View Full Version : '96-'00 Civic
Pages : 1 2 3 4 5 [6] 7 8 9
  1. Hedlights wont turn on but ambers wont turn off??!!!!!!!!!!!!!!!!!!!!
  2. Exhaust Leak???
  3. help me out please
  4. brake knocking
  5. 99 civic engine
  6. how to remove radio from honda civic lx 2000
  7. 99 Civic Oil Loss
  8. A/C Pipe
  9. Looking for seat belts
  10. service connector for ignition timing
  11. Code 65.
  12. so do I need the heat shields on my 00 civic ex?
  13. Cold Start Engine knock/tick (NEW ENGINE THOUGH)
  14. 98 coupe(EX) build the D-motor & Turbo
  15. Help, cant find something.
  16. how to wire aftermarket headlights?
  17. 2000 civic ex questions
  18. Getting better gas mileage
  19. 96 semi-stock civic lost speedo,A/F light show,etc.
  20. 99 civic si
  21. dead battery possibly? your input needed..
  22. Looking for Advice !!!
  23. turbo kit for 92 to 00 civic
  24. I need inside door panels for 1997 honda Civic
  25. D16??
  26. Headlight Setup
  27. Timeing Belts
  28. Newbie looking for advice.....
  29. swamp problem
  30. universal O2 sensor
  31. 99 civic hesitates
  32. Throttle stuck...?
  33. 96 Civic EX Overheating
  34. engine swap for 98 civic coupe
  35. Fuel mileage?
  36. 98 Civic High Pitched transmission noise
  37. any ever dynoed stock b16a sir
  38. B18C1 hatch with problems...
  39. auto ignition switch in my 5 speed????
  40. f22b1 in a 97 civic ex
  41. faulty power door lock
  42. B18C GSR or B18C Type R
  43. Automatic door locks break fuse
  44. 98 hx problems, but whats new
  45. Suggestion on Early Mods
  46. whats really good?
  47. Idle question
  48. More Power
  49. 98 honda civic speedometer brocken
  50. worry about overheating
  51. Headers, Exhaust
  52. brakes
  53. Idle cintrol solenoid location
  54. Radiator support&Syncros
  55. CF diffuser?
  56. air intake questions
  57. air intake questions
  58. 00 civic burns oil
  59. Car 'floats' at 60mph and above
  60. 5TH GEAR PROBLEM: VERY HIGH RPMs AT 65MPH
  61. 5th gear problem
  62. obd2b b18b into 00 civic hatch help!!
  63. Why are EX's so slow?
  64. looking for gearheads near akron ohio
  65. Fuel Specs
  66. 17's
  67. power windows!
  68. 1999 SI Question
  69. Code 67 Help!
  70. motor help????
  71. fer problems with my 96 civic
  72. Manifold too restricting?
  73. Driver Seat Mysterious Wire
  74. PCV Valve location 97 Civic LX Manual
  75. Tire width?
  76. turbocharging a fully built B20v
  77. Am I getting a Good Deal?
  78. 96 civic with a/c problems
  79. Main Pulley
  80. will 96 civic rims fit a 95 civic
  81. temp switch location
  82. Build your own turbo kit?
  83. Inhale and exhale
  84. Intake not sucking up air like it should?CEL error Fuel too rich
  85. Wheel weight?
  86. I cant get power to my left door panel speaker??????!!!!!!!
  87. How to install tweeters?????????!!!!!!!!!!!
  88. does a 98 civic hatch have abs
  89. 98 Keyless entry
  90. Help installing subwoofers!!!!!!!! to 1997 Civic
  91. 97 Civic DX Cpe - Need help!
  92. CIA bypass question
  93. 96 civic with no engine
  94. Hose came loose from AEM CAI and don't know where it goes...
  95. Cross Reference for AEM CAI filter
  96. 97lx TRUNK PROBLEMS...
  97. tires?
  98. Need Directions/instructions On Changing Timing Belt
  99. How do I adjust my e-brake?
  100. full AC install 98 Civic
  101. 1997 Honda Civic CX Hatchback Turbo Question
  102. h22 hatch owners
  103. '00 Civic Won't Start w/ key, only remote start.
  104. 97 CIVIC EX 1.6 L4 D16Y8 FI SOHC; VTEC Won't start
  105. 68mm Throttle Body/CAI
  106. is there detailed pics of bottom of civics online?
  107. What years can swap the engine with the 99 127hp?
  108. help changing spark plugs pleeze
  109. where is the air intake hose?
  110. Shift Light mod
  111. shocks and springs
  112. fog lights
  113. What body kit looks best on 96'-00' Civic?!
  114. quick question regarding the lift points on civics..
  115. Sony CDX-F5500 MP3 (Memory problem)
  116. got problems
  117. Oil Filter 4T22
  118. tires, what do you ride on?
