1996 elantra wont start
hat70087
08-19-2007, 07:09 PM
is there a fuel pump fuse for this one and where is it located?? i looked under the hood and on the driver side fuse box, but no luck. was driving and it just stoped running, cranks, but won't start, any suggestions, as i'm pertty car stupid.:banghead:
Jalmir
08-20-2007, 12:59 PM
Are you sure it's the fuel?
For the engine to work you need fuel and spark, so you should check if there is fuel and spark. If there is both you need to figure what is the problem.
There are no fuel pump fuse but a fuse pump relay does exist but a relay (even that old) are long lasting and will not just stop working like that.
So check if there is fuel comming up the fuel rail and if so check if you have sparks at the spark plugs.
