View Full Version : Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Suspension and Rim info
  2. Doh
  3. all my Sh** is labeled in japanense!!!
  4. FS: '97 Stock Springs and Shocks
  5. need tran. for 98 se
  6. 92 maxima alarm won't go off
  7. Which cat-back exhaust?!?! Please Help
  8. which maxima should I buy?
  9. 96 Max, can I install the BOSE system???
  10. remote car starter
  11. Fan resistor question
  12. does anybody have one??
  13. Cattman Headers
  14. 2001 i30t transmission shifts very hard
  15. Sensors
  16. Will KYB dust covers work on GR2's?
  17. Help? I give you my maxima and 1,000 bucks! ... kinda
  18. how does this work???
  19. what axles?
  20. Maxima's new passive alarm will decrease your insurance
  21. 2003 Maxima vs. 1997 Grand Prix.
  22. you know jersey123 is an idiot when...
  23. 03 Nissan Insurance; Acura CL insurance
  24. how fast have you been
  25. 96 Max, where should I get it repainted?
  26. EVAP canister purge volume control valve
  27. GAB intake mod info needed
  28. KYB GR2 better than stock for 95SE ?
  29. Maintaince Info Needed!!
  30. nOOBY Question
  31. Fog Light
  32. Exhaust info
  33. 03 Maxima VS. 03 Acura CL
  34. codes again!!!!! after fixing everything
  35. 94 Max Audio problem
  36. 0701 multiple cycliner misfire, anyone has that?
  37. FS: 96 Maxima SE 5-spd
  38. For Sale, My rims!
  39. 1997 Maxima has slight drift to the right
  40. Need transmission for 93 Maxima GXE
  41. What year rotors will work????
  42. Almost Stalls
  43. MAF sensor and codes
  44. 18x8 Volks on Pearl White Max
  45. Been away awhile
  46. 97 Maxima 3.0 with 80K QUESTION
  47. dash sensor
  48. Defrost vents?
  49. 02-03 help needed
  50. Brake & Battery Lights
  51. For Sale: 95 Maxima GXE
  52. Parting out 89 Maxima
  53. losing Power...Electrical
  54. interior courtsey lights
  55. XM radio for 2004 Maxima (aftermarket)
  56. 93 Gxe V6 Dohc Hesitates And Cuts Off
  57. 02-03 parking light replacement?
  58. Master cylinder questions
  59. BOSE Problem
  60. skyline
  61. 2002 Maxima CD PLayer Problem
  62. New car... maybe??? Help? yes? please?
  63. o2 sensor change sound?
  64. tired of weak lights!!!!!
  65. Cost of CAI
  66. 00-03 Rear Sway Bar Suggestions
  67. 96 Max, How do i fix my spoiler LED's?
  68. New Ride
  69. Service in Question
  70. Where To Buy Replacement Fog Lamp??
  71. overheating
  72. 02 max 6spd short throw shifter
  73. Maxima.org ?????????
  74. 95-96 97-99 tail light difference
  75. For Sale Brand New Exedy Clutch $220 Shipped
  76. Maxima stock hp figures for 97-99 SE & GXE???
  77. 96 Max, Why does it keep hydroplainning?
  78. Clear Taillights - Home Depot
  79. P1320 warning light code on. Anyone know what this means?
  80. Where to buy parts...
  81. burn outs
  82. which rotors??????
  83. Conversion FWD to RWD
  84. auto transsmission
  85. Transmission Fluid Change
  86. 2003 Maxima tail lights
  87. Trouble finding this material...
  88. DIY transmission fluid change?
  89. ABS Dash Light
  90. 00 maxima timing chain
  91. Waterpump
  92. Need help with brake replacement please!
  93. 95 Max (4th Gen) - Fuel Cleaner Suggestions
  94. power braking/brake torque
  95. 2000 maxima stall on rev
  96. Short Throw Shifter???
  97. Need Help with Frankenar Install
  98. Toyota Scion TC
  99. Fuel Injector Problem
  100. Rear driver side wheel rolling tight....smoke/burning smell coming from the wheel
  101. Emergency In Md Need Brakes Now
  102. linking the dimmer switch to the clock
  103. PSA: "service engine soon" light - check it yourself
  104. blown valve
  105. Axle replacement. Anything difficult about this?
  106. Best Fuel Injector Cleaner?
  107. 00' needs diet.
  108. Beware Ebay bulbs!
  109. Anyone with 18"s on 00-02
  110. bleeding clutch
  111. good alignmentshops in Central NJ?
  112. Cali Spec Questions
  113. going to lose my car
  114. Air Flow/Exhaust censor causing this?
  115. Bose Radio Illumination
  116. Anyone else paranoid?
  117. shift kit or vb upgrade
  118. Clutch problem!
  119. smoked a preppy strap in his jetta
  120. Nissan Maxima SE For Sale
  121. anywhere online where i can get exhaust diagram for 89-94 GXE ?
  122. Knocking from front of the Maxima
  123. Advancing the timing
  124. Shift boot/E-brake boot purchase...where to buy?
  125. Components of stock '96 Bose system?
  126. Engine light with new cone filter
  127. 3rd time a charm???
