View Full Version : Caprice
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15
  1. 327 in my 94 caprice?
  2. Transmission fluid
  3. 1993 9c1
  4. Engine oil?
  5. types of spark plug wires
  6. Exhaust question
  7. Ok So My Car Died On Me Yesterday...
  8. m/c solenoid check engine light
  9. 6-way Power seat?
  10. Hesitation
  11. Where should I get my alternator?
  12. 1982 Caprice Classic
  13. Gas mileage?
  14. installing a new alternator
  15. Also..Has Anyone Swapped Out Their Stock Headlights For
  16. What Is All Needed To Replace Shocks..
  17. electrical conversion question
  18. Another possible trans issue?
  19. 94 Transmission Possible Issue
  20. Timing Adjustment
  21. Cowl Induction or Ram Air
  22. 95 caprice dies after remote start install
  23. I have no SPID Label
  24. The best Caprice movie is Predator 2.
  25. 1987 Chevrolet Caprice. Need Some Help
  26. 91 700r4 repeat front pump leak
  27. Water leaks
  28. Throttle question
  29. rear defroster fuse
  30. oil all over passenger side under hood
  31. no start
  32. Crazy heater
  33. defrost
  34. Time for a new radiator
  35. how do you flush heatercore
  36. Alternator
  37. My new exhaust
  38. Rear End Clunking
  39. shifter linkage
  40. she took a bullet
  41. radiator fan is always on / so so heat !!!
  42. Wiper/washer blows fuses
  43. Stuck choke flap wide open
  44. help 94 caprice no taillights
  45. Rust on floorboards, gas tank, etc
  46. ECM necessary for cruise control? '87
  47. Blower problem - 1995 Caprice
  48. motor
  49. Holden Caprice 2005 Royale V8
  50. Sold but not forgotten
  51. 95 Caprice Hp?
  52. Noooo! Not another code!
  53. alternator
  54. ECM question
  55. power range on a 305?
  56. Car audio/electrical question
  57. caprice seats
  58. tires..
  59. Knocking Noise.
  60. my caprice is dead...... lovely
  61. what will fit 1986 Caprice Chassis?
  62. Problem with 1981 Caprice.
  63. 275's maybe?
  64. Gas Prices
  65. Keyless Entry Upgrade in my 95 Caprice Wagon
  66. Next Question...Tire Size For 82' Box
  67. Blown Fuseable Links...
  68. what year wagon rear ends are interchangable
  69. heater core issuses
  70. car leans
  71. non a/c heaterbox ? and posi rear end
  72. trunk question
  73. 1988 Caprice Cruise Control issues.(Where's the Fuse?)
  74. Key reminder chime?
  75. LS1 swap in my '93
  76. What color is my paint?
  77. 3 things
  78. a few odd problems
  79. a few odd problems i'm at a loss for ideas on these
  80. '87 Is computer necessary for heater to work?
  81. hail damage repair?
  82. instrument panel lights
  83. pinstriping removal
  84. Battery problem
  85. idles stumbles, then falls flat on its face
  86. Synthetic Trans Fluid. switch to or not.
  87. Differential fluid change?
  88. side mirrors
  89. New wheels.. New bolt pattern?
  90. Another paint question
  91. Which wheels compatible with a 94 9C1?
  92. brake block
  93. thought i would let yall see my work in progress.
  94. So I took my boxy to pepboys
  95. replace outter door handle?
  96. any one know if the newer 305 have roller lifters
  97. paint question
  98. shaking at high speeds...i think.
  99. towing capacity
  100. blue exhaust on startup
  101. i think its about time for an engine flush
  102. Check engine light code 174...
  103. lowering an '86 wagon
  104. 87 Caprice carrying on
  105. Moraine or bendix master cylinder?
  106. ignition wirers for alarm starter
  107. steering wheel problem
  108. 84 Caprice - Electric Choke not opening
  109. no pass no start
  110. Rare 9C1 magazine check it out!
  111. Newbie looking to get a 87-90 Caprice
  112. right side exaust doughnut gasket
  113. 1989 caprice rattling noise
  114. Code 14?
  115. 84 Caprice V8 350 5.7 Emission question
  116. 305 c.i.d life span
  117. Caprice Mpgs
  118. Blinker arm
  119. 86 Caprice TAILIGHTS WONT WORK! PLEASE HELP!!
