View Full Version : 3000GT/Stealth
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Less closed threads
  2. airmans swap
  3. foglights
  4. angel eyes
  5. 1st gen headlights
  6. What it's the best clutch for my car
  7. engine swap possible..?
  8. Eibach Springs
  9. fuel system upgrade for 300awhp...
  10. Exhaust Video
  11. piston question??
  12. Best way to drill out a bolt?
  13. squeaky sound
  14. think i got a lemon....
  15. Datalogging
  16. Headlight restoration
  17. ok guys what cam's should I go with?
  18. Interior carpet
  19. Kinda funny...
  20. No Spark, need help quickish
  21. engine internals
  22. break in problem
  23. has anyone polished the intake plenum?
  24. Electrical fun continued...
  25. steeeeeeering
  26. I need a 2nd gen NA Engine
  27. battery help
  28. crap- need help again -electric problem
  29. Looking to buy VR4
  30. guys look at my new ride.. thats for sale
  31. 3000gt TT Conversion or Other?
  32. Lowering springs
  33. Aluminum Lug nits?
  34. Turbo
  35. Lsd
  36. who makes the best air filter?
  37. I'm and Idiot (Clutch Problems)
  38. squeaky noise
  39. about to buy some rims...
  40. carbon fiber hatch
  41. just curious
  42. transmission screwed, help!
  43. Whistling Coasting 25mph-40mph
  44. vr4 radiator
  45. Master Cylinder Problem
  46. ecu tune
  47. cel code p0400
  48. Won't turn over
  49. race my friends?
  50. exhaust backpressure
  51. Glowring and inside lights wont go out.
  52. gas tank
  53. Check Engine Light Problem. Please help
  54. System
  55. Gutting the pre cats
  56. 5th Gear Slip?
  57. SOHC Rear valve cover stuck
  58. Exhaust headers
  59. Radiator and engine fans
  60. SOHC Ticking fuel injectors
  61. JDM engine swap
  62. Back windsheild
  63. Blown turbo?
  64. a story about spare tires and front air dams
  65. New trans computer?
  66. radar detector?
  67. 96 vr4 vs 91 talon tsi.....?
  68. clutch issue????
  69. Major Idol tweaking?
  70. What makes an Auto Trans so slow?
  71. How much power Am I making?
  72. F/S 3000gt Sl
  73. need trans help!
  74. I need help bad, please read...
  75. not goin into gear
  76. timing question
  77. Engine VIN code
  78. Performance question
  79. Videos,Pics,and slips from the track
  80. question about the 99 lifters
  81. 99 turn signal conversion
  82. Best sound system
  83. Question on the Dohc Turbo and non
  84. A/T lag...
  85. Man I love my car
  86. First major problem...
  87. charging system problem
  88. 94 3000GT SL blown Engine
  89. Starter Problems
  90. emissions problem/question
  91. alternator ?
  92. Need advice for 91 stealth
  93. o2 Sensor Bypass?
  94. Short throw shifter
  95. not sure what is wrong with my car
  96. my engine is knocking....
  97. 99 lifter upgrade question.
  98. What do you think? which turbo for the 3000?
  99. electric exhaust cutout?
  100. Idle problems and Stalling when cold
  101. Cams Installation
  102. New Spark Plugs-Are They Worth It?
  103. My engine sounds horrible
  104. I Needa Sub Box
  105. sweet car
  106. 3000gt's/Stealth very own off topic thread: 3rd chapter
  107. My for sale stuff.. make offers please!`
  108. trans/engine plate need help
  109. engine missing? spark plug problem? please help!
  110. Drive Train Problem!!!! NEED HELP
  111. aem plug and play
  112. Valve Adjustment Help?
  113. Trouble at the track :(
  114. small nitrous bottles
  115. Which ECU?
  116. Trans identification/serial numbers
  117. Smog problem!
  118. Spark plug gap for 14psi...?
  119. Stock shift knob thread pitch.
  120. fs...again
  121. FS: 1st gen TT: Airbox, Stealth Center Caps, & Leather Steering Wheel.
  122. Strange noise when i hit bumps....?
  123. nitrous.
  124. texas heat wave
  125. trans driveshaft problem/leak
  126. Alternator Wiring
  127. Exhaust, Custom or Premade?
  128. My tranny crapped the bed
  129. strut problem
  130. 3kgt guy with stealth questions
  131. FYI: Stock 1st gen TT wheel weight.
  132. Electrical failure?
  133. does anyone have an actual 0-60 time for a 3kgt base/SL (222hp)
  134. turbocharged or supercharged?
