View Full Version : '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. 95 Civic EX 1.6L automatic/check engine light/no air
  2. what is the CFM
  3. '92 Honda Civic When warm starts and stops...?
  4. 92 dx poor acceleration
  5. different civics
  6. Rusty Oil Pan on a '95 Civic DX
  7. Need Help Fast!!!
  8. fuel gage light
  9. Help car won't start - no spark
  10. eBay headers and cat, yay or nay?
  11. Tranny swap
  12. Headlight not working w/ new bulb
  13. Clutch/transmission problem
  14. 95 DX engine surges when in idle
  15. 93 Civic HB; Car's Died on me for the last time.
  16. homemade PVC pipe intake?
  17. Cooling system Meltdown
  18. wtb these parts
  19. Instrument light not working
  20. D15B7 Performance Parts
  21. '95 Civic DX - cut antenna cable
  22. 95 civic 1.5, octane 'ping' ?
  23. New Engine
  24. Engine cranks over but it won't start, need help
  25. A/C trouble
  26. 95 Honda Battery Light
  27. Honda Helms Manuals!
  28. b16a vs. gsr swap
  29. Clanking sound in front end
  30. Buzzing noise after start-up? 94' Civic Ex
  31. how does this sound?
  32. Engineers Wanted!
  33. 92 - 95 honda civic Rust! Quarter Panels
  34. Mega Squirt?
  35. D16 axle to D15 tranny
  36. how to identify the si tranny SOHC
  37. what should be a good exhaust kit?
  38. how to define the 170 hp b16a?
  39. My car just randomly died while I was driving...
  40. name of part ??
  41. stupid question
  42. do engine oils make a difference?
  43. Do fuel injector cleaning chemicals really work
  44. tranny code?
  45. 1993 civic bucks
  46. D15b7 Mini-me d16z6 Running only 2 cylinder??? HELP!!!!
  47. Electrical help
  48. best tranny for b-series?
  49. b16a swap
  50. jdm gauge cluster
  51. Need Help With Xplod Head Unit
  52. need help finding my tire size..please..
  53. 93 lx wont start
  54. cel with p08 ecu
  55. what good is the D15
  56. what do u all think abouit this.is it worth it
  57. exhust cans
  58. quick vx question
  59. anyone good at photoshop?
  60. 94 civic high output alternator?
  61. vtec
  62. what is mpg mean ?
  63. Easy electrical question about grounding
  64. 95 Civic got 46.8 mpg?
  65. dropzone?
  66. Tranny Install
  67. safc2 start ?
  68. Strut bars and other braces
  69. Tire Rotation
  70. Decent cat?
  71. wipers are too slow
  72. Grounding
  73. IAT sensor mod
  74. cheap DIY mods
  75. d15b jdm turbo vs golf v6
  76. 3 grand budget, can it be done?
  77. d15b ecu with d16z6
  78. selling my 92 civic
  79. Ignition Timing
  80. New throttle body help
  81. What is the easiest and cheapest engine swap
  82. Will this bolt up?
  83. Add Vtec on ZC engine?
  84. 92 civic alternator problems
  85. Civic burning oil
  86. long block? short block?
  87. 95 civic ex ECU problem
  88. Cold Air Intake materials
  89. what is DPFI?
  90. hi/low throttrl in safc2
  91. Pictures of my 94 Civic Ex
  92. Electronic Principles
  93. Really rich exhaust...
  94. engine light
  95. knoking sensor
  96. which ecu should i use?
  97. 93 Honda Civic Burning Water/Antifreeze
  98. strut bar/sway bar?
  99. o2 sensor
  100. not impressed with vtec eg civic
  101. what year is my Z6
  102. 1.6L VTEC D16Z6 SOHC to DOHC Conversion?
  103. rmf header
  104. intake manafold questions
  105. vtec-e
  106. Help with a steering problem
  107. windsheild replacement
  108. Dashboard
  109. 95 Civic Ignition Timing
  110. power option upgrades
  111. d15b7 swap mini me y8 help
  112. Parasetic draw while car is off?
  113. 92 civic lx
  114. 92 Civic Momentarily Dies
  115. D15Z1 Engine rebuild - head machining?
  116. Honda Civic EX engine for sale?
  117. Rollin chassis
  118. Rollin chassis
  119. Timing Belt Replacement
  120. How much should it cost to replace radiator mounts and get alignment?
  121. Brake Trouble
  122. advice for b16a2
  123. Trunk lid needs help.
  124. Lowering springs, adjustable coil overs
  125. alternater wont charge battery!!
