View Full Version : '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. car just died
  2. what is DSM
  3. How to adjust camber?
  4. h22a harness
  5. 93 civic power door locks
  6. ECU tricks
  7. undercar plastic guards
  8. door pins
  9. Chip Question
  10. Engine Trouble... PLZ HELP!!!
  11. comp ratio
  12. some questions about d series
  13. what is FMIC
  14. 92 Civic with 220,000 miles
  15. Broken Hood Release
  16. P28
  17. 93 civic speedometer not working
  18. Vibration
  19. Good exhaust
  20. how much for power
  21. 94 Civic Wont Start
  22. Want A Civic
  23. 94 Civic Ex Need Help
  24. 92 4dr o2 sensor
  25. gas mileage
  26. turbo question
  27. d15b7
  28. New headlights, need new bulbs
  29. 5th gen d15z1/ 6th gen d16y8 head swap?
  30. Help Please
  31. Need a Motor
  32. Help Dropping Car
  33. Denji Jaguar Eye Wiring Harness HELP PLEASE
  34. long crank time
  35. how attach picture
  36. hatch lifter prob
  37. lost horsepower
  38. RADIATOR LEAK IN 95 Civic EX
  39. B16A SIR Bogging under load.???
  40. how to install turbo
  41. What's the Best clutch for my set up??????
  42. need carfax..plzz
  43. low gas indicator
  44. low gas mileage in 95 civic
  45. low gas mileage in 95 civic
  46. Oil change freq
  47. Surging ANSWERS
  48. 93 Civic Headlight 2d And 4d Difference?
  49. spark plugs help
  50. outside window trim for 95 civic dx
  51. 93 Civic Si Rebuild (to stock) need help!
  52. Cheap way to light up your gauges.
  53. D16Z6 In to 92 Cx Hatch
  54. Clutch problem
  55. im blowing black smoke
  56. car alarms
  57. Piston help
  58. Piston help
  59. Clicking noise front wheels
  60. sir front clips from japan question
  61. motor swap guides on ebay, good or bad?????
  62. battery charging problems??? HELP
  63. Control Arms
  64. 92VX intermitent drive problem
  65. Fed up erratic idle
  66. Swap CRX pistons in Civic Vtec
  67. turbo question
  68. squeeking brake noise
  69. car stalled after 40 secs. now wont start!?
  70. oil leaking by the timing belt cover
  71. transmission question
  72. 94 civic tranny/clutch issues
  73. Easy question on check engine light
  74. 94 civic Hatchback
  75. My car.
  76. 92 Civic Hatchback Head Removal
  77. Better civic??
  78. what is psi
  79. USDM Engines
  80. Ok, so I'm getting a civic...
  81. Stuff in my tank
  82. Tranny ??
  83. dual halo projector headlight problem
  84. motor work
  85. Question about an engine i might get
  86. 3 cylinders
  87. cluth oil leaking into cabin!
  88. inner tail lights
  89. A Clean 93 Si Stock-ish Owner With Some Questions
  90. need some advice for D15b
  91. fuse panel cover diagram 93 vx hb
  92. spring rates for rear(heavy a$$ subs and amps in trunk)
  93. Can Anyone Tell Me...
  94. Mini Me Starting Problem
  95. 95 hatch ?'s
  96. bad bushings?
  97. Tranny or clutch
  98. Repair Manual
  99. turbo boost
  100. don't know what to do!!! help!
  101. Spoon Crate Motors
  102. 1994 Civic DX throttle body is sucking in too much air
  103. 95 VTEC Intake vacuum hoses
  104. B18b1 surging
  105. fuel pump
  106. Timing marks 93 civic 1.6
  107. fuel pump
  108. 95 Civic Top End Swap over to VTEC, Need a few answers!!
  109. 94 Engine Swap Question
  110. My buddies 585whp Civic... Interesting night!
  111. Power problem.
  112. Corners and Tails Out
  113. Gas Milage on 95 ex
  114. is p30 good for d15b vtec ?
  115. b16a 88-91 long block
  116. Yea!!!!!
  117. Head Gasket... Help!?
  118. Dash Conversion
  119. rear panel
  120. Radiator Fan doesn't work
  121. body an paint
  122. plastic stuff in doors?
