I'm and Idiot (Clutch Problems)
933KGTSL
10-16-2007, 08:01 PM
Okay heres my story, i got a new fuel filter took everything out to install it (Battery, washer fluid resevior ,brackets and what not, and the intake tube) and i was wrenching away at the bottom bolt to remove the line from the filter(knuckes scraping against rusted metal the whole time)and brought my wrench up ,i was leaning on the waxed corner panel, slipped and almost smacked my skull on teh hood and my hand/wrench goes into the release fork boot and that little assembly moves, nothing there was damaged but i went into my car after everything was done(AND all together again) and i step on the clutch, start the car and... the clutch stuck to teh floor, theres a little boot where the metal rod connected to the pedal passes through to the engine bay and there was fluid leaking from there, i wiped it all up and pushed the clutch a bunch of times and nothing else came out, and the master cylinder lost a little fluid i dont have the daylight to do it today(im not lucky enough to own a garage) but tomorrow im going to bleed the system, im just wondering if anyone knows what happened and if bleeding it is the right thing to do
X2Xtreme360
10-16-2007, 10:03 PM
If fluid is coming out of that boot connected to the clutch pedal atatched to the firewall, then you have a leaky master cylinder and need to replace or rebuild it. I would reccommend rebuilding it cause it's very very easy to do and much cheaper... you really cant screw it up.
Linebckr49
10-18-2007, 09:35 AM
^yup. fluid leaking out of the boot near the clutch pedal indicates a leaky clutch master cylinder. now keep in mind, your little accident of colliding with the clutch slave cylinder probably had nothing to do with the leaking clutch master. the clutch master has probably had a very slow leak for a while. it was just now that you crawled under the dash and noticed the fluid.
but rebuilding is definitely the way to go. you can get rebuild kits for the clutch slave and master for less than $10 each. autozone and o'reillys carry these. you may have to search a bit, but you'll find one. the rebuild process is very simple, as you basically just replace a rubber lined piston. the difficult part is removing the clutch master cylinder. its a bit of a pain in the ass to remove, but if you have any questions, ask and we'll be happy to help.
oh, and use a line wrench, or even better crows foot flare wrench, to remove the clutch hard line from the master cylinder.
pics of my clutch master rebuild (http://s57.photobucket.com/albums/g236/Linebckr49/3000GT/Clutch%20Master%20Cylinder/). NOTE: not necessary to remove the brake master cylinder. i did it the hard way.
http://i57.photobucket.com/albums/g236/Linebckr49/3000GT/Clutch%20Master%20Cylinder/DSC02588.jpg
933KGTSL
10-20-2007, 10:55 AM
everyone here at automotive forums are amazing. every time i needed help i got it
THANK YOU!
new2mitsu
10-20-2007, 12:17 PM
if you wanna bay a brand new master cyl. i have one still in the box