  135. another headlight conversion question
  136. drop in a V8?
  137. Mistubishi dealership in Victor NY sucks
  138. CEL ON CODES P1100 & P1715 Help!Help! Help!
  139. Engine Knock
  140. 2008 3S National Gathering - 6/17-22/2008
  141. A/F ratio's......?
  142. need help figuring out whats wrong
  143. Boost Gauge Install?????
  144. new to 3000gts, gotta few questions.
  145. good shot for an NA?
  146. 1st generation white rttt for sale?
  147. 1991 Mitsu 3000GT SL For Sale
  148. Milage limit
  149. beat the shit outta this ricer!!!!!!!!!
  150. Moving the MAS
  151. tach help
  152. turbo timer light wiring...
  153. modified civic si and tiburon
  154. cam gears
  155. Aftermarket CD player
  156. lossing boost?
  157. Turbo Timer
  158. where can i get a tb?
  159. Looking for a 3000GT VR4 spyder
  160. carbon hoods
  161. what gauges are you running?
  162. gauges
  163. blown head gasket
  164. Fuel Filters
  165. Bov
  166. Plastic cover for metal honeycombs in MAS?
  167. Plastic cover for metal honeycombs in MAS?
  168. intake install Question
  169. Vr4 Vs Ford Svt F150
  170. Engine Problems
  171. Sail Panels
  172. Help Please
  173. Catalyst monitor error code.....?
  174. check engine light code?
  175. Boost Gauge install questions help fast please
  176. rear garnish
  177. 92 vr4 for sale
  178. Proportioning valve: symptoms of being bad
  179. lifter tick? and a fix?
  180. boost controller
  181. Intake manifold
  182. VR4, honda, lambo, and lotus!!
  183. Bucking like a bronco.
  184. How do you launch?
  185. is this external?
  186. clearcoating sails...?
  187. Name That Part
  188. Aftermarket boost guage
  189. today at lunch
  190. eyyyyyy
  191. Some pics from the North East Gathering
  192. Turbo Timer and Boost gauge installl..
  193. Vr4 aluminum intercooler piping?
  194. Where to find plain rotors...
  195. VR4 Vs. Cobalt SS
  196. Anybody Interested Part 2
  197. can anyone help me with what kind of parts I should buy for a 1994 vr4
  198. dreaming...porsche VTG turbos
  199. Launching a vr4
  200. anybody interested
  201. AWD causing a pull?
  202. anybody ever heard of this?
  203. Went to the track last night....
  204. jacquemond
  205. looking for pics and price
  206. Factory boost gauge?
  207. what's wronge with my car?
  208. its been a month and a half since i last posted, but . . . .
  209. Weight reduction, ECS, SRS, bushings?
  210. dilemma
  211. Quick ?
  212. Failed e-chack with no code?
  213. Emergency Help!!!
  214. BIG oil leak
  215. markoverclock or robbeck's 19Ts?
  216. 3000GT SL vs. Celica GTS
  217. i need a t c u can anyone help me
  218. WTF? Crankshaft can be grounded down?
  219. Need some advice.
  220. Anyone completed a "snake eyes" mod?
  221. First mod for stock vr4?
  222. Throttle Body to Intake Pipe Mate
  223. wierd sound???
  224. Electrical Problem
  225. courtesy light wire
  226. Squeeky belts
  227. Not sure to panic or not
  228. Problems with vr4's?
  229. Help...
  230. Cleaning Polished Parts
  231. hid conversion triggers bulb out/electrical notice
  232. Ebay Intake Advice!
  233. AA relay location
  234. Having Charging system problems
  235. Dry versus Wet System Intakes
  236. About to leave my car in the ghetto....
  237. new project.. hehehe
  238. Musical chairs: the gt ecu ed.
  239. factory alarm
  240. gotta question
  241. Blow Off Valve??
  242. vr-4 transmission...
  243. NA Plug Gapping
  244. Painted my TB today
  245. Voltage Problems
  246. Electrical Issues
  247. tt conv. parts,2-bolt block, manifolds, tt heads, ic piping, lots of misc parts ....
  248. Brakes Question
  249. AWD 5-Speed Trans Needed: 91 Stealth TT
  250. ???????
