View Full Version : Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. help fitting G35 rims on my I30
  2. 1989 max turbo????
  3. Y-pipe and Cat.
  4. ebcm gm#12389539 inop repair or replace?
  5. Looking for parts for a 95 max
  6. intake system i bought off ebay for my 95 maxima..need info
  7. Rear brake
  8. '96 maxima front brake squeal- help!!!
  9. 1989 Mxima Body Kit Help
  10. 1989 maxima speedometer
  11. Service Engine Soon Light
  12. Custom turbo kit for 95 Maxima
  13. Wheel Question?
  14. anyone knows where to get wheel center caps for I30?
  15. Aftermarket radio/steering controls
  16. Stillen Intake... worth it?
  17. Cali Knock Sensor
  18. 92 maxima brake line leak
  19. Changing Radio on '94, screws will not come out - HELP!
  20. Exhaust pipe 2000 SE Max
  21. Headers
  22. 97 Cefiro Wiring help
  23. 2002 I35 Power Seat Memory
  24. Advice on Buying 2000 i30t
  25. paint job
  26. Stereo bracket removal
  27. Infiniti to drop I35
  28. does nissan make a tip or sport tronic transmission for maxima?
  29. Help please!
  30. Acceleration Problem with '98 Maxima
  31. Rear Speaker Question 97 Maxima
  32. Adjusting the clutch cable
  33. Brake specs on 4th gen?
  34. Engine Swap
  35. Keyless Remote Programming Instructions
  36. transmission upshift problem
  37. WANTED - Passenger side wing indicator cap and holder for..........
  38. considering buying a maxima
  39. Decoding error code
  40. 98 Maxima Remote Control Problem
  41. 97 max error codes
  42. **Infiniti I-30 Body&Parts Wanted**
  43. 98 Maxima parking brake problem
  44. 1993 Nissan Maxima (alarm need help)
  45. Strut life
  46. location of egr valve on a 99?
  47. When driving on the highway or not a perfect road is the outside sound easily heard?
  48. 2001 Maxima. Service Engine Soon Light is ON.
  49. For Sale: 2001 Maxima
  50. 1996 maxima does not start on first turn of key
  51. Check Engine Soon
  52. Engine Knock
  53. 92 maxima missin?
  54. Exploded bulb-now what?
  55. Engine Swap
  56. Engine Light ON??
  57. 95-96 Red/Clear Tails on eBay
  58. CG-Lock from Tunervision - Worth it ?
  59. corner lights
  60. Need help w/ fuse diagram
  61. Air bag
  62. WTB:// A31 Cefiro Grille
  63. audio system needed
  64. FS: 98 max 95k buffalo area
  65. Angel Eyes
  66. Maxima '89
  67. Opinions On 2k -2k1 Max
  68. Dash Lights Out After Removed Factory Radio.............does Anyone Know How To Fix?
  69. steering fluid leaking
  70. 98 maxima tire / tranny shake?
  71. 92 maxima need info!
  72. O2 sensors, Knock sensor, EGRC Solenoid Valve
  73. Since I know nothing about cars.....
  74. Knock Sensor and ECT Sensor
  75. My Maxima
  76. 2004 Maxima Headlight Aim Adjustment
  77. Brake and Engine light on
  78. Bose problem
  79. 1993 Air Bag Warning Light
  80. Windsheild molding
  81. first time at the track
  82. 5 spd Maxima vs. 5 spd Prelude.
  83. Passenger door mirror
  84. A 2000 Front On A 96
  85. ECU Codes
  86. gotta question
  87. maxima of middle east
  88. Just got my 99(slightly modded)
  89. a31 cefiro grille?
  90. Help with ecu code please
  91. 99 Blower motor resistor
  92. Pics of 03 Max
  93. 99 Max blower motor resistor
  94. MPG on 03 Max
  95. Be aware!!
  96. +20hp Power Mod Chip Nissan Maxima????
  97. ECU Code 05 05
  98. 94 nissan maxima blower
  99. upgrading tires - wider profile
  100. Knock Sensor
  101. 2001 Maxima rear door will not open from inside or outside
  102. help with tranny problems..
  103. first time mod, 95 maxima, help wanted
  104. Keyless Entry Help Wanted!
  105. Where is the Front Left O2 sensor located?
  106. adding power seats 92
  107. Need Help...
  108. cefiro headlight bulbs?
  109. Parting out a 96 maxima plus some goodies
  110. 2004 Maxima Elite ?'s...
  111. cleared headlights
  112. 2000 Nissan Maxima - Difficult Acceleration
  113. Inside CV boots for 96 Infiniti I-30
  114. Rear brake pads installation
  115. Sluggish 96 GLE
  116. Tints
  117. ECU code help please
  118. 02 maxima vs 02 audi a4
  119. PIAA fogs
  120. 95 maxima gxe for sale
  121. Anyone know how to stop a squealing pully?
  122. ecu code 0509
  123. 93 Maxima ignition will click relays, but not turn engine.