  126. How Much Could I Get For My Car????
  127. taillight/dash lights out, but fuse not blown
  128. Oil Cooler
  129. Why dose it shake?
  130. installation of eurolite instrument cluster....help needed
  131. Hail Damage! Sux!!!!
  132. diff between whp and bhp ?
  133. Buying a new car - wut should i get?
  134. civic95 won't start, it cranks and sparks ok
  135. Resistor...
  136. Blue Tinted Headlights
  137. 91 civic lx starting problem
  138. D series motors and tranny
  139. Vtec hesitation
  140. extended warranty?
  141. Simple Oil Question
  142. Cat for Civic?
  143. 93 EX Power Steering?
  144. My 95 EX Pics
  145. Is it my clutch?
  146. Gear Box Honda
  147. Q about 93-95 Civic coupes
  148. Catback Exhaust System (need everyones info )
  149. what does that mean RB26DETT?
  150. what does that mean RB26DETT?
  151. Clutch Problems
  152. This is really sad
  153. Correct Head Gasket
  154. 92 d15b with 91 d16 si head swap -Help.
  155. b16a4 swap problem
  156. vtec not working yet working
  157. Replacing rear glass shocks
  158. quick civic question
  159. 86 civic engine into 95 civic
  160. Header
  161. Valve Tick
  162. Tranny Question
  163. 94 civic dx
  164. Tail light help
  165. i would not be any thing from skunk2!!!!!!
  166. is www.xenocron.com good ?
  167. please need help....
  168. Hooked up battery backwards
  169. steering problems
  170. does any one............
  171. ready to give up
  172. '95 Civic alternator question...
  173. what dose this mean?
  174. what kind of.........
  175. Cleaning air filter
  176. Engine Hop
  177. Transmission Problem
  178. K20A2 swap?
  179. Pinks!!!
  180. z3 Fenders On a 94 Civic Ex Coupe
  181. wich setup would make more power/faster?
  182. have to replace plugs every month 93 d16
  183. 17's chippen bad
  184. benefits of Control arms and tie bar
  185. 93 Civic Wont Start
  186. Import!!!! Rhd
  187. 94 civic Si Exhaust question
  188. Custom
  189. 93 civic lx --> d16y8 swap
  190. vtec
  191. Piston's question
  192. Automatic To Manual 92 Hatch
  193. Diff Ecu Wit Diff Motor
  194. Invader Tires?
  195. Engine & Tranny Installation
  196. clutch problem. please help.
  197. Surging idel
  198. what this mean ? >the dyno
  199. Need Help!! RPM's dropping
  200. HELP---93 civic lx d16y8 swap
  201. 95 civic just quit
  202. Coolant smell and light smoke
  203. Skipped timing?
  204. my 92 civic thanks you all for yor help
  205. Honda civic LSI 1992 engine wont start when its raining
  206. Whight smoke and rough idle
  207. If I...
  208. proplem upload photo
  209. ...help...
  210. Gauges
  211. Check this! Civic with teggy front end going mad cheap
  212. d15b2 in a 92 cx???
  213. Problem!!!!!!!!!!!!!Help!!!!!!!!
  214. alternator help
  215. can anyone help?
  216. Installed short shifter now tranny makes noise
  217. cx tranny with a ZC
  218. car wont start. please help becaue i need to fix it fast
  219. Looking into a 92 hatch With h22 JDM..
  220. Throttle adjustment?
  221. how engine cut off
  222. OPEN THREAD(engine swap)
  223. i need help with my fuses!!
  224. Block Swap HELP!!!!!!
  225. Turbo Help!!!!!!!!
  226. great site
  227. Wing Transplant ideas?
  228. auto ecu in manual tranny
  229. Turbo Manifolds
  230. Turbo Manifolds
  231. 1995 civic
  232. 93 Civic DX wont start
  233. Rev Limiter
  234. guage cluster
  235. 93 Civic SWAYS on freeway. SCARY!!
  236. what MSRP mean ?
  237. dry rotted tires
  238. power steering fluid
  239. Ex d16z6 Engine, 5spd trans, ect. priced
  240. rally edition??
  241. Help car won't start
  242. Brake light darker
  243. intake manafold
  244. Syncro's
  245. Several Mother Frickin ?'s
  246. a/c and heating problems
  247. Automatic Transmissin
  248. Plastic inside doors
  249. Code 43
  250. New Civic Buyer
