Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Honda
Civic | CRX
> '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
wheel locks
mini-me/frankenstein
do i have to use the h mounts,
Rain Bad
Looking for a pic of wiring harness
can i swap f22b into my civic
swap help...
Radiator flush question
resistor for gauges
92 Civic Fan Motor Not Turning On
94 Si rotors heating up
how much hp can a dx clutch handle??
headlights...
injector/motor cleaner
Muffler situation
pedals sticking
motor and tranny swap in 92 civic hatchback
Major oil leak
d16y6
Aftermarket Stereo Removal?
Speedmeter problem
Car Alarm Install for a 1995 Civic DX
jdm d15b swap!!
95 Ex 4d boost
95 Honda
American Drifting sensation wins drifting contest in Iraq!!
good deal?
Common Electrical Indiglo question
1995 Civic Dx Stolen & recovered.. Ignition Screwed ?? HELP ME !!
Need help on stock 95 1.5 sohc Civic temp no start situation...
On my mind at the time...
95 Civic Passenger door handle
I'm a newbie and I need advice on a swap
d16y8 vtec solenoid plug
JDM front bumper????
desperate!
Off Topic
94 Civic Speedometer Problem
yet another camber question
compelet info about ECU
testy spedometer/odomemeter/fuel gauge
wich is the best d series motor
Electrical Starting problem
95 Civic DX bought with no start
Made my p-flow lol!!
change your ECU from auto to manual
vtec ecu or non vtec ecu
Speedometer problem part 2
Replacing Speedo Seal
Whats the difference between 94-97 honda civic ex's?
is that dengours at the ecu ?
92 H22A Hatch Flooded
My Honda is overheating
clutch install gone bad i think!
jdm foglights?
manual tranny fluid change
how to wire in the vtec
lsd tranny
several honda questions
92 dx hatch won't start
I need a bolt..........Help....Will work for Bolt
parting out 94 cx HB
are all obd1 fuel inejctors the same
Not enough oil on startup?
Installing Corner Lights
02 sensor for 2001 corolla
95 civic accel. and then some
93 civic AC rattles
93 civic AC rattles
help with swap
throttle body ?
cable hook for a 93 civic hood
Damn O2 sensor
How To Check CEL CODE?
RS*R, HKS, or Buddy Club?
swaped a si cluster into my dx srs light on
obd1 or obd2????
K20 transplant;)
b18c or b18c1
bulbs behind rear defrost and cruise
swapping stuffs
Tranny ate my dipstick!!!
turbo questions
Diff kinda Civic accident
Update on the RHD conversion
Fuel Issues
6 1/2 to 6x9
PLEASE Help her doc! Let her LIVE!!
Wiring Trouble Please Help
head swaps,info, looking for 1.6vtec head and some help
92 civic first time changing brakes help
94 Civic EX window fit 94 DX?
What size speakers?
7000$ wut to do?
site for name of parts with photo ?
air filter
Good Buy?
tickets??????
Difference between EX & LX & DX
all im reading is D15b7s suck balls!!
95 civic ex
i need some pointers
93 Civic Auto Shift Cable
Auto. transmission problems
Carbon Fiber Side Skirts
Torque Converter Install Question
turbo ???
shortest tranny for d15b ?
What's a fair price for this car? PLEASE
Buying a 92 Civic - Problems to look for?
Switch Headgasket... question
94 honda overheating
Weird anoying noise, need help!
Car Is Bogging Down
Gas Mileage Improvement
Why do i feel stupid 4 axin this
Expansion Valve? need help :(
Pix of the creature.
95 civic wont start
94 civic ex with odd markings on the engine
replacing stock antenna
D16z6 with D16y7 block.. will the turbo manifold of the d16z6 fit with the d16y7?
D16z6 with D16y7 block?
question about gauge cluster
Questions about 92 Honda Civic
Im a DSMer wanting to buy a civic project car....heres some of my ideas and questions
92 civic with b18ls swap
92 civic with new dash from 95 acura ?help?
93 civic mods.
94 Honda Civic
what is gsr ?
car sale
anyone ever got a turbo kit from here?
Does this sound like a good car?
need swap help
am i running rich
Replacing stereo
power window conversion
5 gen civic sedan fog light
front window all jacked up
92-95 4dr civics
95 civic dx swap to d15b (vtec jdm)
B18B boosted
Caliper Specs
94 Civic overheating when on Highway.
Just Plain Stupid!!!
Would it work?
New yet not
Temperature Guage Maxing out / motor not hot
How much are we talking???
b16 problems
92 civic with zc swap?
92 civic engine swap query
A dumb question and a smart one... (about stripping)
radio install
Need Opinions
Which wire from ecu is rpm/tach signal?
help...my cooling fan fuse just melted in the fuse box...
Effects Lighting
Axle Boot
civic parts fs
Is there an exhaust that helps you get better gas milage?
Quick Sunroof Q.
figurin' this forum stuff out
turbo D series?
rev limiter
honda ex 95 cruise control not working
d15z1 vtec-e default rpm engagement?
94 Dx Brake Question Ani Or Non?
tranny problems
95 d15b7 to 93 d16z6
my honda after dewin 70 on the freeway
confused about civic dx tach
Can i bypass my oxygen sensor on d15z1 vtec-e
tach in a dx?
Just got a 95 cx, just a couple questions i have.
will a ex cluster clip into a dx
need help
my hatch
squeaky suspension
motor swap d16z6 to b18c1
best engine for civic to accerelat?
>>B18c swap into a 94 ex civic<<
why a 92-95 4dr civic?
burned ignition
timing problems
Interior Lights HELP!!
maximume acceleration
gauge cluster question
camshaft hell help =(
hatch-coupe insurance rates
Speedometer
car stalls
6000 redline?
way too much play in shifter PLEASE HELP!
proportioning valve a MUST for teg rear disc conversion?
Start Up: ITB's on my Civic...
Idle control solenoid location
I Need Da Radiowiring For A 94 Honda Civic Someone Cut Wire Harness Off
O2 sensor question.. NEED QUICK RESPONSE
Ecu question
engine coolant
CX and DX 0-60 and 1/4 times
Hard getting shifter out of park
sunroof wont open in 95 honda civic ex
Tell me everything I need to know about installing a 4-2-1 header.
power window relay ???
A/C Issues - 95 Civic EX 1.6L -
95 Civic A/C Trouble!!!
vtech head on non v-tech block
help, looking for fender for 93civic
My new Civic
Airbag ???
My civic fails to start sometimes
Overheating Civic....
accord brakes?
Newbie Here
Cam Question for ya ladies.
over cammed?
over cammed?
VTEC not working
ECU Code 43
will 96 civic rims fit a 95 civic
red line on a civic
How do I adjust the idle on my car? Is this my problem?
My brake joints squeak and I can't find where to oil! Please Help
'95 Civic won't start
pulleys, what are all of them?
A/c fitting question
jstu got my civic!
turbonator or tornado? that is the question
engine ID
tranny swap
++Walbro 255LPH HP fuel pump++
drivers side mirror cracked!!!
best tranny
baffled muffler
AT transmission problem!
Possible Clutch Problem???
Timing marks off, advanced to the max
92 Si Hatchback Gauge Cluster????
Reverse Lights
Just bought a civic and its shaved......
93 civic EX vtec: idle rpms surging NOT EGR
honda civic ecu
Daughters 95 fluctuates in power on road
Oil Inside Distributor
Dude, Where's my gas?
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
