1996 Elantra Air Bag Light On
frafreg
10-15-2005, 04:58 PM
The 15 Amp fuse for the lighter popped. I went to replace the fuse and accidentally removed the fuse below it for the air bag which is also a 15 amp fuse. When I put both fuses back in, the air bag light stays on. How do I reset it? I have already tried removing the ground from the battery for 30 seconds with no luck. There must be some way to reset it. Thank you very much!
beancounter
10-16-2005, 10:25 PM
take it by the quick lube and get them to reset it. they should do it no charge assuming they aren't busy and in a good mood. or you can try the dealership. as for a diy answer, i can't help, sorry
peachferrari
10-20-2005, 02:56 PM
I think AutoZone will do it for free too.