  119. Questions about 97 honda HX
  120. 99-00 civic parts
  121. How to remove airbag to install aftermarket wheel
  122. 1998 Civic SiR with B16a engine ***HELP!!**
  123. how do you know if you need new rotors?
  124. Doors will not lock or open!!!!!!!!!!!
  125. My e-brake doesn't work (ok to remove completely???)
  126. Need Help Plz
  127. Messed up parking brake
  128. vtec malfunction question
  129. a car that run 12's??????????
  130. DOHC Engine Swap
  131. will 99 hood fit my 97
  132. p0131 code
  133. Sounds like a Turbo, But NO TURBO!
  134. Need A/C help...
  135. Speed Chip?
  136. slow acceleration
  137. general maintenance + manual
  138. Belt Replacment on 00 LX
  139. Buying a Steering Wheel?
  140. Models of Honda Civics
  141. Rate Your Exhaust
  142. any 1 herd the dragger muffler
  143. d16y7 compression
  144. Thinking of buying a Civic . . .
  145. k24 motor in a 1997 civic
  146. Engine Swap
  147. intake
  148. Help Me Plz!!!!!
  149. Selecting park
  150. Head Gasket Horror! I Need Help
  151. 99 civic power windows..help
  152. exhaust questions
  153. ECU for VTEC
  154. water & spark plugs, NOT GOOD MATCH; HELP!
  155. head lights
  156. Tach problem need help
  157. Civic 98 Alternator Replacment Walk Through
  158. No spark
  159. Keyless entry / Alarm - 98 Civic
  160. flowmaster exhaust ?
  161. Buying 96 H/B
  162. O2 sensors
  163. Squeaky Clutch
  164. guage cluster
  165. trans fluid leaking in clutch
  166. weird noise please help
  167. OEM vs aftermarket front bumper
  168. Almost stolen 99, now needs ignition. HELP.
  169. is the d15b a direct replacement for a 1997 civic dx
  170. N/A setup
  171. alternator drive belt help
  172. Tough decision, need lots of help here on purchase
  173. ecu or distributor
  174. 98 dx cat-back exhaust
  175. OEM keyless remote entry for 96 EX
  176. ? about the engine for a 1997 civic dx.read
  177. Catback vs. Axleback
  178. Exhaust for 4dr?
  179. compression ratio
  180. N/A or turbo
  181. Websites not to order parts from...
  182. car specs
  183. Knock sensor question
  184. whats the best sounding exhaust for a 1997 civic dx
  185. whats the best intake for a 1997 civic dx
  186. Free Rear Strut Bar for 99-00 Civic Si Coupe
  187. cold engine problem
  188. difference between drag and full coilovers?
  189. No power steering on my '99 DX?
  190. 98 ex
  191. Si or EX?
  192. Clutch click
  193. engine swaped parts
  194. watch this hilarious vid
  195. getting a 96 civic
  196. sponsership pros and cons, and availible ones
  197. 97 lx best engine swap for the price
  198. just curiouse. what would i get for a trade in for a new civic if i traded in a 1997
  199. whats the best place to get a engine for a 1997 civic dx
  200. Is my 2000 civic ex a vtec
  201. b18b swap
  202. getting a 96-00 civic soon
  203. K20a2 AC & Powersteering
  204. cat????
  205. BAD Head problems plz hlp
  206. getting a motror swap
  207. Vtec Head Swap Question
  208. how to install a muffler?
  209. gaughe swap
  210. timing belt help!!
  211. 00 civic----burning oil in no.2 cyl
  212. locking tuner lugs
  213. Civic SI - please read
  214. D16 series valve covers
  215. Turbo vs Supercharger in a B18C5 Type R
  216. Door Panel
  217. clock reset
  218. Cutting off Catyliac Convertor
  219. how can i redline higher?
  220. 2 questions...
  221. Need Help, 98 DX Hatch Intake System
  222. headlight bulb size?
  223. what in the hell is VP???
  224. Electric Supercharger?????????????
  225. Spring installation
  226. Need Wire Diagram for 97 d16y7 alternator
  227. 97 Civic Turbo D16y5 ..fuel pressure help.
  228. How many inches of piping should i go?
  229. are these good rims?
  230. PCV Valve location 2000 Honda Civic EX
  231. Side skirt length?
  232. Clutch adjustment???????
  233. CIVIC SI vs. CAVI Z24?
  234. 99-00 A/C Kit on my 1997 DX Civic?
  235. 97 civic hx
  236. does this seem like a decent setup?
  237. Got a new hatch
  238. is a 97 civic dx a good car?
  239. 97 Civic HX Catalytic Convertor
  240. engine problem?!!
  241. radio code
  242. Need help with Trouble codes
  243. exhaust/catalytic converter
  244. help with 1999 civic ex motor swap
  245. Need help deciding new struts
  246. help need a 98 lx exhaust manifold will anything else work
  247. radiator help, please
  248. please tell me my wheel bearings arent gone
  249. shift knob
  250. d16y8 rebuild question