  120. Wiper Switch
  121. Excessive play in ur steering?
  122. digital dash flicker
  123. caprice question
  124. just throwin da idea out there....
  125. Painting
  126. Car Wont Start Vats Wire Spark Help!!!!
  127. Sub/amp/electrical questions
  128. Update on the rear end noise
  129. Slow to heat/defrost
  130. ABS System.
  131. long road trip maintenance suggestions
  132. Oh, squeaky shocks
  133. GMC Jimmy Tires?
  134. idling problem info hesiatation/cutting off
  135. A few car show pics (mostly B-bodies)
  136. A post for Silicon :-)
  137. Installing alarm system
  138. 94 Caprice V8 'Engine light on, but no code"
  139. Strange rear end noise
  140. altenator change?
  141. Bouncing at idle?
  142. need some performance advice on a 305
  143. blower problem
  144. running prob's on a 79 caprice
  145. IGM needs replaced, how tough of a job?
  146. can some one get the history report on this car
  147. I just got a caprice
  148. Update on my car
  149. Window Tint
  150. Canada or not?
  151. i think i have a altanater prob
  152. 91 caprice leaking coolant leaking coolant
  153. Chrome Strip around Windshield
  154. 84 caprice dies at idle and stalls out in gear
  155. Carpet between rear seat and window
  156. '94 LT-1 proper fuel pressure number?
  157. weird problem
  158. Cant remove my valve cover
  159. A statement and a question
  160. Body work finished
  161. Smelling gas under the hood
  162. cutoff/kill switch
  163. I hit a tree
  164. Did some body work...
  165. EGR Valve
  166. be careful what you buy
  167. From manuel to power windows
  168. 95 caprice for sale?
  169. 85 305 Questions
  170. car stalls when shift into reverse when warm
  171. New video posted
  172. Results from my Emissions test...
  173. wont run
  174. 84 caprice door
  175. catalytic converter?
  176. Headliner replacement help...
  177. could fuel be my issue?
  178. Different sized alternator cases?
  179. Will a radiator from a 94 9C1 go into an 1980?
  180. still in need of advice
  181. 2 problems
  182. Ugh!
  183. more vacuum and EGR questions
  184. heater core?
  185. radio question
  186. Go 305 go!
  187. knock at startup?
  188. still having trouble
  189. 86 parisienne just died and will not start
  190. Im going to buy a caprice
  191. ac coversion
  192. tachometer?
  193. Update!
  194. Air cleaner question
  195. High Mileage Engine - Oil
  196. diagnostics codes
  197. what is this?
  198. 88 4.3L caprice RPM problem
  199. idling problem 3
  200. Rear End Questions
  201. rip off!
  202. idling problem 2
  203. wanted tail lights 1976 caprice classic
  204. Cuts Out !!!!!!!!!! help
  205. 9C-1 Transmission Specs
  206. 94 9C-1 LT-1 Starts, dies...starts, dies...
  207. rear end
  208. 9c1 springs
  209. great, just great.
  210. What causes speedo needle "parkinson's"
  211. Radio and Horn not working
  212. Wire Wheels
  213. does your speedometer move by itself?
  214. Oil leaking and possible coolant leak
  215. rattling clicking in steering column
  216. Sway bar end link dissapeared
  217. ABS Light on
  218. Nothing but new posts works?
  219. Carb adjustments
  220. Whoaaaa
  221. do you keep pictures?
  222. vent problems
  223. Is your caprice dirty?
  224. 95 9C1 idle/shifting issue
  225. 94 caprice rear outer bearing replacement
  226. 1966 Caprice
  227. brake issue
  228. 95 Caprice brake question
  229. I hate my front sofa (seat)
  230. it's like new!
  231. car smokeing i think is valve seals no sure tho
  232. power steering hose
  233. Your thoughts?
  234. Gas Vapors
  235. 1989 Caprice Overheated
  236. 2 wire or 1 wire alternator? '87 Caprice
  237. Pics of new dual exhaust on '87 Caprice
  238. Turn signal won't cancel
  239. Need Help
  240. Need AC help!
  241. hesitation problems
  242. No brake lights or turn sigals
  243. caprice has hesitation
  244. Where can I get these 9C1 wheels?
  245. Tilt wheel's all wobbly '87 Caprice
  246. OD of heater hoses '87 Caprice?
  247. can someone help me?
  248. cant find parts
  249. Factory battery hold down 87 Caprice what's it look like?
  250. Help
