knoking sensor
hany
04-29-2006, 05:34 AM
what does knoking sensor do?
i have d15b vtec jdm is this motor have knoking sensor ? and if yes how can i know its harness in the ecu ?
CivicSpoon
04-29-2006, 12:36 PM
It senses knock (http://www.visionengineer.com/mech/engine_knock.shtml) and when the knock sensor tells the ECU that there is engine knock, it will retard ignition timing.
I'm not sure if your engine has a knock sensor or not, but I'm going to make a guess and say it doesn't since it's usdm cousin (d16z6) doesn't have one. But if your engine is supposed to have one, you would be throwing a check engine light code for it if it isn't hooked up.
