View Full Version : '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. 95 honda civic ex v-tec
  2. del sol running on 3 cylinders
  3. Are these mounts all I need?, (97 GSR b18c1 into 94 civic hatch)
  4. 02 Sensor
  5. JDM EG From Germany
  6. ECU Problem
  7. Just bought 92 civic
  8. Turn signal doesn't work
  9. CR-VTEC "the right way"
  10. question re Auto Tranny fluid
  11. Engine swap question
  12. is a SOHC ZC worth fixing up?
  13. Spark Plugs Problem.
  14. My Civic 94 EX does not start......please help.
  15. Wtf Tranny Dipstick Is Bent
  16. 92 Civic wont start
  17. 93 5speed need a motor please help
  18. 93 civic 5speed need motor
  19. B16A SiR II Tranny
  20. B20 cylinder walls thicker than H22's?
  21. 92 si ecu code 22? and
  22. Brake enhancements
  23. 92 cx with d16y8 obd1
  24. 95 civic Must push gas pedal??
  25. FRONT END CORE SUPPORT DMG!? HELP! =O pix!!
  26. Help In Buying A Civic
  27. left side blinkers stay on
  28. weird problem
  29. 92-95 Civic DX and EX cam sprockets
  30. Why are sk2 cams $200 more than obx and blox?, What's the difference in them?
  31. b16 head value?
  32. 95 Manual Honda Civic - Shifting problems?
  33. D15B7 and the D16Z6
  34. 94 Civic Alternator
  35. License plate screw size
  36. Civic EK9 Type R gentle climb
  37. Steering Gear
  38. 93 civic won't start
  39. 1993 civic will not start
  40. Engine search for 92 CX....
  41. Runs and stops
  42. Water pump question
  43. 94 civic no spark
  44. 95 Civic EX Stolen ECU
  45. What's the stock exhaust diameter?
  46. motor question on a 97 civic ex
  47. rebuild my gsr
  48. Strange idle issue
  49. '95 LX No cruise control or horn
  50. has any one done this
  51. 1995 Civic LX - Please Help!!!
  52. B16A swap into a Ford Escort
  53. 92 civic injectors
  54. I need help
  55. fluctuating idle, checked spark plugs, then car stalled and now won't start.
  56. No brake lights or horn
  57. motor questions
  58. Don't hate me....what would be faster?
  59. Header comparison
  60. Just got a wrecked 97 GSR
  61. Coolant loss mystery
  62. 95 Honda Civic Missing and has a strong gas smell
  63. Want your opinion guys
  64. replacing turn signal assembly
  65. 94 civic cx distributor O-Ring
  66. 94 civic cx distributor O-Ring
  67. d16 intake/throttlebody on d15 head?
  68. NOOB -B16A2 swap, what dizzy's..
  69. NOOB -B16A2 swap, what dizzy's..
  70. clutch? or tranny?
  71. air/fuel ratio
  72. civic ecu?
  73. dont know what type of engine i have
  74. my car wont start...help please!!!!
  75. 4040 vs 3030 Prop Valve?
  76. 92 Civic: trouble getting the key out in the cold
  77. 92 Civic: wierd rattling noise in the cold
  78. Head gasket questions
  79. Which alternator produces most current?
  80. My unsolvable mystery! - Gas smell/ low mpg
  81. integra brake booster question
  82. head question
  83. civic questions
  84. Error code 21 after engine swap
  85. electric window
  86. timing belt
  87. Knock Sensor
  88. Civic rear disc conversion, What parts will it need?
  89. turbo questions
  90. decat pipe?
  91. How long will it last?
  92. 1994 Civic EX
  93. ...any ideas?
  94. turn signal problems
  95. poor air con
  96. clutch does not seem to catch fully when releasing it
  97. check this out
  98. Fried Battery, anyone know what i should do?
  99. Problem With Car Battery!!! Need Help!!!
  100. 95 civic auto trans problem
  101. D16Z6 head on a D17y8 engine
  102. F serires swap?
  103. center caps
  104. d16z6 v b16a2
  105. car dies when i turn hard right.....
  106. runnin rich yo
  107. 95 civic auto trans problems
  108. 95 civic overheating...frustrating!!
  109. Integra brakes on 94 hatch
  110. Show me your Intake Manifold!
  111. Need some help with headlight alarm!
  112. engine swap
  113. low rpm studdering
  114. EG Hatch strut connector stripped out
  115. wiring diagram
  116. Tampa Where you at????
  117. B16 turbo
  118. Civic not starting
  119. TRANNY GOING OUT? need help
  120. My New 92 Civic. (Im New!)
  121. Engine Mileage
  122. help me figure out why my fuses keep blowing
  123. lowered 92 civic with b 18 having problems
  124. 1993 Honda Civic Hatchback SI Need Help
  125. Melted Bumper
  126. '95 Civic dies when engine is just warm?
