View Full Version : Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. 1999 I30 Chugging and stalling
  2. 96 Maxima - Keyless door lock- Windows go down?
  3. 96 Maxima, Hard Starting WHY??????
  4. What makes a maxima a maxima
  5. 1998 maxima front and rear speakers
  6. 97 maxima radio plays sound but no light
  7. advice on 2000 maxima...
  8. 1989 Cefiro
  9. windows go down no key no command..
  10. LoLOMGWTFBBQS!
  11. Service Engine Soon light came on
  12. Brake and +- light on infiniti 01 i30 (91k miles)
  13. Balljoints
  14. 2000 Infiniti I30 front end noise
  15. CV Boot
  16. Looking for '97 Maxima interior parts.
  17. 1996 Maxima runs rough and stalls
  18. How good are ceramic brakes?
  19. 96-00* Max Questionable?
  20. 96 GLE/Front-end collison/Remote entry not working
  21. INFINITI or Maxima rear lip Spoiler for I35?
  22. air conditioning problem
  23. First Drive: 2009 Nissan Maxima
  24. First Drive: 2009 Nissan Maxima
  25. Acceleration whistle: '03 Maxima
  26. 1995 max cranks but won't start
  27. Passenger side key code
  28. my Maxima Car (middle east)
  29. All brake lights dont work- 96 max
  30. Your opinion about this idea please!!!!!! And any tips you would like to give me.?
  31. Alternator Output
  32. 99 I-30 with lots of miles--Please Help
  33. No Engine Light
  34. impossible to remove cd player
  35. Whining Sound
  36. max probs
  37. Changing brakes soon, what kind would you recommend?
  38. Should I do this with my 98 Maxima?
  39. 95 maxima DTC 0407, hard to start, kicks back
  40. Metal noise when bump (sometimes)
  41. out of control window
  42. Change oil and brake
  43. Transmission Filter
  44. Is this true?
  45. How do you know when to check...???
  46. 96 Nissan Maxima code p0734
  47. How to suit up '00 Maxima
  48. 2000 Nissan Maxima w/ 77K miles for $5,500 a good deal?
  49. Brake Guide Pins - 99 Maxima
  50. 89-94 VG30E Maxima...Performance Parts?
  51. No Eletrical power till Engine Starts
  52. 95 Maxima slow and no power
  53. Help With Several Check Engine Codes - WEIRD!
  54. 96 Infiniti I30 Pulling
  55. OEM Car alarm keeps going off
  56. '98 Maxima Giving problems
  57. Metallic Popping Noise on Sharp Turns
  58. jumper wires get hot and spark
  59. Fuel Light
  60. Metal noise when turning sharply to the right
  61. Rough idle in gear 99 maxima
  62. 2009 Maxima
  63. 97' Maxima woes...
  64. '98 Maxima rough idle, hard starting.
  65. 99 maxima engine starts for a second or 2 then shuts off
  66. Headlights Stolen!
  67. Service Engine Soon light
  68. Locking or non-locking differential
  69. MAF sensor question - 2000 Maxima
  70. Problem with windows and locks
  71. 2003 Maxima GLE parts car... many parts for sale
  72. Bad Front Engine Mount?
  73. Car Is Making Weird Noises
  74. 00 max service light reset
  75. '97 Maxima Engine Cuts Off While Driving!
  76. "program Mode" For Nissan Maxima 2004
  77. 96 maxima hyper ground kit
  78. 93 Maxima stalls whlie driving
  79. Just bought a 4th gen vq30de... Time to fix it up...
  80. 2001 Maxima
  81. Help! '97 Maxima
  82. Help with 2007 Maxima!!
  83. VQ25 runs but stops under idle
  84. Battery draining power 94 maxima
  85. ABS Light 01 SE
  86. I am having trouble programming my new remote!!
  87. Looking for owners manual for 96 Infinity i-30
  88. Tech help needed if possible
  89. 95MAX stalls after 5 mins runs ok before and after
  90. Did the Dealer Screw Up My Car?
  91. Both front windows no longer working
  92. Love for maximas....and a little help
  93. WON'T START - left me stranded.
  94. 95 Maxima battery and alarm help
  95. I need help please!!!!
  96. I made a Maxima Calendar!
  97. 2000 Maxima rough idle and stalls only when cold.NO CODES?. Any ideas?
  98. New Owner Questions
  99. Rear Strut
  100. 92 Maxima GXE Cruise control, where to begin
  101. Wheel bearing, or something else?
  102. New 95 Maxima owner
  103. Programming 2001 or 2004 Maxima Key
  104. 01 Maxima SE Electrical
  105. I Need Some Serious Help Please!!!!
  106. No acceleration
  107. Should I Do It?
  108. Lowering Springs
  109. 95 maxima check engine light
  110. 98 Cefiro OE alarm going ballistic
  111. How long have you had your maxima?
  112. Vibration on idle and 30mph - 40mph
  113. I30T 98- Belt squeel wont go away & Fuse map needed
  114. 1994 Maxima - Axle?
  115. Keys
  116. Headlights and Tailights
  117. Engine wont turn over
  118. Air intake sensor location
  119. Engine wash
  120. Maxima Auto Trans Stuck in 1st Gear!
  121. Service Engine Soon light
  122. 00 Maxima Power Window Goes Up then drops by itself.
