Automotive Forums Car Chat
Honda
Civic | CRX
> '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
What could possibly be wrong now?
whats better for a 1992 civic lx?!
adding oil pressure guage
engine names
5th gen classifieds???
Relocating a/c controls?
intake manifold & throttle body question????
tranny swap ????
15+ hp mod chip
any body know some cheap easy tune up for mycivic
headers
Header to stock exhaust?
d16z6 swap
grinding gear
Code for Factory Stereo???
94 Civic H/B Need Rear Qtr
Interior Lighting Problem...
exterior mods program?
What tranny is BETTER???
Oxygen Sensors
Help with Radio Reprogramming!!
93 civic 1.5 timing belt
juss bought my first civic
side mirror turn signal wiring
5th gen Civic HB GSR?
help me out
Power Door Locks 93 Lx Civic
somethings wrong with my speedometer needle HELP!!!
1995 Honda Civic Won't Start
Best Headers?
92 civic suspension problem??
94-00 COMPLETE front end for sale
Been gone for a while
94 Civic EX ABS/Cruise/Steering Problem
Need confirmation on speaker size.
code 19 in a manual trans....
92 Civic Hatch I Need Help With B18 Swap!
Idling Problem
hear some evil, smell some evil. (need help)
Engine swap woes
WTB: 1992-1995 Civic EX/SI Coupe
B16A5 or B20A?????
Where do I go to find out if my frame is straight?
Check Engine Light Still On!!!!
any one from hawaiii
ATF change
94' Del Sol Si head bolts
WTF: Back lights wont turn off, Weird!
1993 Civic Hatchback problem
tranny prolem
Possible to fit an 8" sub into the rear deck?
Need Chip - 95DX - I/H/E
Another H22 Question
95' del sol broken timing belt
H22A or B18C1(GSR) into 92-95 Civic HB?
Grrr.. poor car..
Flywheel or pulleys?
SPOON p06 chip ??
92 Civic Install Crank? JDM Fuel Pressure Regulator GOOD? BAD?
what is better a longer intake hose or a shorter one
JDM & USDM?
Civic auto vs. manual trans
Quick remote start question
my car is choking!
V-tec or Not??
Warm engine HIGH IDLE!!!
What kind of camber kit?
b18b hatch
High Flow Intake Manifold
Momo Pedals installed.
no signal lights..help!
Rub!!!!!!!
92 civic LX questions
take out cruise control
93 hatch mount?
no start-b16
95DX HB Camber
Vibration with engine on
noise in 1,2,3 gears
D16A Questions
Bride seats
starter question?
a few more months
Off the wall window question.
need some clarification
couple questions ?
93 Civic Wiper Motor
Back to see whats up in here
camber kit... needed or not??
Help!!! Buying a civic.
92 civic ex four door mods
Debating on buying this car
Trailer Hitch
Does anyone know where I can find a write-up for lowering my 93 Civic?
opened question
Apexi GT
pionner gm-x372 problem
92 civic QUESTION
D16z6
mini me problem
a/c wiring
Vids
Need help - Y8-Y7-A6 compatibility???????
Engine swap question.
Replacement Radiator
Liquid wont spray
internals question
Instructions for lowering 94 Civic
Stripped Distributor Rotor screw
Idle too high on my 95 Civic
ok bad dash problem
witch floor mat for my civic?
just quess
I'm New
Sideskirt length
B20
Broken fuel gauge?
Car Not Starting
Guage cluster in 94 civic dx
rod question
ferio!!!@@@#@#@!$#@!$$!@???
d15b7 to d15b swap
Stupid Radiator
overheating problem!
Headlights and Gauges .. anyone knows where I can find them ? (photos included)
carsponsorships.com
What could you do with $12,000?
Interior vent painting
EK Conversion??
93 civic fuse help
timing belt replacement
Timming issue
Help with hesitation please???
Best performance tires?
Help Please!!! I don't know what is wrong...
Looking For A Hatch
knocking on the firewall
Fuel pump queston......
Short Video
Cel 5 ????
civic radio wire coloring
94 Civic's no start problem
95 civic ex wiring problem
Which hatch...
ECU Code - 1
in the market for a car, need some info
Building Block
sunroof problem
mini me sohc vtec....d-series 4 life!
94 EX Noob questions
is the eg6/ek9 good for auto Xing ??
98 civic motor in a 92 civic body
Looking for a stock exhaust manifold..
Sponsor Question...
Newbie questions
does anybody know what brand on exhaust and intake is good in hp
attn: rice burners
gar eating tooo much gas!!!!
Smoking Front Left Tire Area
Want to make a swap need advice?
Drums or Discs?
i/h/e question
Squeaking, vibrating from Distributor Cap '92 Civic
Yoooooooooo...check out this Acura V6 3.2L swap on a civic!!!!!
looking for a cargo cover for my 92 civic hatch
another start up question 92 civic ex
Apc
Civic Type-R
usdm or jdm
No Start, No crank Help
newbie checkin' in
honda civic CX...
02 sensor problem
Civic HB and VW gti
95 civic lx engine swap
opinions on jdm
180whp racing clutch?
Timing belt tensioner noise????????
Too Many KM's?
Got a ticket for modified Exhaust, need to ask a question
gsr civic swap help?
95 Civic DX Idle Problems
Another stupid question
93 civic speed limiter
limited slip differential in the snow????
Thinking about FI, got some Q's
Blown Engine - Want D16Z6 or full B swap
Headers Help
Sumthin's wrong
gauge in cluster busted help
I so should have gotten a CRX..
JDM ZC rebuild Question.
summit ignition system.
need a part
SI Tranny
ignition problem
Will Vtec Kick In If Car Is Up In Air
brake light!!
passenger turn signal wiring
O2 sensor WILL NOT come out..
weight
headlight issue
completely new to this
Curious to know?
Sound clip on my D16Z6 8700 RPM
Rear Brakes
Random yank
fender question
quick sensor question
Injector problem
need help with gauge installation..
knocking valves problem
Header Performance??
transmission swap cost
Redline question
Troubleshooting Problem
AEM big brake kit
brake upgrade
Already use the Search feature...couldn't find it..
HELP!! 1.6lt vtec 4cly-SWAP??????95 civic
4 sale?
Pearl White Civic
Vtec Engine Swap
Irratic Idle w/ heater on?
Plans For a 94 Civic EX with the V-Tec
Shorts out when I hit Brake?
D16Z6 swap into 92 civic VX
White Rims, HELP!
RPMs
RPM>>>>>>>>>>>>
D16z6 and VTEC
troubleshooting anyone?
another already answered question....
Small question...
rear drum grind
B18B1/B20 Hatches check in
vtec for non vtec. need help
hood fix?
Integra XSi Swap??
s2000 steering wheel
b16a??
V-tec or Not?
Whats faster?? 01 accord or 93 civic
What is that annoying rattle sound??
Gauge cluster/ tire size change ?
trunk problem
95 Civic Hatchback DX tach install problem
what model?
Painting int. Vents
How to Install Ignited Start button for Civic 92
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
