Automotive Forums Car Chat
Honda
Civic | CRX
> '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
WTB! 93 civic hb this n that..look
Slow on take off????
timing belt help!!!
????????????Need Help??????????????????
92 civic wont start
Home made intake..
lower control arms
tranny of B AND F changable?
Preformance Advice
LS/VTEC turbo Civic or B18C1 turbo Civic
Idle speed
Turbo on a B16A2 Engine Questions!
more carbon fiber..
Weird Idle Problem
engine swap hlep plz
Ok Settle This Once And For All!
girlfriend in trouble #2
girlfirend in touble
max hp
Buying a '94 Civic
Input needed please! Is this worth buying??
'94 Driver's window
Car smokes a little when i hit vtec...
integra intake?
Axle Removal
How can I make my ride smoother?
95 Honda Civic EX Value????
Radiator
98 tranny in 93 eg6?
Motor Mounts
ac install
Will a 95 4door hood fit on a 95 ex coupe?
93 civic D16Z6
Civic DX 1343
Ok my car runs fine, but it sounds kinda funny when i accelerate
Replaced starter, still nothing happening
Motor swap help
Will a b16 tb fit on a d16z6
93 Civic Bushings Cracked/Safety question
Going to the salvage yard! & my 1st pix of my 95 ex
Engine runs poorly in drive, Fine in Park?
95 Civic will not start if it is warm
My 1st honda...
Converting EG4 to EG9
POST YOUR ?'s HERE!
b16a3 in 1996 ?
fresh air leak
Rust...
Platinum +4's
idling help
Will I be alright?
need some help with yellow koni struts!!
89 DOHC ZC on a 94 civic ex
Auto to Manual parts
D16/B16 header question
h22a in a civc AC a go?
Engine mounts....REAR!!! HELP!!!
Help! Moisture in trunk...
question about the HP
Motor Swap
Question on itake manifold
Magnaflow exhaust for a 95 EX..
Ignition Switch or something else?
timming belt cut
plz o plz help me!!!
Brake pedal travel
rear lca bushings
'88 integra LS/B18 question
type-r swap
Carfax?
how to fix engine code 4
Where to buy Valve cover Bolt???
95 to 99 front swap
Can some one help please
My car won't start! Please Help!
Replaced d15b7 with d15b2. something is wrong.
flat spots on tires?
dash light out
93 civic dx engine swap
Alternator Belt Tightening Question
EX Tire Size?
inner rear trim panels
Steering Wheel Allignment???
is there a cheaper alternative for wiper blade
skunk2 manifold carb eo number
transmission swap
Fuel filter line loosening
block switching (if that makes any sense)
Electric Supercharger That Works
d16z6 help needed
I need some help with my civic
help with build?
B18B Info
civic is revin high
Help -- advice needed!
93 Civic JDm Fog Lights
gsr cam and b16 cam
ECU plug?
What do you call this cable?
b18c3
3 random questions
where is the fuel relay on 92 dx hatch
93 Civic Ex VS 96 Ek Hatch
New: Please help? Civic VTEC!?!
Website List
Acceleration/Hesitation issue?
Different oil weight for winter?
Scary moment today- Brakes
coolant system pressure abnormally high
water pump installation guide
B16A Mounts
Help!!! Honda civic cx , no start
93 civic EX check engine light
runs rough at idle and worse in reverse
B16A ?'s
p28
Power Steering Bleed Out - Can I go without?
Guage Cluster mileage?
oil pan gasket
95 civic AT crank pully wont come off!!!
94 civic dx interference motor?
Speedometer 10 mph higher.
1995 Dx Inconsistant Idle
Door Skin Replacement!!! Help!!!
How do I hook up this air/fuel ratio gauge?
question about electrical system
93 coupe CKP code 4
quick question
93 Civic Si Weird Noises From Engine
93 civic tail light,head light,and corner .
exhuast
Removing cat. converter
cel code 19
kyb gr-2 shocks
automatic tranny help
How do I install the dash trim in my '93 civic?
carb to injection?
P73
93 civic. I was just jacked!
Need a new clutch advice?
D16Z6 Timing HELP!!!
technecal question about oil pump
Evil... Very persistant Stuck rotors.
94 civic A?C compressor wont run
Opinions on Engine swap
Exhaust video clips
transmittion leak
Heater hose routing Help!!
Optima battery nowhere to be found??
Alternator or Battery?
Is this the bumper cover or complete bumper
Paint codes?
springs
93 Civic Disc Brake Conv.
Heater core replacement
what do you think?
struts or shock
Brake Help
Cant find power lock plug! NEED HELP!
Removing part of exhaust pipe on 95' DX
d16z6 or d16a9 or d15b 3stage
b16a2 swap, but d16 ecu/tranny/mounts?!!
???? about 1993 Civic
long time to start in the cold
Brake Sensor on 1993 Civic..
Runs fine cold, bad warm
Need help with 93 coupe dissy problem
How to replace my thermostat ?
ticking noise after shutting engine off
is this engine in USA ?
How much to fix this, rough estimate.
looking at a 94 Civic
Chilton or haynes ?
What would you spend $150 on a 94 coupe
Aftermarket Lower Control Arms and Sway Bar
ATTN: who bought ebay headers?
Clanking sound
stereo
ecu code?
look here to know the clynder head year
95 civic ecu question
Keys matched
Thermostat Question
radiator
possible?
Need help kinda new at this. Plz and Thnx!
How can I find out what replacement engine is in my car?
engine code places?
How many miles is too many?
exhaust leak
1993 civic
Security L.E.D.
D-b!?
Badges
Tie rods?
H22a SWAP issues. PLEASE HELP
Core Supports reassembly Help
Questions Help needed =)
Suspension problem
93 Honda civic no start!
Overheating stock 94 ex coupe
attempting to stall
Check out what just came in the mail...
need help with this
JG camshaft 85vt35 valve setting spec need help
Odd Idling Problem. 93 Civic SI
93 civic 1.5 head gasket bolts torque and tightening sequence?
cam gear
93 civic dx speed sensor ?
D16Z6 engine needed
S-AFC 2 Problems
95 civic what wires are needed?
Cutting the springs to lower my 94 honda civic
harness conversion
tranny help 95 civic DX
water pump?
Rough Running
How to Change the Head Gasket In 94 Honda Civic EX
window molding
true or false
Water ddipping w/ ac on
I'm Confused
Please Help... Engine Problems with 94 Civic EX
new heads
How much would it cost me to replace the exhaust?
Replace O2 sensor question
alarm remote programming
turbo d5b7
tough time
Duraflex?
B16b
head gasket?
dashboard lights on my '92 civic
Issue with my e-brake..
My New Civic Si
Transmission Shifts Late
K&N filter oil?
"projector headlights" on my 94 civic hatch?
95 Honda Civic Dx Horn Slowly Died...
Need help on who makes this civic piston. Thanks
ebay header feedback
More questions...
steering rack removal
94 civic?
Hatchback question...
i am looking to spend 15k on a car
JDM H22a issues
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
