View Full Version : Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. egr system/knock sensor problem
  2. Clutch burning smell
  3. Pssss Turbo!!!
  4. This car drives me nuts
  5. help, I nerver get a response
  6. Buying a New Key - 2002 SE
  7. quick tranny question
  8. Brake size/rim fitment question
  9. Drilling Through Firewall
  10. Error Codes PO440 and PO446
  11. Window mounting assembly
  12. Quick as a whisper
  13. losin my hp
  14. rpm all over the map
  15. mafs questions..... please help a SR guy!
  16. Does anyone know codes PO440 and PO446?
  17. PO400.....EGR Valves......Where is it? How can I clean them?
  18. 88 maxima light
  19. ecu/error 0514
  20. Need Maxima parts CHEAP!!!
  21. Transmission/Shifting problem
  22. Nissan stalls
  23. Nissan Maxima turbo with 476whp video
  24. Fighting about a Goat
  25. Engine Swaps??
  26. We got another one
  27. WTB: Aftermarket Y-pipe
  28. Evolution A32 and A33 Group Buy
  29. HID problem
  30. Clock and interior illumination
  31. airbag light keeps flashing?
  32. Book to rebuild alternator &
  33. 89 maxima vg30e map or maf?
  34. guess what happened to me today?
  35. DON valve body
  36. alignment
  37. looking for clutch advice
  38. Tail light replacement
  39. Stalling at Idle/Low RPM's-2000 Max
  40. Stalling at Idle/Low RPM's-2000 Max
  41. 1993 Maxima voltage regulator location??
  42. Mileage?...
  43. Programing Keyless Code
  44. can't alarm my alarm
  45. Duralube??
  46. Max wattage??
  47. fs:foglights both $170 shipped
  48. Let's brag
  49. boost
  50. FS NEW 7" LCD or Trade 4 BodyKit
  51. 2004 Maxima Headlights
  52. Mevi
  53. 03 Maxima - need help changing rear pads
  54. clear corner tail lights
  55. Changing fog lights
  56. 2002 Max 255HP, 2004 265HP WHY??
  57. HOT !! New Nissan Shift Knob: Picture Inside
  58. my 2000 I30 makes a fart noise by my glove
  59. Help on Smoother Ride & Tire Alignment
  60. Strut replacement on 89 max
  61. Knock sensor and O2 sensor
  62. need help with steering prob
  63. help asap
  64. Southeast Maxima Drag Racing Meet: 02-29-04
  65. I'm 03'd up!!!
  66. New "Turbo Max" video
  67. oil leak...
  68. Where is Sensor 1, Bank 1? (99 Max)
  69. Parking Brake Malfunction
  70. Need installing instructions for CAI for 2000 Max
  71. Error Code P0135
  72. I need information on accessories for my Maxima
  73. Racing Seats Anyone?
  74. Anyone interested in a Ram-Air type of thing for intakes?
  75. New new forum with a question
  76. Car died while in motion, now it wont start and alarm is going off!!
  77. door remote
  78. Eclipse GT
  79. What would you get next?
  80. intall o2 sensor/ bad gas mileage
  81. Precats on a 2002
  82. 97-99 headlight upgrade on my 96
  83. Who has redlinemax carbon fiber hood ?
  84. Code 135, I need new O2 Sensor, DIY??
  85. stock or not
  86. Short shifter worth it?
  87. Matrix Clear Corner Install
  88. Handsfree install on 03 with Bose
  89. Warpspeed Ypipe for $160 shipped!
  90. ECU Screw is missing!!! Help.
  91. Bose speakers
  92. HELP! I want to install factory foglites on my maxima.
  93. fog lights
  94. Auxiliary in on 1997 i30 stereo ?
  95. how bad would i get beat?
  96. maxima stalls after deceleration, stalls at idle
  97. 94' Maxima Shuddering Problem
  98. idle air control valve for 2001 maxima
  99. Front Body Kit?
  100. air coming in
  101. Seeking donations to repair a max!
  102. debate
  103. cv boot
  104. Cold Start Problem = Don't really need to worry
  105. 97 Nissan Maxima
  106. New Nissan Flagship!!
  107. 2004 Maxima SE Intermittent Cold Start Problem
  108. 1993 Maxima Reverse Gear does not engage
  109. 1992 Maxima - low mpg, knocking during driving, idle searching
  110. 95 Max SE with intermittent starting problem
  111. 95 nissan maxima cold start problem
  112. Fuse Panel Location?
  113. Tail Lamp Fuse Blowing
  114. Factory Alarm System: lights are not flashing after i lock doors ?
  115. how do you reset a ECU on a 2000 Maxima
  116. FS: 1996 Nissan Maxima GLE in No Virginia/ DC area
  117. Need a little help on my 92 Max
  118. License Plate Light problem, Please help as MAXIMA FAILED in inspection
  119. Maximma 03 tires
  120. changing fuel filter 2000 maxima
  121. 4th gen instrument cluster lens & climate control button?
  122. Galant, camry and accord..
  123. Cefiro rear parcel tray removal
  124. 99' I30 Outside Air Temp sensor, calibrate?
  125. Cefiro chamber and alignment troubleshoot.
  126. new engine for 96 nissan maxima se
  127. 1996 Maxima Stall/Shutdown when Idle
  128. infiniti I30 '96
  129. 1984 maxima?