  128. new ride
  129. Question about doing a I30 LSD tranny swap
  130. 1987 Maxima VIN # ??
  131. 2003 Maxima Insurance
  132. AE Pedal Installation
  133. factoy foglights...
  134. Windshield Problem
  135. Strobe Kits
  136. Sup newbies???
  137. turn signals
  138. K&N Air Filter...Worth it?
  139. anyone with y-pipe as only exhaust mod?
  140. Polish headlight & windshield?
  141. 02 MAX Rear end alignment
  142. Which Cold Air Intake?
  143. Caliper Replacement
  144. Parking Light Fuse
  145. ECU error code 0704
  146. Car Domain Sites?
  147. Bodykits...Have any of u ever?
  148. Bodykits...Have any of u ever?
  149. Bodykits...Have any of u ever?
  150. Sub Ruins Rear Tires?
  151. 97 Maxima lights dim, radio turns off
  152. PICS - Floyd Bennett Field
  153. 1996 Maxima SE Bose Stereo System Problems
  154. 4th Gen Maxima Auto Climate Control
  155. Brake pad replace questions
  156. PLEASE help :-)
  157. *NEW* Genuine Nissan Maxima Floormats !!
  158. Bought a '96 SE, now I'm leaking oil a day later...
  159. 1995 maxima
  160. What happened to www.maximaforum.com??
  161. Door handle codes unlock and lock doors
  162. Anyone know how to reattach a spoiler?
  163. "Whirring noise in 1st gear"
  164. Shifter squeek or chirp
  165. synthetic motor oils For Turbo & SuperCharged maxima
  166. forum
  167. Frankencar...Deadbeats???
  168. stalling prob. w/ 3rd gen maxima
  169. Hum and Vibration from right front of 99 Maxima SE
  170. Size of axle hub nut (97 SE)????
  171. difficult to explain
  172. Maxima.org
  173. GLE/GXE & SE suspension question
  174. OIL CHANGE QUESTION 1997 Max 3.0
  175. Groaning Sound from Rear pads 97 Maxima
  176. First weird thing ever happened
  177. anyone have a plastic tray for the dash lying around?
  178. steering rack leaks - what are my options?
  179. steering shaking b/w 60-80mph
  180. Problem codes HELP
  181. bad paint on 2000 se
  182. How do I test Fuel Injectors?
  183. are these shifters any good? why so cheap?
  184. Spark plugs
  185. 2002 Max w/Bose 6 disc question
  186. f/s intake, mafs, altezzas, and iat sensor
  187. Electrical problem, HELP!
  188. Left the gas cap off...
  189. Parting out a 94 Maxima
  190. replacement of struts
  191. no start 95 max
  192. new keys
  193. 1993 Maxima Fuse Problem
  194. LED side mirror turn signals
  195. maxima shirt
  196. WARPSPEED Y-PIPE (95-99) Maxima
  197. Looking at a used max..
  198. Clear Side Markers....
  199. 2000 I30T speedometer head
  200. 00 Max Bose Rear Speaker
  201. Opinion....
  202. Quick Question B4 I go back to my Mechanic
  203. Replacing Rear Struts Easy?
  204. how to change out Oxygen adn Knock sensors for 96 I30
  205. Should i buy??
  206. Should i buy??
  207. more reliable? altima or maxima (95-99)
  208. Blew my F***ing MAFS again
  209. Bose rear speakers '95
  210. 87 Intercooled, Turbo for sale.......
  211. Weird problem
  212. where do you mount the air temp sensor
  213. difference between a 98 Nissan Maxima GLE and SE
  214. 2003 maxima problem!
  215. latest pick
  216. Which intake? Which Y-pipe?
  217. will 10.5's fit
  218. I don't usually post this stuff
  219. Found keyless code, need help using it.
  220. Check Engine Light From Trunk?
  221. 1996 corolla, camry or maxima?
  222. front strut bar
  223. Possible starter problem
  224. Need Rims 4 Bolt 15 To 17 Inch 205/215 45/55
  225. 97 Maxima at dragway Video
  226. Starting Problems Max98gle-one More Time
  227. stumped...whatsup with my brakes
  228. Opinions on Xexon Theft??
  229. Nissan Maxima MAF Help!!!!!!!IMMEDIATE RESPONSE PLEASE!!!
  230. R32 Headlight Mod
  231. simple air cond. question
  232. 96 maxima egr temp sensor
  233. better but not quite right!!!!!
  234. does FTSB work well?
  235. parts that fit 93 max
  236. My car went dead and I need your help..
  237. For Sale: Brand New!! Injen Cold Air Intake Still In Box
  238. 89 maxima engine swap
  239. speedometer is failing
  240. 1993 maxima emission problem?
  241. P1105, Wath is this?
  242. tranny on '94 slipping
  243. HELP Maxima just quit!!!!
  244. 04' max 350z parts
  245. Error code 31. Replace ECM???
  246. Knock Sensor and C.E.L.
  247. HVAC Controls
  248. Airflow Direction
  249. Weird noise from front right wheel.
  250. Suddenly running on 5?