  127. What head/tail lights will fit in a 3dr?
  128. Cut Harness?
  129. Cluster interchangable from EX to DX?
  130. What is better to put into a civic?
  131. Turbo...
  132. Clikity-Clak Name That Noise :)!
  133. Compression ratio's by the pistions?
  134. sideskirt question.
  135. New Cylinder Head Question
  136. Fuel Cut Off To Early. Cut Off At 6500rmp
  137. Brake Job
  138. Rough Idel / excel after Car has Warmed up
  139. Decent exhaust on a budget?
  140. CIVIC 94 windshield washer
  141. It just gets worse and worse....
  142. My trunk won't close
  143. 95 honda civic wont start
  144. Trouble with Brake Lights!
  145. which trim for me!?
  146. need advice on 94 civic dx
  147. Exhaust Questions - Whatcha Got?
  148. acceleration problems...
  149. Japan Si cluster into 95 Civic DX
  150. AC system recharge. ac not cold enough
  151. Anyone seen this B series swap DVD?
  152. ABS Brakes?
  153. What's the output on a stock alternator for my 95 civic? How many amps?
  154. LS tranny vs b16?
  155. Alternator belt
  156. are D15 engines interference?
  157. Wiring Diagram for a JDM Climate Control
  158. intake smog help
  159. type r turboed
  160. 95 civic swap-a-roo
  161. Started up, stalled after 5 seconds, won't start!
  162. 95 civic ex coupe 1.6 ltr -83,000 mi -won't get +20mpg?
  163. putting a y8 header on a d16z6 and tb question!!!
  164. d16z6 with y8 parts?
  165. 92 Civic DX SRS light on after clock spring snafu...
  166. main relay?
  167. Stereo problem- fuseOK, wiringCorrect...No constant Power
  168. Bad Injectors???
  169. 95 civic d16z6 ???
  170. ecu coding problem?
  171. fuel system problems
  172. HELP!!!! Suggestions for Rebuilding Motor
  173. prelude fuel injectors
  174. Some exhaust related questions
  175. dizzy question
  176. Exhaust repair mesh
  177. Poor Idle
  178. a/c question
  179. power window and lock conversion
  180. For those of you with Main Relay problems.
  181. accidentally put ATF instead of oil
  182. My B16 is so slow!
  183. Tech Questions...
  184. d16y8 into d16z6 car
  185. 95 Civic hatch
  186. 92 Civic Dash
  187. black smoke
  188. wtb cheap engine
  189. PGM-FI Main Relay, 94' Civic LX
  190. 4 door WONT START???
  191. my list of problems (92 civic dx)
  192. Engine Noise... yay
  193. Whats the Chance of a Warped Head?
  194. 95 Civic Losing Water But Not Out Of Hoses
  195. 95 Civic Poor Idle & Hesitation In Acceleration
  196. Need a picture of a 1995 Honda Civic DX engine
  197. 92 civic sedan possible engines
  198. Need immediate help... How to pop the hood with a broken latch
  199. Oil Pan Gasket
  200. new fuel filter or pump...please help
  201. Car stalls once operating temp is reached?
  202. Disk Brake Conversion Question
  203. any step-by-step on changing an axel?
  204. honda civic and autocross
  205. help! question for integra to civic suspension & brake conversion
  206. Car is not using all the fuel??!?
  207. Heat/AC question
  208. '93 Civic Console
  209. Need model number for '93 civic ECM
  210. what size is the bigest vtec????is it the h22???
  211. Help My Honda Civic
  212. 94 civic-No spark
  213. well... if anyone cares
  214. Dead
  215. What to do with 7-8 Grand
  216. Shift Linkage
  217. 1995 Civic EX Intermittent Wipers Don't Work
  218. b16a2
  219. CRX vs Del Sol vs EG
  220. what would be best to put in a civic 94 coupe
  221. Tps ??
  222. SRS Light Reset????
  223. Power steering for DX manual EG
  224. need help with oil leak
  225. Another 1992 Civic That Won't Start
  226. help poor civic died on me ?
  227. wat should i do k20 k24 or h22
  228. D17a2 swap into eg
  229. Can Someone Help Me Out?
  230. civic shifter safety lock release
  231. Erratic Idling
  232. ????????????d15bvtec?????????
  233. Torque converter not locking?
  234. difficulties
  235. heating problem
  236. Importing a JDM Engine to Vancouver
  237. oxygen sensor
  238. heating/air con controls
  239. window
  240. crower cams ???
  241. Lost in Japan, Civic or Integra?
  242. 95 Civix EX Auto trans filter
  243. Help with engine swap??????
  244. need help with cool air intake
  245. 93 Civic ex grinding brakes
  246. 1995 honda civic dx, need help installing rear speakers
  247. fuel system reset in a 94 honda civic??
  248. Newbie Need help with replacing driver seat 95 civic
  249. wiring for passenger door..
  250. Jerky decelleration