  123. Installation of headlights and gauges
  124. 95 Civic pics
  125. Hatch+h22= 12's???
  126. Parts For Sale!! Time For A Tune Up!!
  127. Wiring diagram for gauge cluster 94 civic dx?
  128. Vtec
  129. ex transmission
  130. do anyone know about b18b longblocks
  131. 91 honda HB engine swap
  132. civic wiring help
  133. ex gauge cluster
  134. what do i need for this swap. 97 b18b1 into a 94 civic
  135. 1993 Civic EX for 4250
  136. Looking for a civic coup
  137. Tranny Fluid
  138. Most Effective Swap
  139. Foglight installation instructions needed for 92-95
  140. how know sir tranny ?
  141. Question for your Civic guys regarding the JDM SiR hatchback (EG6)
  142. civic beat a eclipse?
  143. Help!! What's wrong with my NEW starter?!
  144. 95 sohc d16z6 vtec civic ex
  145. throttle position sensor
  146. torque dampener
  147. help
  148. Low gas milage after replacing fuel filter
  149. battery problems
  150. jdm corder lights for 95 4dr civic
  151. junkyard b18b
  152. Engine swap 93 CX
  153. which can kill the GTI
  154. gauge bulbs
  155. polyurethane bushing sleeve
  156. clock /radio reset....
  157. Compression checks
  158. Fuel filter
  159. Vtec Light
  160. HID conversion
  161. how to set clock
  162. Wont start
  163. Engine Overheating
  164. Oil Help
  165. Loud Rubbing Noise
  166. I'm so happy, I just gotta tell somebody!
  167. Help Me Choose...
  168. anti-freeze not working??help please...
  169. How to get the car on jackstands???
  170. Wanna do a RHD?
  171. hi :)
  172. vtec
  173. kittin
  174. d15b7 ta a d16z6 engine swap
  175. 95 Civic EX: Problems going into/out of PARK: Automatic
  176. need storing precautions for my civic
  177. Master Cylinder + ABS question.
  178. honda problems
  179. i need a speedometer...
  180. anyone have a stock 95 shifter?
  181. were the hell i am suppose to start to make my honda better........
  182. Woodruff Key fell out
  183. 94 Civic LX Starter?
  184. strange noises under acceleration
  185. need a part asap!
  186. I am stuck with ball joint nut installation
  187. What do you think my car is worth?
  188. B17's and 92 Civics
  189. anyone selling
  190. ignition lock broken...help
  191. ECU Worth the 40 bucks?
  192. torque
  193. 1995 divic dx trunk light?
  194. How to: Automatic Door Locks/Keyless Entry on '95 Civic?
  195. 92 Civic buckingand shakeing on acceleration
  196. Rev limit on 94 dx?
  197. front axle do it yourself?
  198. front axel with or without ABS, difference?
  199. where is the main relay on 92 dx hatch
  200. Drain transmission oil when replacing driveshaft?
  201. Should washers and nuts be replaced every time?
  202. cx gas mileage
  203. 94 civic dx speedometor problems
  204. Why people, WHY????
  205. Replacing radio/heater bezel?
  206. power door locks
  207. horn harness
  208. problems with reverse
  209. blue smoke at high rpm's
  210. 2 questions......
  211. News Flash: Nitrous Cures Warts(lol)
  212. Hood cable and latch
  213. engine is noisy!
  214. steering wheel shudder
  215. 94 Civic Tweeter grills
  216. drag advice
  217. 95 civic ex fluids
  218. stock 94 civic....clean
  219. racing question...
  220. how many hp on a 92 civic si?
  221. a cam ? and a shock?
  222. steering making wining noise
  223. 95 civic wont turn over, but stereo still comes on
  224. here we go......
  225. idle problems
  226. Honda Turboz
  227. B16 engine and stock tranny
  228. how to save gas ?
  229. wiring
  230. muffler tape?
  231. header swap
  232. 95 Civic LX -- Rear End Package
  233. need drag advice
  234. Which engine do I have?
  235. buying a 95 civic ex!
  236. buying a 95 civic ex - anything i should look for?
  237. jdm d16z6...
  238. 95 civic Water Pump? Overheating
  239. Questions about LSD no not the drug.
  240. taking doors apart?
  241. fuel pump not priming
  242. Easy to install Racing Seats on Original brackets?
  243. instrument panel 95 ex
  244. Is my civic JDM?
  245. ebay headers
  246. No bumper supports! only new bumpers
  247. Wobbling Crankshaft Pulley
  248. 94 civic ex brake problems
  249. breaks upgrade
  250. wheel safe to drive on?
