more 93 sentra question w/video!
HeWhoKillz
11-25-2009, 12:03 PM
Moppie
11-25-2009, 03:17 PM
Don't hammer on the distributor!
They have an off set key, so it will only go in when the rotor is facing the correct way.
If you get it lined up right, it will just slide in gently.
HeWhoKillz
11-25-2009, 09:46 PM
how do you know which way to face it?
MagicRat
11-25-2009, 11:21 PM
Push the distributor into the hole gently. When you feel the distributor shaft touch the end of the camshaft, rotate the distributor shaft slowly. When it reaches the right position, the distributor should slide in the rest of the way.