  123. Removing plenum off 2000 Maxima
  124. Overdrive...?
  125. Rattling/Grinding noise coming from front end, 97 SE 5spd
  126. Heres my STORY
  127. 95 max - hard start - HELP
  128. how to clear air bag codes
  129. Removing Factory Head Unit
  130. 96 Maxima w/ code p0745
  131. 95 maxima grill
  132. clutch prob.
  133. 2001 Maxima starter
  134. How may miles does your maxima have
  135. 96 i30 p0500
  136. 01 Max Cat Converter Hard/Easy Replacement
  137. 2001 Radio screen keeps going off
  138. Pending OBD II codes
  139. maxima overheating dont kno what to do
  140. Audio fuse keeps blowing????
  141. Tranny issue: Not shifting after oil change
  142. Maxima Break Squeak
  143. dealer and ntb exact opposite opinions
  144. I30 over heating
  145. 99 I30 stalling, HELP?
  146. Maxima Diesels
  147. Resetting the computer.
  148. Wierd noise coming from my engine....
  149. 2000+ muffler on 96 I30
  150. '00 I30 extended cranking
  151. 95 maxima no power Alt or batt?
  152. 97 max stalls
  153. noise in 2002 j35
  154. window inop
  155. CEL and 2 codes
  156. 2007 Maxima se. gas tank non fillable?
  157. Infiniti Navigation discs
  158. 97 Nissan Max curise control issue
  159. FS:1991 maxima garage sale!!!cheap!
  160. I30 Vacuum Hose Diagram?
  161. 90 max heat
  162. Maxima Codes
  163. Replaced Knock Sensor in 96 Maxima
  164. 00 Maxima, runs great, no power HELP
  165. Noises in 03 Max!!
  166. 2001 Nissan Maxima
  167. ABS Light
  168. I30 Fog Light Installation
  169. looking at a 2001 Maxima
  170. 90 maxima acting funny on start up
  171. P0174 Code
  172. Please Help!
  173. Ring gear access plate
  174. Front brake make noise
  175. I Need Some Headlights
  176. Knock Sensor
  177. EGR & oxygen sensor trouble codes related?
  178. 95 maxima firing order
  179. 97 max rad. support
  180. 95 maxima misfire code p0306.
  181. 96 maxima 3.0 engine will not start at all!! Help!
  182. 96 Maxima code PO130 again
  183. Power steering woes
  184. Ford Alternator in a 92 maxima
  185. 2000 Maxima not starting after starter install
  186. '93 maxima Sunroof questions
  187. 2000 Max SE - Rear Brake Caliper stuck
  188. Maxima Battery goes dead.
  189. i30 1996 - Review
  190. Fog Light and Bumper
  191. Injectors
  192. What does my car actually weigh?
  193. Clearence issues, any ideas?
  194. 2006 impala
  195. Should i attempt doing the axles on a 95 maxima my self???
  196. Throttle shuts off
  197. 1985 Max Speedometer is Erratic or Not Working!!
  198. 97 nissan maxima problem
  199. Repair Manaual for 2001 I30
  200. 2001 Maxima Leather Seats cracked
  201. Opinions on 2006 (new) Maxima 3.5 SE Price Quote
  202. injen replacement filter
  203. 96 I30 cabin filter
  204. 95 Maxima won't start screws up POS count
  205. Has this been done yet?
  206. Keyfob unlocking & windows
  207. Changing the Airbag Module in a 99 Maxima
  208. Struts and Springs 99 Maxima
  209. 93 maxima gxe drives sluggish after warms up
  210. 2K Maxima stalls when warm
  211. Maxima 99 misfires
  212. brake upgrade
  213. '95 Max warm start up miss?
  214. 1996 i30
  215. Which aftermarket parts throw up codes?
  216. type of gas
  217. Maxima No start No crank
  218. 1998 maxima good car ???
  219. Parting Out 1992 Maxima-Most parts available
  220. stalls on reverse
  221. just got a 96 and needs front end work
  222. just got a 96 and needs front end work
  223. Help with ideas for mods to a 00 maxima gle
  224. Which year are these Maxima rims?
  225. Question about stock Bose system in.....
  226. air intake
  227. BOse radio issues
  228. oem parts
  229. 92 Maxima High emissions at low speed
  230. thundering noise when pressing accelerator
  231. Problem with fans on '90 Maxima
  232. 97 nissan maxima se no start after accident
  233. Need Help with Inifiniti I30 (1996) knock sensor
  234. 96 maxima won't start - intermittently ??
  235. Rich fuel mixture
  236. Window Problems
  237. Anyone seen these on a car?
  238. Nissan Wire Replacement
  239. 5 1/2 Gen Maxima
  240. 98 Maxima GLE P0325 & P0400 fault codes
  241. 95 Maxima Sensor and suspension problems.
  242. oxygen sensor + knock sensor change on Infinit I30
  243. 1990 Maxima dash removal
  244. valve gaskets after accident
  245. Car shaking at speeds above 70 MPH
  246. I30 Performance Upgrades?
  247. I30 Dash Seperating above radio
  248. error code P0500(Vehicle Speed Sensor) - 1996 Nissan Maxima
  249. 98 Max - power steering leak
  250. heres a stumper for you gearheads