  124. HELP tranny problems
  125. 95 SE cold start problem fixed
  126. whiney hum (ho hum)
  127. hi everyone
  128. Cefiro Maxima puzzle
  129. 91 SE - stalling, no power - RESOLVED!
  130. 2003 3.5 engine swap into 98 3.0L max
  131. Wood dash trim with charcoal plush interior?
  132. what's happening to my '88: starts, noise, stalls
  133. 2004 maxima stalls on occasion at startup
  134. dash trim for 2003 max
  135. little help
  136. Wtb:oem Rims For 2002 Gle
  137. 2 Problems
  138. tire size
  139. 2003 Bergundy Maxima SE
  140. 2004 maxima tranny
  141. 18's or 19's on maixma opinion
  142. FS: 1995 Ruby Pearl Maxima
  143. engine light
  144. Where is the PCV Valve for 00'
  145. need help
  146. Tuning up my 2001
  147. 91 maxima bad engine noise
  148. Carbon fiber hood on 5th Gen
  149. urgent! question about ignition coil !!!
  150. 2002 Maxima gas door
  151. Instrument panel and radio display
  152. 91 Door Buttons
  153. help
  154. think about a 95 max
  155. PIAA Xtreme Foglights
  156. 3 problems
  157. Y-pipe
  158. 2003 Maxima rims
  159. what piston brake up grade can i put on a 95 max?
  160. what is this?
  161. 3 diff noises.
  162. Parting out 1989 Maxima.
  163. Any real improvements?
  164. Xeon Bulbs
  165. door lock problem
  166. Maxima Discontinued 2004
  167. ECU ERROR code: 0104 (Vehicle Speed Sensor)
  168. Engine Ground Wire kit worth it?
  169. FOR SALE: (MAX/I30) BUDGET Y-pipe, STILLEN RASB, REESE TRAILER HITCH
  170. Rim Fitting Info
  171. QUESTION?!?! Whats the Best Suspension out there For a 97 Max?
  172. VQ30DE Compression Check
  173. 92 Max with Engine Stalling at StopNGo Traffic
  174. Low Fuel light
  175. Lights for Bose
  176. ecu upgrade
  177. Reset my ECU???
  178. Help on checking ecu fault code on 2kse
  179. Stock Clarion Amplifire inputs/outputs
  180. Manual Tranny for '86
  181. Auto to 5-speed
  182. Worth it to install 6x9 spkrs on a 4th gen?
  183. Rear sway bar
  184. does over drive burn more gas
  185. How hard it is to install headers on 5th gen?
  186. some intake questions
  187. drive axle installation problem
  188. Performance parts?
  189. 1994 maxima automatic down shifting probelm
  190. newer rims on an old car
  191. 2000 Maxima hesitation under acceleration
  192. 1993 gxe, put in D won't run, trasmision problem?
  193. Pics of my car with rims...
  194. these any good?
  195. New '96 GLE, a few questions
  196. stupid question
  197. Gas Mileage 2000-2001 I30?
  198. what is the recomed tire pressure for 17" aftermarket rims?
  199. Garage Door Opener!!
  200. Newb needs help !
  201. 1/4 mile 0-60 times
  202. Window/Lock Switch Lighting
  203. Tire Shopping: 99 GLE
  204. check out the deal
  205. cold air intake and CD player
  206. F5 Hurricane Resistor Sensor Modification
  207. 1992 Maxima fuel return hose
  208. 87 maxima reverse lights not working
  209. steering vibration over 110km/h
  210. BOSE question, 03 Maxima
  211. will these rims fit my 2k1.....
  212. Need Help! Will 19x9s fit a 5th gen front?
  213. Couple of exhaust questions.
  214. 92 max burning oil.
  215. 93 maxima got her period
  216. polished mevi on ebay...
  217. 03 Berhundy Maxima
  218. good rear component speakers
  219. what exhaust do u have
  220. 97 Max idle problem in neutral
  221. Clutch fluid leak question
  222. 95-99 max vs 99 hoda civic SI
  223. This Is What I Need
  224. Intake Temperature sensor. Where is it ??
  225. 1996 Infinity I30: booming noise on highway
  226. i need help quick
  227. pace setter exhaust......good? bad?
  228. 95 maxima gxe for sale
  229. Dash and rear lights not working, HELP
  230. New rimmies
  231. what the hell is the flex plate
  232. AC Odor
  233. anti-freeze leaking from the back
  234. Rattling trunk
  235. Electrical Problem
  236. 1998 Wierd things happening
  237. 93 maxima blower switch
  238. Idle Problems
  239. My right headlight never turns off
  240. RVM rims
  241. Is Premium gas really needed?
  242. evaporater cannister/fuel tank
  243. I Need A Hood For A 2001 Nissan Maxima Gle
  244. Window down feature
  245. Can't get flywheel off, please help!!
  246. Help Where is connector for back O2 sensor
  247. MOdifying the IAT sensor with a Capicitor
  248. does anyone live in dallas
  249. Help the Chariot Spank old domestic at RANKMY RIDE !
  250. Elusive Part