  130. 2000 nissan maxima shuddering
  131. 97 Max GLE funny noise on starting
  132. 96 Turbo Maxima VS 2001 F150 lightning
  133. Help!!! I think my starter is out.
  134. Check Engine Light On
  135. Can 2002 HID headlights be used on 2000 GLE???
  136. hey houston maxima owners
  137. Maxima specific DTC Codes
  138. help With My Radio Save Me
  139. Where is the trunk release
  140. Stalling with emergency break
  141. Fuel Options
  142. knock sensor
  143. knock sensor
  144. Need Advice w/ Error Codes on 99 SE
  145. Dealer Can't find my Starting problem!!!
  146. Camber adjustment kits?
  147. 1996 Maxima Heater Problems
  148. tokico suspension kits any good?
  149. help ... I am new to cars ....
  150. front rotor loose?
  151. what is the correct way to hook cargo net????
  152. The ultimate nonturbo max??
  153. unhooking odometer
  154. having factory alarm problems
  155. Need advice on what catback to get
  156. Speaker install question
  157. 4th Gen- Keyless Entry Unlocking lights blink?
  158. 01 max rear rotors
  159. 98 maxima brake rotors
  160. resetting "service engine soon" light
  161. 95 Maxima - Timing chain replacement
  162. Can high octane harm engine?
  163. What could cause bad gas mileage?
  164. Best way to sell my running but beater 1987?
  165. looking for keyless entry remote
  166. noise from the front of the car...
  167. Blown MAFS...again
  168. '01 Maxima fast idle
  169. r32 cefiro heaD LIGHTS
  170. 1995 Nissan Maxima starting problem
  171. Gas Mileage on a 98 Maxima
  172. selling my beautiful maxima
  173. How can I add significant horserpower to my 03 maxima
  174. 94 Max Automatic Trans Problem
  175. Remote start
  176. Crazy Tach needle not a cable issue.
  177. reverse glow gauges 97 nissan maxima
  178. Hard Starting on 1995 Maxima Help!!!
  179. Help..98 Maxima Wont Start =(
  180. Help! Rear Brake Cylinder won't compress
  181. Need help, DTC's P0300 and P1320
  182. head lights
  183. Locating Ignition Coils
  184. Mevi?
  185. Throttle Position Sensor
  186. How to build a 94 Max
  187. searching for the right ecu upgrade...
  188. Maxima Racing - Timeslip Database
  189. Traded in my 2000 Max
  190. oil changing question
  191. Max with Headers!!!
  192. 93 maxima timing belt
  193. 2 Noises too many + windshield wipers wont work + CD Error! PLEASE HELP
  194. Nismo parts at dealerships?
  195. woodtone shifter
  196. I35 Insufficient heat
  197. Check Engine after JWT ECU mod
  198. Need help with Fuel injectors
  199. Shuddering/Rattling on a 92 Maxima GXE
  200. Oxygen (O2) Sensor
  201. 1989 Maxima Fuel Line Replacement
  202. Proof that having a new car isn't always great?
  203. 97 nissan maxima weird starting issues... HELP!!
  204. Every thing you ever wanted for Free!
  205. Group Deal: Tein S. Tech Springs (4th & 5th Gen)
  206. Engine knocking
  207. 02 sensors
  208. Car shifts into Overdrive too early
  209. FS: '97 Black Maxima 5-speed in LOS ANGELES
  210. Rear rattle sound... PLEASE HELP!!! Maxima 2k
  211. F/s sprint springs 95-99
  212. Foglight 9006 bulb super white LED
  213. F/S Frankencar Apex'i Intake w/ bent midpipe
  214. Turbo 94 maxima
  215. New Corvette
  216. 99 Maxima Rear Brake Piston
  217. 1991 Nissan Maxima Starting Problem
  218. Synthetic oil
  219. I'm looking for fog light
  220. 2000 Maxima advice
  221. About RB24-S
  222. Need to Know?
  223. 92 se manual tranny
  224. 1998 Nissan Maxima Fuel Filter
  225. headlight and general light 95 questions
  226. Leather care
  227. Mevi ?
  228. Cam Position Sensor HELPPPP!!!!
  229. '92 Maxima Stuff.
  230. '87 Maxima Computer Problems
  231. Not maxima related, but what the hell...
  232. 95 Maxi Questions
  233. 1998 Maxima SE Cycling start ups. Car Ground in the Tranny??
  234. Is my check engine light dead?
  235. 2000 GXE Maxima vs. 2001 Honda S2000
  236. 1998 Maxima 28k-PROBLEMS Need advice
  237. Basic Exhaust Question
  238. Installing 2001 Lights on 2002 / 2003 Nissan Maxima
  239. my Bose....
  240. A33 maxima's
  241. My Exhaust Falling Apart!
  242. Kyb Gr2?
  243. wats the bolt patterns on 98 maxima?!?!
  244. O2 Sensor Heater Circuit Malfunction? Help?
  245. New Drifter
  246. Help! Noise under hard acceleration
  247. 5th Gen Maxs
  248. HID's Stolen!!
  249. who know about electric shock
  250. V8 Maxima?
