gas tank
Micah_Jones
10-10-2007, 05:15 PM
Well i have a leak somewhere in my gas tank but i think it is just the line that comes off of the top of the tank...it only leaks when the car is started and its from the top of the tank so i didnt think theres a hole in the tank...it also has a little trouble starting...do you think a fuel line on top of my tank is bad/has a hole in it/etc...?
Stealthee
10-10-2007, 06:07 PM
Pull the fuel pump access pabnel and check it for yourself. ;)
liquidPunk
10-10-2007, 07:02 PM
Just remove the spare tire and the plastic bins. then you can see the panel.
Micah_Jones
10-10-2007, 07:35 PM
wait...is the fuel pump access panel the metal part that the tire is attached to? i didnt think that came off...ill try that...sounds simple haha
Twizted_3KGT
10-10-2007, 09:42 PM
No, it's a square metal cover held on by screws underneath the plastic bins on the right side.
Micah_Jones
10-11-2007, 07:21 AM
ok i found it...but it is rusted on so i will have to try to get into that today and see what i can find...
