Fouled spark plugs
moliva1568
11-23-2009, 04:44 PM
This is for a 1984 Caprice classic with a 305. I pulled some spark plugs 1,3,5,7,2. they all (didn't get to 4,6,8) and they all look like the pics below, are wet and smell like gas. it looks like oil is on them too?? the car starts fine and idles fine but during driving it accelerates but then bogs down. i have to punch the gas to get through that. i usually put it in cruise control on the highway to prevent that but any incline and it starts to do it. plugs, wires, cap,coil, are no more than 6 mos. old The mileage is at 108,XXX. What should i look for or do next? I was going to change the plugs yesterday but I want to find the root of the problem and just try to get it all done. The catalytic converter is busted FYI. i don't know if that plays a part.
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1454.jpghttp://i63.photobucket.com/albums/h151/livewire1568/IMG_1455.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1456.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1457.jpg
before i look to fix the above issues, look at the pics below here. at what point do i consider it beyond repair? is it already? what would you do if your car looked like this underneath? should i look to find another car and write this one off ? Is there anything that can even be done to fix/cure it? I wanted to keep from driving this for a while and try to get things taken care of. Unfortunately this will probably be my daily driver through winter unless i can find a cheap station car or something.
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1458.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1459.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1460.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1462.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1463.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1464.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1465.jpg
http://i63.photobucket.com/albums/h151/livewire1568/IMG_1466.jpg
Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 8.12; MSIEMobile 6.0) VZW:SCH-i910 PPC 240x400
Moppie
11-23-2009, 11:22 PM
That is a lot of rust!
I would throw it away before something fails and the car falls off the road.
The fouled plugs look like blow by from worn rings, another reason to throw it away and start again.
MagicRat
11-23-2009, 11:51 PM
First, the rust.
When GM downsized their big cars in 1977, and the others in '78, they went with a thinwall frame concept. The frames were relatively large in cross-section, but the metal was thin. They were not rustproofed well, and most were a C-section in places, allowing dirt to accumulate inside the frame and hold moisture, resulting in considerable rust-out.
If you car is like most GM's of the day, your worst frame rust occurs between the rear bumper and the rear axle.
Try taking a hammer to the rest of the frame. Chances are, lots of the metal surrounding the rust holes is paper-thin and the hammer will go right through it, so your rust problem is actually much worse than it appears. That hole just in front of the rear axle is especially bad.
Unfortunately, Imo, your car is not safe or roadworthy to drive as-is. Sure, it may last a while longer if you drive gently.
But eventually you will hit a big pothole or have a emergency stop or turn which will bend the rusty frame, or a control arm will tear loose allowing probably the rear axle to shift and you may lose control.
This kind of rust is usually difficult to repair. You can't just weld little patches over the holes because, chances are, the frame is rusty and weak front to back, so there is little solid metal left to weld to.
An experienced welder/fabricator can cut and remove large sections of weak, rusty metal, then make and weld in new metal sections. But this is expensive and time-consuming. Your car is definitely not worth the money to fix.
Around here, the cops keep an eye out for cars with this kind of damage, and will seize the plates when found, essentially removing the car from the road.
You could sell it as-is for parts, or locate a similar, rust-free car and use this one for parts.
BTW, don't feel too bad about this. It has happened to millions of Rust-Belt car owners over the decades. I have a 1968 T-bird that was FAR worse. Essentially the front and rear quarters of the frame were connected by fresh air. I fixed it but it was a heck of a lot of work.
As for the engine, it's not blow-by. These engines had a habit of having engine oil leak past old valve seals, allowing some oil to burn and depositing carbon on the plugs, pistons and valves. These seals can be changed fairly easily. But the gas smell indicates carburetor problems. The choke may be sticking closed, the choke pull-off is not working etc. Sound familiar? :)
moliva1568
11-24-2009, 09:22 AM
damn. i guess that's it then. the bad spot you refer to is where the jack hole is and one day when jacking it up, it went through. i guess i'll have to keep an eye out for a new one. thanks
