133. 94caprice?'s optispark,digi speedo,etc.
  134. Rear end sag
  135. What Is The Best Brand For These Parts?
  136. 77caprice coupe LOUD rear brake noise
  137. 94 Wagon disc brake conversion.
  138. current draw
  139. determine posi for 88 caprice
  140. fuel sensor question
  141. Is It Best To Replace The Battery
  142. Speedometer not working
  143. Doors for a 2 door chevy caprice 1984
  144. Help Please
  145. Changing diff oil
  146. Engine Swap
  147. 91 caprice steering column
  148. i think i just messed up big time
  149. 95 caprice timing
  150. Whew, just did "repairs" and upgrades!
  151. 88 chevy caprice seat
  152. 90 Caprice lower engine noise?
  153. Cost of repairs to a 87 Caprice Estate
  154. 95 caprice programmer
  155. 88 caprice exhaust issue
  156. Valve stem seals
  157. Fender and door from an 84...Will they fit on an 87?
  158. disc brake question
  159. Is there a good police vehicle restoration enthusiast forum?
  160. Now the transmission is slipping.
  161. 95 caprice wiring harnes
  162. 95 caprice computer ecu
  163. Looking for left front fender and driver door for my 87
  164. Which Post Do I Disconnect On My Battery
  165. 95 caprice classic heads
  166. Oil burning smell in 96
  167. I Just Messed My Front Driver's Side Door Up..Question
  168. 95 caprice tranz swap
  169. Lowering and wheels?
  170. New Hesitation thread
  171. exhaust?
  172. Burning a LOT of oil..
  173. 1988 caprice questions???
  174. STILL cant get timing correct
  175. 87 caprice 2 door
  176. 1980 Caprice 350 small block **HELP**
  177. Window motor replacement
  178. My Front Bowtie License Plate Keeps Falling Off
  179. Engine additives
  180. 94 Caprice Ignition Problems?
  181. problems with a/c
  182. Transmission linkage
  183. Where is everyone???
  184. how big is my gas tank
  185. Removing moldings on 96
  186. Noisy exhaust on 96
  187. what is a Lt1?
  188. Hesitation
  189. I Replaced My Shocks..But The Ride Is Still Bumpy
  190. She died again, and this time it seems final.
  191. 1994 caprice won't move!!
  192. 1987 caprice classic fuel line question
  193. Ok So I Broke The Oil Dip Stick Shaft In My Caprice
  194. 85 slows down wen i push da gas
  195. 91 Caprice Wagon Liftgate Release Buttons Failed
  196. Swapping 3rds in an '85 Caprice
  197. Help !!!
  198. Just when i thought spring was here for good..
  199. 96 Cap stalls when put in Reverse
  200. Time to lube the speedo cable.....Again
  201. 79 Coup, camshaft pulley?
  202. Spring is in the air.
  203. Wheel Bearings
  204. Distributor Cap
  205. Wiper switch
  206. What Is All Needed to Replace Brakes..
  207. Muffler/Exhuast question....
  208. Lift cups or lift springs?
  209. 94 caprice problems help!!!!
  210. 88 Caprice Power Issue
  211. Headers for my 87 brougham
  212. 85 actin up
  213. hoses
  214. Heater Core Question
  215. K&N air filter worth it?
  216. Ok So My Car is Burning Gas Like Crazy
  217. Big cars vs. smaller cars
  218. Metal on Metal Squeak
  219. steering and suspension
  220. Rag joint eliminator?
  221. 1992 caprice runs rough
  222. My caprice 0-60
  223. Coil Springs
  224. Busted glove compartment
  225. 90 Caprice, strange electrical problem.
  226. iPod dock in caprice
  227. Help!!!!!
  228. 1996 Caprice Wiper Motor Problem
  229. spring rates
  230. Different horn?
  231. Power Steering Fluid leaking - from line
  232. Original Caprice documentation and brochures
  233. What have you done so far?
  234. '82 Caprice Classic and Impala Brochure
  235. 1993 9C1 radio ?
  236. How do i use cruise control?
  237. Post your Caprice mileage here.(Part II)
  238. lookin for pictures of a 1979 caprice
  239. brakes...
  240. '89 Caprice 305 TBI Problem......
  241. Would A Bad Ball Joint Cause
  242. engine swap?
  243. 94 Air/water leaking
  244. Odometer
  245. 85 Caprice rear end replacements
  246. Brake problems..
  247. question about my 95 caprices
  248. Wiper problem
  249. won't start in cold weather
  250. 96 caprice 4 door window problems
